Exterior Blackout Overlays
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dxironman, Dec 17, 2021.
  1. Dec 17, 2021 at 3:23 PM
    Dxironman
    Dxironman [OP] Well-Known Member
    Central Florida
    21 TRD Sport
  2. Dec 17, 2021 at 4:34 PM
    Tacoma091919
    Tacoma091919 Well-Known Member
    Tim
    2019 OR DCLB
    I bought cheap ones on Amazon. Been on a little over a year and working just fine. Like the look much better than the bright chrome.
  3. Dec 17, 2021 at 5:29 PM
    Sierrahunter
    Sierrahunter Well-Known Member
    2022 SR5 Double Cab Long Bed 4x4
    I've purchased both. One OEM package was from Ebay, (a repair shop needed to order the full set, only used one emblem, then sold the rest), the other was a "ToyoBB" brand to cover the missing emblem (also from Ebay). In comparing the two, there are small differences, but imperceptible unless side by side. IMO, the main issue is whether the adhesive is different, which I cannot tell.
    Side note, there are dozens of "OEM" emblems on Ebay and elsewhere that are not OEM. If you want OEM, ask them if the box says, "Toyota".
  4. Dec 17, 2021 at 5:44 PM
    japjoe7
    japjoe7 Well-Known Member
    Joey
    Pike County, PA
    21 Barcelona Red Sport DC AT
    Bought mine here, eBay fit perfect. Personally I find the price of the OEM just ridiculous for what they are.
    Jere likes this.
  5. Dec 18, 2021 at 12:24 AM
    Gonks
    Gonks Well-Known Member
    OC
    SOLD 2020 White TRD Offroad 4x4
    The main difference I have seen while shopping is some knock offs will fade faster than others. Just look at reviews for the brand you are looking for. It is very hard to justify the insanely overpriced OEM ones for so simple an item.
  6. Dec 18, 2021 at 1:00 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Got to be careful on the Amazon cheaper ones like I hot. I put one on and you can see the chrome on the top just slightly. Off they came and I picked up a set from the dealer. Much better quality on the OEM in my opinion. I returned the Amazon junk ones, however there may be a better set, I may have gotten the cheap ones but yes there is a difference.
  7. Dec 18, 2021 at 6:45 AM
    Dxironman
    Central Florida
    21 TRD Sport
    If they fade or need to be removed will it mess up the chrome when they come off?
  8. Dec 18, 2021 at 11:03 AM
    pnwtacoma_
    pnwtacoma_ Well-Known Member
    Matthew
    Portland, OR
    Solar Octane '23 Tacoma TRD PRO
    BuiltRight Industries Bedside Rack, Baja Designs Amber S2 Pro on CBI ditch mount brackets, Baja Designs Amber Squadron, Switch-Pros PowerTray for SP9100
    Most go on with 3M tape so you can use a heat gun to loosen that when taking off a faded cover. Only caveat is that the OEM chrome emblem went on with 3M tape also, so you'll want to be careful that you don't overheat the cover and original emblem. Doing so means you run the risk of both coming off together
    japjoe7 likes this.
  9. Dec 18, 2021 at 5:45 PM
    ALI3N_123
    ALI3N_123 ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Eric
    Austin, Texas
    2021 Silver TuRD Squirt DCSB 4x4 // 2008 Black Rusty Shitbox DCSB PreRunner
    Counterfeit Toyota parts do exist. Cruise control stalk stopped working on my 2008 so I bought a new stalk on eBay. The baggie it came in had the nice looking Toyota sticker stating part number and all that but upon comparing the 2 stalks, it did feel a bit cheap. Knockoff works well though.
