Extra Weight in bed - Need Suspension Advice
Discussion in 'Suspension' started by pos3idon, Sep 2, 2014.
  1. Sep 2, 2014 at 4:33 PM
    pos3idon
    pos3idon [OP] Active Member
    New York
    2011 Tacoma 4x4
    12 Volt outlet in bed, Leer Topper, UltraGauge, second battery
    Howdy All,
    I have a 2011 Toyota Tacoma Access Cab 2.4L 4x4.
    I added a bunch of weight in the bed with the following:
    Leer topper (Leer Model 180 - I'm guessing weight is around 210 LBS)
    Roof Rack
    Roof top carrier box
    Second battery (Optima Deep Cycle Wight 39 LBS)
    Sleeping area and storage drawers made from 3/4" plywood. (Not sure about the weight on this; just guessing maybe 100-175 LBS)
    Gear
    Water
    Now my leaf springs are drooping (I have had the TSB performed) due to the extra weight. What would you recommend to fix this? I was considering dropping the leaf springs and replacing them; any advice on springs?
    Thanks for the help!
    Note: I have some super Springs laying around that were removed when the TSB was performed. Do you think these could be used with the post TSB springs? (they also rubbed on the brake line which was part of why they were removed)
  2. Sep 2, 2014 at 4:46 PM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    If you want lift (2.75"/3" - 4" UNLOADED depending on which option you pick below):
    (I would suggest getting the additional D29XL leaf to add to the pack) OR
    (I would suggest the expos) OR
    If you want minimal lift (1.5" UNLOADED; remove TSB before installing; unless someone else says otherwise to leave it in in addition to the kit below)
  3. Sep 2, 2014 at 4:48 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Wheelers HD leaf pack or airbags
  4. Sep 2, 2014 at 4:55 PM
    pos3idon
    New York
    2011 Tacoma 4x4
  5. Sep 2, 2014 at 4:56 PM
    PCTaco
    PCTaco 36 hour Build
    Adam
    New Columbia, PA
    '18 Access Cab TRD Offroad RIP '13
    Working on it
    I'd go with airbags if you don't want lift.
    If you want to lift everything APEX leafs or Dakars + the d29xl AAL.
  6. Sep 2, 2014 at 4:56 PM
    geekhouse23
  7. Sep 2, 2014 at 4:56 PM
    OZ-T
    Peter North
    British Columbia
  8. Sep 2, 2014 at 5:10 PM
    pos3idon
    New York
    2011 Tacoma 4x4
    Did you use the Nitrocharger Shocks as well? How's the ride quality? I'm cautious about going up too far because I don't want to make my tires look small (245/75 R16 Hankook Dynapro ATM's)
  9. Sep 2, 2014 at 5:11 PM
    OZ-T
    Peter North
    British Columbia
    Yes , stiffer than stock but handles weight great
