F@#%@#g abs almost killed me
Discussion in '2nd Gen. Tacomas (2005-2015)' started by anotherreject, Mar 25, 2013.
  1. Mar 25, 2013 at 10:44 AM
    Skunkman
    Skunkman Well-Known Member
    Syracuse - Tug Hill
    2007 Tacoma Access Cab ,
    My ABS is downright dangerous in the snow and ice also, kicks in way too soon and leaves me with no brake control.
  2. Mar 25, 2013 at 10:45 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    It'd be cool if someone figured out how to make it less sensitive.
  3. Mar 25, 2013 at 10:49 AM
    Gregman
    Gregman Well-Known Member
    Freddy Beach, NB
    05 DC LB 4x4 SR5
    I would like to instal an ABS off switch but I'm afraid that might get me into a world of trouble with insurance if I was ever in an accident.
  4. Mar 25, 2013 at 10:57 AM
    VanCity4x
    VanCity4x Well-Known Member
    AB
    05 Tacoma
    3link on tons
    Had same problem, cost me 2k. Wet roads, person in front slasmmed on brakes, to avoid a yellow light no less :mad:
    Abs kicked in and i slowly rolled into into them. No damage to the taco, probably would have been less with theirs if it wasnt a shit box pontiac, whole rear caved in.
  5. Mar 25, 2013 at 2:19 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Same here.
  6. Mar 25, 2013 at 4:17 PM
    Country101
    Country101 Well-Known Member
    NW Arkansas
    08 tacoma access cab V6 4x4 manual
    dirty truck mod, custom trailer scratch on tailgate, husky floorliners, OME Lift
    Yep, it's about killed me several times. Dont hit a reflector on the center line while turning either.
  7. Mar 25, 2013 at 4:22 PM
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    Indeed. It seems that bumps set the ABS off terribly. The few times on wet pavement have been on rippled pavement at busy intersections.
  8. Mar 25, 2013 at 4:24 PM
    EatMyTacomaDust
    EatMyTacomaDust Well-Known Member
    2014 "Black Beauty" Baja DC 4x4
    ICON 3" LIFT, Console Vault, Tailgate Security Clamp MOD, SuperBumper Crash Attenuator, TRD Front Skid Plate, Wet Okoles - 1/2 Piped, Undercover SE Tonneau
    Don't brake in snow & ice - use engine compression to slow down then gently brake at the end while you are going so slow it's not going to matter.
  9. Mar 25, 2013 at 4:34 PM
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90,'97,'12,'05 Tundra 4.7,'07 T4R 4.7,'08 T4R 4.7
    Really? 1/2 inch of slush, the ABS kicks in at 10 mph and you can't stop? I call BS on this.
  10. Mar 25, 2013 at 4:35 PM
    14U2NV
    14U2NV Active Member
    Socttsdale
    '12 SR5 4x4
    ABS is designed to allow the driver to steer and change direction under braking conditions. If your wheels are locked up you will not be able to steer around potential hazards. ABS was NOT designed to make you stop faster.
    I lived a bulk of my life in the snow belt. The Tacoma may have very sensitive ABS system, but I have had several vehicles kick on ABS while on snow and the system will never let you come to a stop until it finally detects a surface with more traction or you hit something.
    If you spend a lot of time in snow and ice conditions, the best thing you can do is get dedicated snow tires. They are designed to provide increased traction in extreme cold, snow and ice conditions. As a general rule, all-terrain tires make horrible snow tires.
  11. Mar 25, 2013 at 4:44 PM
    monkeyface
    Colorado
    1/2 inch of slush at 10 mph my ass. Don't make me laugh. Load of BS.
    I don't know what this constant meme is with the ABS. I live in Colorado, had to brake plenty times in snow and ice, and it works just fine for me. I feel some sliding, I pop the clutch in and brake down just fine.
  12. Mar 25, 2013 at 5:06 PM
    CorrosiveTendency
    CorrosiveTendency When up to your nose in shit, keep your mouth shut
    Nathan S.
    Schuylkill Co, Pa
    05' DblCab SB Speedway Blue
    OME 885's, Locker Mod. Bilstein 5100's on 4 corners
    Maybe it's just a stiffer suspension on so many of our trucks. Which makes the bumps, so prevalent on our wonderfully maintained roads (PA: memories last a lifetime, alignments 25 miles), feel a lot worse and cause a wheel hop. The wheel hop, while on the brakes will momentarily stop the wheel, causing the ABS to kick in. I have experience it on dry pavement approaching a stop sign. I hit an expansion joint, the ABS sensed that the wheel stopped and 'Whirrrrrrrrrrrrrrrr' Kept on rolling. Just hammer that pedal to the floor. It is one of the strongest parts on any vehicle.
  13. Mar 25, 2013 at 5:10 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    THIS.
    ABS mod illegal = No (in the US). However, I can see someone using it against you in a civil case.
    Personally, I wouldn't disable ABS on any vehicle, including the ones I owned the 29 years I lived in NJ, but that's just me,
  14. Mar 25, 2013 at 5:10 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    This thread strikes me as funny because generally I've seen these threads going the opposite way. "Oh you just don't know how to drive!"
    You're right though, ABS blows in these trucks!
  15. Mar 25, 2013 at 5:16 PM
    #35
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
  16. Mar 25, 2013 at 5:20 PM
    #36
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    I'm not going to blame the drivers neither the trucks. The ABS has been fine, unless it literally is broken.. give ABS something to work with! TRACTION, ABS cant work for you w/o it.
    You don't have to buy a winter tire like blizzaks , maybe get an ASR, AT or MT with severe weather rating, then air down just a bit in winter. Suddenly you never remember ABS until you hear it a thread. This doesn't mean you will stop, just like summer, but they sure help.
  17. Mar 25, 2013 at 5:30 PM
    #37
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    I don't know what I'm doing differently from the rest of you but I've never had an abs issue. It really makes me wonder if its the tires you guys have, I've got ms2's ... Maybe a lack of tire traction adds to the touchy abs? I'm not blaming anybody but I really don't understand this.
  18. Mar 25, 2013 at 5:30 PM
    #38
    Alaskan toy
    Alaskan toy Stormtrooper Corps
    Anchorage, AK
    2010 Arctic Edition (TRD Off-Road)
    Tonneau, Shackle Hitch, Auto Start, OEM Seat Covers, Color Matched Interior Accents
    Interesting...
    ABS pumps the brakes for you faster than a human could manually, though a human can stop quicker if you know how much pressure to apply just before the tires lockup and activate the ABS.
    Driving around town, I haven't had ABS activate for any reason. The only time it has kicked on is on a hill by my home that is always pure ice and everyone has issues with it.
    Maybe I'm just lucky and got the one truck with functioning ABS.
  19. Mar 25, 2013 at 5:32 PM
    #39
    EatMyTacomaDust
    I haven't had any ABS issues either [knock on wood] - and I have crappy dunlops - even though there really not that crappy - they've been good so far in the rain and snow. . . just not killer tires.
  20. Mar 25, 2013 at 5:34 PM
    #40
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Wait for it
