Extremely BAD,
Discussion in '4 Cylinder' started by bsb120, Nov 28, 2013.
  1. Dec 11, 2013 at 6:50 AM
    Enid
    Enid Member
    Victor
    Oklahoma
    2014 Tacoma Pre 4cyl
    Grill guard
    Wish I had read this before I purchased my 2014 4 cylinder. MPG is around 20 but as low as 17 with mostly highway miles. I hear the 6 cylinder is getting about that much. Worse thing is the 4 cylinder is a dog. I have to have lots of room to pass on the highway due to the lack of power. My advice, STAY AWAY FROM THE 4 CYLINDER TACOMA !
  2. Dec 11, 2013 at 9:17 AM
    Speck
    Speck Well-Known Member
    Tejas
    07 2.7 4x4
    Do you have a manual or automatic? The manual takes (or for me at least) some getting used to. I wouldn't want automatic with the 4 cyl. I have the added weight of 4x4 and a camper shell, and can still goose it pretty good if I need to. Most (99%+) of the time I'm just taking it easy though, staying well below 2500 rpm, and getting 21 mpg avg mixed driving. I don't think any of the 4x4 V6 get that.
  3. Dec 15, 2013 at 10:54 AM
    bsb120
    bsb120 [OP] Well-Known Member
    Bradley
    Easley, South Carolina
    2016 DCLB TRD SPORT
    God filled up and checked again and I'm back to 16
  4. Dec 15, 2013 at 10:58 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    If you're in a hurry, don't get the 4. I'm perfectly satisfied with it.
  5. Dec 15, 2013 at 11:05 AM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    What is the PSI in the tires?
  6. Dec 15, 2013 at 11:38 AM
    Rackster
    Rackster Well-Known Member
    Kevin
    Connecticut
    '04 E/cab 4x4 2.7 Auto SR5
    I agree with the advice above -
    • Drive light; no quick starts and keep a steady foot
    • Use synthetics; slicker and better when cold
    • Find routes to work, store, etc that optimizes your FE
    • Keep your truck tuned (how old are the plugs??)
    You also want to reduce the rolling weight; get rid of any clutter. And with the weather cooling down (cold here in NE), FE will suffer. Ethanol also takes a bite out of the MPGs. That said, you should be around 22 MPGs (or better) so you are off around 40%. If you aren't sure when the plugs were changed last, you might want to start there.
    Good luck!
  7. Feb 3, 2014 at 7:10 PM
    bsb120
    Bradley
    2016 DCLB TRD SPORT
    got an ultra gauge for Christmas and after around a month now all im showing is 18.5 I guess I just expect to much from the poor prerunner
  8. Feb 4, 2014 at 4:17 AM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2009 Prerunner TRD AccessCab
    New Navigation DVD/CD/TV/AV/Bluetooth Stereo and seat mod spacers, 1" hubcentric spacers, seat heaters....
    You may think you are being conservative with the right foot, one has to be uber conscious of the pedal pressure, I was able to vastly increase my MPG's by paying real close attention to my right foot and the instant MPG function of the Ultra Gauge....
  9. Feb 4, 2014 at 8:21 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Check your valve clearances. If they are way out, especially the exhaust valves, you should get them adjusted. Labor intensive, therefore costly. I just had mine done for $500 at a local garage. Purrs like a kitten now.
  10. Feb 4, 2014 at 2:39 PM
    bsb120
    Bradley
    2016 DCLB TRD SPORT
    how many ways can it be calibrated, I filled up and used the fill up option everytime. alo what size tank does the 2.7 prerunner have? I read that it has an 18 gal. but when im on empty and fill up it comes up to around 15
    my uncle owns a garage and he checked it with the computer and says everything it running absolutely perfect couldn't be no better
  11. Feb 4, 2014 at 3:25 PM
    Fordless
    Fordless Well-Known Member
    Jack
    Central Alabama
    2015 Tundra DC SR5+
  12. Feb 4, 2014 at 3:30 PM
    bsb120
    Bradley
    2016 DCLB TRD SPORT
    oh well I got a remote start to allow it to get warm, in the mornings
  13. Feb 5, 2014 at 6:10 AM
    Enid
    Enid Member
    Victor
    Oklahoma
    Grill guard
    I have read all and none apply. It was warm when I checked the MPG. It gets worse in cold weather for sure. Worse also on corn gas. I watch my RPM and do not let it idle to warm up. Bottom line, it does not get close to the MPG rating. It is a dog compared to the 6 cylinder and from what I am told gets the same or worse MPG. I saved a couple of grand on purchase price but that is all.
