Extra Soot?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Maticuno, Feb 16, 2013.
  1. Feb 16, 2013 at 4:49 PM
    Maticuno
    Maticuno [OP] Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    I know that the 1GR's run a little rich and I'm used to seeing some carbon sticking near the tip of the exhaust, but recently my truck has been throwing so much that it is splattering all over the mud flaps and side of my truck. I've also noticed a rather sharp decrease in fuel economy (2 - 3 mpg). No codes are showing on the scanner. Any chance my O2 sensors are on their way out but haven't thrown a code yet?
  2. Feb 16, 2013 at 5:28 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Cold weather = longer time spent running in open loop + shit winter gas = more soot.
  3. Feb 16, 2013 at 5:39 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I'd run a tank of Lucas fuel system cleaner through it then change the oil. A few squirts of MAF cleaner wouldn't hurt, either.
  4. Feb 16, 2013 at 5:41 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    a/f sensor going bad can do this
  5. Feb 16, 2013 at 5:42 PM
    Maticuno
    2011 Suburban 2500
    I did the MAF and throttle body cleaning about a year ago and everything was pretty clean. I occasionally run a bottle of Techron through the tank, but I'm still pretty sure most "fuel system additives" are snake oil.
  6. Feb 16, 2013 at 5:48 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    If you don't run a fuel system cleaner occasionally, olefin builds up in the injectors and can make them stick open (or closed) so I've heard.
  7. Feb 16, 2013 at 5:48 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Not with todays fuels.
  8. Feb 16, 2013 at 7:05 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Nope. This hasn't been an issue in many years.
