extremly mad about TSB
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ClemsonTacoma, May 28, 2009.
  1. May 28, 2009 at 12:05 PM
    ClemsonTacoma
    ClemsonTacoma [OP] Well-Known Member
    Cam
    Lexington, SC
    Tacoma
    Pioneer DEH-P5100UB single din HU and black dash kit, Alpine 12" sub custom inverted box bed liner'd, various interior trim painted black, 48 blue LED domelight, cheepo floor mats, hose clamp mod, Cobra CB and knock off firestik, Stock steelie rims, with 265/75/16 Sumitomo HTR Sport A/T's
    i just got off the phone with Stokes Brown Toyota Hilton Head/Bluffton. i called about the suspension tsb and the man who i was talking to said he had heard of it a few times. then later on in the call he said he has never heard of it so i told him about this fourm. he seemed like he was going to accept it but i have to drop it off on monday and let them drive it around all day:mad: The stealership should be more knowgleble
  2. May 28, 2009 at 12:09 PM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    load the bed to capacity, so they can feal it hit the bumpstops, and record the mileage when you leave it so they cant say "we drove it all day" when they probably just pulled around the lot, and then wrote off the idea of helping you.
  3. May 28, 2009 at 12:10 PM
    ClemsonTacoma
    Cam
    Lexington, SC
    Tacoma
    how much b/c i dont have any money so i cant load anything in it
  4. May 28, 2009 at 12:11 PM
    ClemsonTacoma
    Cam
    Lexington, SC
    Tacoma
    EDIT: i told them it hapens when i put a dirt bike in it but sadly its my friends, and i do have the only 3 leaves
  5. May 28, 2009 at 12:12 PM
    ClemsonTacoma
    Cam
    Lexington, SC
    Tacoma
    should i take the weights off my weight set and drive around?
  6. May 28, 2009 at 12:17 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    Its funny, some people have a bitch of a time getting the TSB done, yet some(like me) have no issue whatsoever. I took the truck to the dealer, told them my rear end bottoms easily and told them I read of a TSB for it, they looked it up and said they'd order the parts and when was a good time to drop the truck off. That easy, no shit! doesnt make sense why some dealers would be so opposed to doing the job in this slow economy. Work is work.
    that could probably work.... how much weight total?
  7. May 28, 2009 at 12:17 PM
    ClemsonTacoma
    Cam
    Lexington, SC
    Tacoma
    note: i have 560 lbs of weights in my room
  8. May 28, 2009 at 12:19 PM
    ClemsonTacoma
    Cam
    Lexington, SC
    Tacoma
    the guy i was talking to sounded so suprised when i told him the suspension bottoms out...it even bottoms out unloaded if i drive over a speed bumb at 25 mph
  9. May 28, 2009 at 12:21 PM
    petersharp
    petersharp Well-Known Member
    Do you need to ask?! It's up there ^
    Louisville, CO
    Ex DC LB Sport owner.
    Go buy 1000 lbs of sand then take it back afterwards, as said up there ^^^
    If you can't afford that, you've got much bigger problems than the suspension on your truck.
  10. May 28, 2009 at 12:22 PM
    Veccster
    Veccster bass turds
    Eric
    Pittsburgh - The City of Champions
    2020 Pro
    560 should do it for sure. You can use logs, stumps, cement blocks...anything to add weight.
    I agree with Relentless...it is odd that some do it without question. My dealer needed to keep the truck for an hour so they could make sure there was no damage to my components. Once everything checked out, they called Toyota and verified my approval - ordered the parts and was done the next day.
    I would've fought like hell if they told me to LOAD MY TRUCK UP WITH A BUNCH OF WEIGHT TO VERIFY THAT I AM NOT LYING!
  11. May 28, 2009 at 12:33 PM
    RelentlessFab
    Eric
    Sparks, NV
    As for TSBs, I even had the creaking clutch pedal TSB done at my dealer even though my truck didnt technically fall within the affected VINs. They did check it out and found the cracked bushing though so that probably helped.
  12. May 28, 2009 at 12:38 PM
    07tacoark
    07tacoark Still kickin like a chicken!
    Red
    Fort Worth, TX
    07 4x4 SR5 & 19 TRD-OR 4x4
    Lots on 07 ... getting started on 19
    mine bottomed out with my 4wheeler in the back.
    if that ones a jack ass about the TSB take it to a different one and make sure they give u the bilstein shocks if u dont already have a TRD model
  13. May 28, 2009 at 12:43 PM
    ClemsonTacoma
    Cam
    Lexington, SC
    Tacoma
    ha no i have money i just owe my parents 600$ as said in my signature so i cant go spend like 100$
  14. May 28, 2009 at 12:44 PM
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    dont even do that. Just take a print out of the TSB in hand and show it to them and be like look this shows that there is a problem with my leaf pack so i want it replaced. Tell them its a harsh ride and they should replace it. The dealership i took mine to didnt drive it around or look at the bump stops or anything. i showed them the TSB and they said ok we will call you when the parts get in.
  15. May 28, 2009 at 12:45 PM
    ClemsonTacoma
    Cam
    Lexington, SC
    Tacoma
    oooh i like the way you think:spy: how would i go about getting the bilstein's
  16. May 28, 2009 at 12:49 PM
    07tacoark
    Red
    Fort Worth, TX
    when u get the TSB done, they put them on there. it actually states in the rear susp TSB that your truck model gets them on there. i looked mine over to make sure they didnt screw me over, counted the leaf springs and whatnots.
    so if/when u get this TSB done, u will have new bilstein shocks :D
  17. May 28, 2009 at 12:53 PM
    8th sin
    8th sin Swollen Member
    Tampa, FL
    2015 DCLB 4x4 Sport
    Llumar CTX Tint, Grillcraft MX Upper, Pro Comp Rockwell 5034 17x8.5, Nitto Terra Grappler G2 LT285/70/17, Icon Stage III
    After three trips to two dealers, hours of waiting, and 90 minutes on the phone with toyota's customer service people I was told that the TSB did not apply to my situation; despite the fact that it's emblazoned right on the TSB that it is to be applied when the customer complains of a harsh rear ride. I never loaded up with weight and took it to them, but to have to have to do that is ridiculous. I would think the dealers would jump at the opportunity to bill toyota for work and make a customer happy, but apparently not.
    I don't carry heavy loads, but I bought the truck to tow. Now my trucks out of warranty and I'm SOL. Guess I'll just have to lift and get some deaver rear leafs!
  18. May 28, 2009 at 12:56 PM
    BUK 0H5
    BUK 0H5 Still For Sale
    Queen Creek, AZ
    Silver 09 2.7L Manual AccessCab SR5 PreRunner
    Removed Mud Flaps, Suspension TSB, 5100's all around, JVC KW-AVX710 Head Unit with Metra surround.
    Bilsteins are part of the TSB package if you do not already have a TRD. I think she was just saying to double check that they actually put them on after the TSB instead of leaving the stock shocks.
    Edit: Damn she beat me to the punch ^^^
  19. May 28, 2009 at 12:58 PM
    neontrail
    neontrail ✈ ✈ ✈ ✈ ✈ ✈ ✈
    Idaho
    2004 NISSAN XTERRA XE/SE
    De-badged, Tint 20%, Blue 48 LED dome-light, .......
  20. May 28, 2009 at 12:59 PM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    make sure they do the alignment as well...
