F#&K!!!! just stripped a bolt head!
Discussion in '1st Gen. Tacomas (1995-2004)' started by MapleMoose, Oct 1, 2011.
  1. Oct 1, 2011 at 4:54 PM
    MapleMoose
    MapleMoose [OP] Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    As you can see i was installing my 5125's on my 96 Tacoma and the one bolt head broke off! Any ideas?
    Top rear strut mount
    And how am i suppose to fit the bushing on that??
  2. Oct 1, 2011 at 5:05 PM
    acidfly
    acidfly Well-Known Member
    Kevin
    Kitsap, Wa
    Toytec 3" lift, 4.88 gears, ARB locker, Elite front/rear bumper with sliders, Fully LineXed, Custom bedrack
    Throw a die on it, not a big deal. I dont remember is it welded in? If not replace it.
  3. Oct 1, 2011 at 5:07 PM
    Monkeysuncle
    Monkeysuncle My Cat's breath Smells like Cat Food
    Kevin
    Florida
    99 Tacoma SR5 4x4 5 speed Manual Hubs
    Diff Breather,CB thingy,GPS,Cop Shocks,Cop Breaks, old Man Emu 881's Dakar Leaf Springs and Nitro sport shocks. Deck Plate mod
    How much heat did you subject that too?
  4. Oct 1, 2011 at 5:08 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    Die? what do you mean? Do you mean tap it out?
    And yes it is welded
    No heat, just muscle.
  5. Oct 1, 2011 at 5:12 PM
    RAT PRODUCTS
    RAT PRODUCTS Raw Strength Equipment
    Farmington, MN
    Cummins Coal Rollin SOB
    Smokin with a smarty.
    Should have used heat, not muscle.
  6. Oct 1, 2011 at 5:15 PM
    acidfly
    Kevin
    Kitsap, Wa
    Dir is the opposite of a tap, it'll rethread the bolt. You might beable to salvage it, even if its just good enough you can throw 2 nuts on it, wont go nowhere
  7. Oct 1, 2011 at 5:23 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    The rest of the bolt is inside the mount. Only the head turned which resulted in breaking. My only thought is to either drill it out or somehow thread the rest of the bolt out.
  8. Oct 1, 2011 at 5:24 PM
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    from the looks of it you snapped the bolt off. time to get creative with a welder and some steel rod
  9. Oct 1, 2011 at 5:26 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    Yeah, i guess i could just weld a bolt next to it and use it to mount the shocks
  10. Oct 1, 2011 at 5:38 PM
    acidfly
    Kevin
    Kitsap, Wa
    Oh it broke... thought it just stripped. Yeah id cut the remander off then drill out and throw a tap into it. New bolt with Loctite or Copatite. The hard part is to drill it centered and straight, try to get a bit just small enough to not drill the inside threads id use 3 bit sizes for the process, when you get to where you get to the point where the hole is thin on the old bolt at that point you can pick out the old bolt metal saving the thread.
    Im pretty shitty at explaining things, let me know if you want me to explain better
  11. Oct 1, 2011 at 5:40 PM
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
  12. Oct 1, 2011 at 5:50 PM
    acidfly
    Kevin
    Kitsap, Wa
    Dont use those, they will never remove a bolt like that, likely it"ll break then he'll have temped steel break it apart. Id recommend the square type. Dont mean to shit on your suggestion, i just believe that style it crap
    edit, if you do go this route kroil it up over night
  13. Oct 1, 2011 at 6:08 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    Thanks.
    Yeah just realized that i didnt strip it, but broke off the head.
  14. Oct 1, 2011 at 7:24 PM
    fidencio74
    fidencio74 Well-Known Member
    Fidencio
    Escondido, CA.
    04 Tacoma DC PreRunner 2WD
    Magnaflow Catback System, King Coilovers, Total Chaos UCAs, Rear 5100, Deaver J59, Greasable shackles, rear steel braided brake hose, Timbren Rear Suspension Enhancement Kit, Kenwood DDX318 HU, JL Audio XD700/5 Amp, Infinity 6830Cs Front, Polk Audio DXi 570 Rear,Pioneer TS-SW2501S4 10" Sub/ Custom enclosure behind the rear seat.
    cut a line through the middle of the screw with the dremel and use a flat screw driver to take it out. it should be really easy. don't worry about cutting the mount, you will be fine.
  15. Oct 1, 2011 at 7:34 PM
    KenLyns
    Belly of the Beast
    Square type? You mean like these?
    $26 Alden 4507P Micro Grabit Broken Bolt Extractor 4 Piece Kithttp://www.amazon.com/Alden-4507P-Grabit-Broken-Extractor/dp/B000Q60UOO
    Does seem easier to use.
  16. Oct 1, 2011 at 8:15 PM
    acidfly
    Kevin
    Kitsap, Wa
  17. Oct 1, 2011 at 8:25 PM
    acidfly
    Kevin
    Kitsap, Wa
  18. Oct 1, 2011 at 8:57 PM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    if you can get a nut on the end that snapped off, thread it on then tack weld it on there because it doesn't look like you have enough threads to get two nut on there. use some penetrating oil on the end that goes to the frame and let it sit over night. try to remove it in the morning.
  19. Oct 1, 2011 at 10:34 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    So i cut the bolt mount off and im now in the process of trying to take the rest of the bolt out or making a new mount and taping it. Then i can weld the mount back on.
  20. Oct 1, 2011 at 11:15 PM
    acidfly
    Kevin
    Kitsap, Wa
    No he snapped the bolt while trying to remove the nut.