  14. Feb 5, 2014 at 12:55 PM
    Fordless
    Jack
    Central Alabama
    2015 Tundra DC SR5+
    I don't doubt that in the 2nd gen the EPA estimates are incorrect for the Prerunner 4cyls. Unfortunately the EPA estimates are based on the 5 lugs like mine. The estimates for my truck is right on. Unfortunately because the two trucks have identical powertrains and similar weights the EPA allows Toyota to use the EPA ratings for the 5 lug on both. In the first gen they had to test them both b/c the 5 lug used the 2.4L and the Prerunner used the 2.7L.
    Is it dirty? Yeah probably a little, but from what I have read Toyota is legally within their rights to do this.
    All I can tell you is if you want to get your EPA rated mileage you'll basically have to change the rear gears to 330s and put some smaller tires on it. But you would be best served by just putting up with the fuel economy or trading for a V-6.
  15. Feb 6, 2014 at 6:00 AM
    #35
    Enid
    Enid Member
    Victor
    Oklahoma
    Grill guard
    You can check anything you want to check and drive anyway you want to drive but I have not heard one person say that get anywhere close to the mpg on the sticker. I think it is time that Toyota changes the sticker or changes the set up on this model so future buyers get what they pay for.:mad:
  16. Feb 6, 2014 at 6:11 AM
    #36
    oldstick
    oldstick Medicare Member
    GA
    I think it is just trucks in general with their poor aerodynamics. I remember a lot of folks bought the old Toyota 4 bangers (before the days of Tacoma/Tundra) expecting to get good mileage and a lot were disappointed it wasn't that much better than a half ton pickup.
    If its paid off and running well, don't worry about it. Unless someone gave me a free hybrid it would take years and years and years to break back even over the purchase cost of a new vehicle.
  17. Feb 6, 2014 at 6:30 AM
    #37
    Fordless
    Jack
    Central Alabama
    2015 Tundra DC SR5+
    Obviously this isn't completely true because the new Dodge half ton ecodiesel was just rated at 28mpg highway by the EPA. So powertrain selection/technology has a lot to do with mileage. If Toyota would update the powertrain in the Tacoma to match the rest of it's lineup I suspect mileage would increase by 15-20%. By that I mean adding DVVT, Direct Injection, and transmissions with more gears.
    I think the Tsunami/Earthquake hurt Toyota more than anybody realizes. They're at least 5 years behind on most powertrains and on the Tacoma they're probably 10 years behind.
    A good example is the transmission that are behind all the 2tr-fe. It's the A343E which is an electronically controlled version of the A340 which was in use behind the Pre-tacoma V-6. Circa 1990! They were actually used as early as 1987 in some vehicles. They've proven to be extremely durable but not very fuel efficient b/c they only have 4 forward gears.
  18. Feb 6, 2014 at 1:50 PM
    #38
    Mr. Pick
    Mr. Pick Well-Known Member
    Middle TN
    '12 AC, SR5, 2.7L, Auto
    All of that outdated stuff is exactly why I love my Taco. Tried and true. Tested and de-bugged over the years. Both factory and aftermarket parts are plentiful and cheap. All of which is why the 2.7/auto is one of the longest lasting, generally trouble free vehicles you can buy. Just what the Dr. ordered for this old geezer! :D
  19. Feb 6, 2014 at 4:14 PM
    #39
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    Same here. :)
    The 5 speed in my 2012 is exactly the same model transmission that was in my 1996 Taco. Bulletproof.
    I'm a big fan of trailing edge technology. :thumbsup:
    Greg
  20. Feb 7, 2014 at 6:56 AM
    #40
    Enid
    Enid Member
    Victor
    Oklahoma
    Grill guard
    Power train would explain a lot. I had a 2013 Rav4 that ran great and got almost 30 mpg all the time. It had a 6 speed. My Toyota sales rep told me the Tacoma had the same engine and would run about the same. As it turns out the Tacoma has a larger engine but the gross weight difference of the vehicles was less than 500 pounds.
