EXTREMELY squirrely front end
Discussion in 'Technical Chat' started by BUFU, Jun 1, 2020.
  1. Jun 1, 2020 at 3:13 PM
    BUFU
    BUFU [OP] Member
    2005 White Tacoma
    265/75R16 Falken Wildpeak AT3W, Stealth Custom Series SR8, Fox 2.5 front, Fox 2.0 rear, JBA UCA
    Alright guys, just replaced front coilovers, UCA, tie rods, leaf pack and rear struts. After getting aligned my front end is an absolute mess, fighting the steering wheel going over small bumps on pavement. I lifted the truck about 2 inches and currently do not have a sway bar, however its not just simple body roll. The alignment guy had to max out one of my tie rods. What could possibly be the issue? Is it a steering rack issue? Lower control arm? Should I find a different alignment shop?
  2. Jun 1, 2020 at 3:15 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Start with a new alignment shop.
    69 Jim, Naveronski and EdgemanVA like this.
  3. Jun 1, 2020 at 3:16 PM
    gotoman1969
    Just outer tie rod ends?
  4. Jun 1, 2020 at 3:17 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Who's doing your alignments? If it's someplace like Firestone then I highly recommend going elsewhere, find a shop that specializes in alignments on customized vehicles. Places like Firestone only plug in factory alignment numbers into their machine and send you on your way. While the numbers might look good on paper they aren't necessarily what a lifted truck with aftermarket suspension needs
    If it's still wonky after a good alignment then go from there
  5. Jun 1, 2020 at 3:18 PM
    BUFU
    BUFU [OP] Member
    2005 White Tacoma
    Inner as well.
  6. Jun 1, 2020 at 3:19 PM
    BUFU
    BUFU [OP] Member
    2005 White Tacoma
    It was actually a shop recommended to me by an offroad shop in the area that just moved out of town. I'll make a couple calls around town and see what I can find.
  7. Jun 1, 2020 at 3:21 PM
    eon_blue
    Azusa, CA
    Hmm...did they give you a printout that you can post up here?
  8. Jun 1, 2020 at 3:23 PM
    JEEPNIK
    JEEPNIK Well-Known Member
    2020 Voodoo Blue TRD Sport
    That he had to "max out" any of the adjustments is a red flag. Who did the work you or a shop? If you did it take it to a shop and pay a few bucks for a diagnosis. Front ends aren't as simple as folks think. There is a lot of complicated geometry involved.
    Sprig likes this.
  9. Jun 1, 2020 at 4:09 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    This^. You need an experienced pro. You can mess with it for ever and still not have it right.
  10. Jun 1, 2020 at 4:35 PM
    BUFU
    BUFU [OP] Member
    2005 White Tacoma
    Unfortunately I was in a bit of a rush and forgot to ask
  11. Jun 1, 2020 at 8:20 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    few can align a truck front end correctly
    especially after lift
    big tyres
    etc
    in the dirt or back woodz it hardly makes a difference
    in this metro ( over 1 million) area there are ONLY 2Truck shops i would trust
    another a maybe..........none are $ wheel drive shops
    the ones i use can do 3/4 ton to 6-7 axle rigs
    U dont mention age / mileage
    always makes a difference
    good luck
  12. Jun 3, 2020 at 9:27 AM
    BUFU
    BUFU [OP] Member
    2005 White Tacoma
    Alright guys. Took it to the off-road shop in town and they are still have trouble getting it aligned. They are saying my tie rods might be wrong. I purchased the 555 inner tie rods from low range and some Moog tie rod ends from rock auto.
  13. Jun 3, 2020 at 9:33 AM
    gotoman1969
    Simple fix. Go to Toyota and get the OEM parts, they’ll be right. If they sell them the n pieces and not the entire rack as a whole.
  14. Jun 3, 2020 at 9:40 AM
    eon_blue
    Azusa, CA
    I have the same inners from Low Range, a lot of people on here do too. Inners I went with OEM though because they weren't that expensive (~$40 or so).
    The alignment shop should be able to tell you where the trouble is exactly. Who did the tie rod install?
  15. Jun 5, 2020 at 4:58 PM
    BUFU
    BUFU [OP] Member
    2005 White Tacoma
    Well, I got three alignments. One from a shop that was recommended by an offroad shop, one by an offroad shop and one by firestone. You know who was the only one who could get it? FIRESTONE. Interesting turn of events. Thank you all for you replies and ideas.
  16. Jun 8, 2020 at 8:31 AM
    ROAD DOG
    FEW
    a good tech makes ALL the difference
