Extra plug inside dash?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Lionfan, Jan 25, 2010.
  1. Jan 25, 2010 at 8:07 PM
    Lionfan
    Lionfan [OP] Well-Known Member
    Colorado
    03 ext cab trd black
    Billy 5100's with eibach 3"coils and custom built rear leafs, brush guard and lights, sprayed in bedliner, camo interior, camo decals, new sound system, wet okole's, 265/75/16 tires, fog light mod, rear locker mod, deck plate mod
    Ok so I was taking my dash trim pieces off my truck and noticed an extra little plugin on the left side behind the dash. There is nothing for it to plug in to so I was wondering what it was for? Its white and has a 2 prong plug in. It is taped with the bunch of plugs that go to the ect power plug and the dash light dimmer switch and the rear diff lock button. Any ideas what it is?
  2. Jan 26, 2010 at 6:01 AM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    ??? Pics?
  3. Jan 26, 2010 at 6:06 AM
    Gr8WhiteTaco
    Gr8WhiteTaco bishes love my haircut
    Aaron
    Knoxville, TN
    SOLD 02 Double Cab TRD 4x4
    2005 Mazda 3S hatchback
    x2
  4. Jan 26, 2010 at 7:26 AM
    Lionfan
    Colorado
    Ok heres a pic. Its the little white plug on the left. The other plugs are for the dimmer and diff lock, and the plug for the ect power is not in the pic on the left. Did it come unplugged from something that I didnt notice when pulling everything out or is it for an add-on you can do. I only remember unplugging the 3 plugs and I've looked for a place that it might plug in to but cant find anything. Any help would be great before I put it all back together and find out I need it for something.
  5. Jan 26, 2010 at 9:52 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    Toyota typically installs as full a wiring harness as applies to the most versions of a given vehicle. This means that the factory harness might include empty plugs for connections you don't have (e.g., optional equipment not installed on your Taco).
    In other words - such 'dead end' connections are to be found in most all pre-2005 Tacomas.
  6. Jan 26, 2010 at 9:54 AM
    maconhurler
    maconhurler Well-Known Member
    Harrisonburg, VA
    04 4wd v6 sr5
    Deckplate Mod, Catz Fog lights, Roll Top Tonneau Cover, Pioneer Premier 800prs HU, 10" Kicker L7, Kicker 5 1/4 components, Polk dB 5x7s, Oznium superflux puddle lights and bed lights
    I too have seen this plug and wondered what it was. I'd love to know specifically what its for.
  7. Jan 26, 2010 at 2:19 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    Power Mirrors?
  8. Jan 26, 2010 at 5:07 PM
    derekp
    derekp giddy up!
    Derek
    Grand Forks, ND
    2001 X-Cab 4x4 TRD V6 5Spd
    Deck plate, Flowmaster Delta-Flow 40 series, 265/75-16 Wrangler TDs, more to come...
    My power mirror switch is in the door. Is the sunroof switch located in the roof or dash? Could it a switch for fog lamps?
  9. Jan 26, 2010 at 6:21 PM
    Black Taco
    Black Taco Well-Known Member
    Rob
    WPB, FL
    TOYOTA
    Not OEM.
    I was thinking the plug for the trailer brakes for the pigtail that comes in your glove box, but couldn't tell from the pic. That's more on the column. ???
  10. Jan 26, 2010 at 8:22 PM
    Lionfan
    Colorado
    Thanks for the info guys. Ya I was thinking a possible fog lamp or trailer brake control too. Ok good to know Im not missing something. I just had a few parts of my dash, door trim and my console dipped in camo so I am in the process of putting it back together. I'll post some pics when I get it put back together.
  11. Jan 26, 2010 at 8:29 PM
    REVHARD25
    REVHARD25 Well-Known Member
    so cal
    RUGGED TRAIL PACKAGE
    Tint on front windows. Dnx7120 kenwood. Rear tsb springs. Wet okoles seat covers UWS truck box Weathertech floor mats TSB floor mat hook grommets Satoshi grill AFE drop in filter Fumoto drain valve Bed mat
    Its for the optional ejecter button ..in case your lady is giving you shit;)
  12. Jan 26, 2010 at 8:43 PM
    EnolaGaia
    Midwest USA
    '01 & '04 S-Runners
    There was never any such thing as a powered factory sunroof or provision for fog lamps in the 2001 - 2004 Tacomas, so it's not either of those ...
  13. Jan 26, 2010 at 9:37 PM
    pittim
    pittim mittip backwards
    Pink slider.
  14. Jan 27, 2010 at 9:59 AM
    derekp
    derekp giddy up!
    Derek
    Grand Forks, ND
    I remembered a sunroof option on later years but couldn't remember if it was powered on the double cabs or not. 1 outta 2 ain't bad! They might have shared the wiring harness on the 4Runners and that might be the switch for the back window...(thinking out loud)
  15. Jan 27, 2010 at 11:06 AM
    EnolaGaia
    Midwest USA
    '01 & '04 S-Runners
    The factory 'sunroof' was actually a manually pop-up moonroof, offered from circa 1995 to circa 2002 or 2003.
    However, dealers may have added or offered aftermarket power sunroofs at the point of sale. In any case, the factory harness didn't include any wiring for a sunroof or foglight option.
    Tacomas and 4Runners of that period didn't share harnesses. 4Runners were assembled in Japan and Tacomas in the USA. The harnesses were supposedly sourced from two entirely different suppliers.
  16. Jan 27, 2010 at 5:06 PM
    MowTaco
    Kansas
    Didn't know if you had power mirrors or not. Fog lamps are probably my next guess.
