Extra Reverse Lights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TuRDTACO, Nov 30, 2007.
  1. Nov 30, 2007 at 11:28 AM
    TuRDTACO
    TuRDTACO [OP] Carolina Alliance: Midwest Firearms Division
    joliet, il
    HAD 07 TRD OFFROAD PRERUNNER
    small dent on the hood, new foglight bulb, roughed up bedliner, been smoked in, suspicious stains on the passenger seat, boogers on the drivers seat, dirty floor mats, girl doodles on the dirty windows, loose wiring
    i know there are at least a couple tacos on here with extra reverse lights, here are mine. they're just small fog lights from pepboys bolted to the bracket on each side of the hitch in the back.
  2. Nov 30, 2007 at 11:53 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    That's a nice setup. Did you run a fresh wire back there or are you feeding off of the trailer harness?
  3. Nov 30, 2007 at 3:51 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    looks good man!! when i get rid of my dual exhaust, and put just a reg. single in/out flowmaster on there.......im definitely installing a set on my ride. they will help alot for loading/unloading my boat at the lake, and numerous other things( light it up when some is tailgating your ass, they will back off:D)!!
  4. Nov 30, 2007 at 4:30 PM
    concrete jedi
    concrete jedi Well-Known Member
    Rochester N.Y
    06 Tacoma 4 door indigo blue
    Broken and scratched tailgate, cracked rear tail light lens, coffee stain in driver seat.
    Very clever ! clean, small, out of the way, effective. :thumbsup:
  5. Nov 30, 2007 at 7:44 PM
    TuRDTACO
    joliet, il
    everything is wired independently, i just ran the power wire from the battery to avoid screwing up anything on the hitch plug
  6. Nov 30, 2007 at 7:45 PM
    TuRDTACO
    joliet, il
    yes thats an added benefit lol, i havent gotten to use them to blind anyone following too close yet but i'm just waiting cuz when i do, it'll be enough to make them hit their brakes lol, these little lights are bright as hell, i can see everything within 75 feet in the dark now
  7. Nov 30, 2007 at 7:47 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    i wired mine under the truck b/c i'm sure i'd bust them backing into something...lol...i either turn them on at night for tailgaters....or turn on the cargo's to give them a heads up too
  8. Nov 30, 2007 at 7:47 PM
    TuRDTACO
    joliet, il
    and i only spent $30 on the lights w/ the harness, 4 on the switch and 5 bucks for various nuts and bolts to fashion up the brackets needed to bolt them up, but these things are rock solid, they aren't going anywhere unless i really want them to. the best part is that nobody even knows they're there unless i point them out
  9. Nov 30, 2007 at 7:48 PM
    TuRDTACO
    joliet, il
    when i get my light/roll bar put in i'll be using a similar pair of lights for cargo lights
