extra capacity oil filter
Discussion in '2nd Gen. Tacomas (2005-2015)' started by j31driver, Aug 25, 2009.
  1. Aug 25, 2009 at 6:02 PM
    j31driver
    j31driver [OP] Active Member
    chris
    upstate NY
    09 Tacoma
    Hi there, new to tacomaworld and new to Toyota. Just got my new 09 Tacoma base 2 w/d 2.7 liter 5 speed. I love it so far! I have so far taken the secondary air filter out and put on an engine pre -oiler. I have always used Purolater's best for oil filters and I am looking for an extra capacity filter. Any help would be appreciated. Thanks, Chris
  2. Aug 25, 2009 at 6:20 PM
    Terrier
    Terrier Well-Known Member
    2008 SR5 Access Cab 4x4 2.7
    I think that possibly the filter for the 6 cylinder might be greater capacity and might be interchangeable with the 4 cylinder filter. Check with your dealer parts department.
  3. Aug 25, 2009 at 6:23 PM
    mpgnc64
    mpgnc64 Well-Known Member
    Mike and Denise
    Western NC
    06 4x4 Access cab 4cyl 5spd, 2000 Prerunner
    Tool box, Thule rack, rod holders, 5100s at 1.75 and the TSB
    I use a K&N pn 2009 for my 2.7. Its larger and the 1" nut on the bottom makes it real easy to remove.
  4. Aug 25, 2009 at 6:28 PM
    Hootbro
    Hootbro Omnipotent
    Delaware
    2009 Tacoma Regualr Cab 4x4 2.7L
    Word of advice so you can make adult decisions.
    Use of a non cataloged spec'd oversize filter for any application is grounds for the filter maker to deny warranty claim if the filter fails and engine problems result.
    Use of any filter that is not Toyota OEM, is grounds for Toyota to deny warranty claim for any oil filter related problems.
    With that said, any filter that is equivalent to FRAM PH3600 is a good oversize filter for your application. (Just stay away from FRAM)
    Ford Motorcraft FL-400S filters are a good one also and are made by Purolator
  5. Aug 25, 2009 at 7:09 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Also, they can't deny you your warranty for using an aftermarket filter if it meets spec per that court case of which then name I forget at the moment. If you used K&N's filter, they would even fight it for you if you were denied.
  6. Aug 25, 2009 at 7:14 PM
    Hootbro
    Hootbro Omnipotent
    Delaware
    If the after market filter is the cause of failure, you are still stuck getting restitution through that after market filter maker.
  7. Aug 25, 2009 at 8:58 PM
    SCCAKen
    SCCAKen Well-Known Member
    Ken
    Atlanta, GA
    09 Access Cab V6 Auto TRD Off Road
    Weathertech floor liners, MacNeil dark window deflectors, debadged, dedecaled.
