Extra's needed after 3" lift
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jlaurence32, Nov 28, 2021.
  1. Nov 28, 2021 at 8:36 PM
    jlaurence32
    jlaurence32 [OP] Well-Known Member
    Colorado
    2016 MGM TRD Sport 4x4 DCSB
    Just did a 3" coilover lift with UCA's, came with diff drop and carrier drop. Everything seems fine. What are some other things that may need to be addressed due to the lift? I'm gonna do the extended rear brake lines, they were really stretched when the rear axle was hanging, and also read something about the CV boot fins rubbing because of the new angle? Not sure about this. Anything else recommended?
  2. Nov 28, 2021 at 8:38 PM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    Did you change out the driver side bearing on the front diff for a solid bushing?
    CV boots rubbing is pretty typcal with much of a lift. Clean the CV shaft near the outer boot and slide the inner end of the outer boot inward about 1/2" and crimp a new clamp on it.
  3. Nov 28, 2021 at 10:08 PM
    jlaurence32
    Colorado
    Oh yeah, forgot, had to do the ecgs bushing. Was pulsating like mad. The bushing fixed that... anything else besides the cv boot?
