F**ked up with 1G3 Touch-Up Paint
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jamestcurran, Sep 10, 2025 at 10:24 PM.
  1. Sep 10, 2025 at 10:24 PM
    jamestcurran
    jamestcurran [OP] Well-Known Member
    I have a 2013 TRD Sport Magnetic Grey and I managed to bump a corner of the roof taking a box off the roof-rack. It took three chips of paint off, each a little smaller than a penny, probably about half the size of a penny.
    I swung by my local Toyota dealer and picked up some Toyota Touch Up Paint, in 1G3 (code taken from the door jam).
    It doesn't match ...
    It's a shade or two too light and completely lacks the depth of the original paint. Anyone else hit this issue - any suggestions on how to "fix" it?
  2. Sep 10, 2025 at 10:24 PM
    jamestcurran
    I realize that :worthless:but it's dark out - so I'll add photos in the morning.
    usmc2msu and eherlihy like this.
  3. Sep 10, 2025 at 10:30 PM
    MGMDesertTaco
    Dogota likes this.
  4. Sep 10, 2025 at 10:43 PM
    jamestcurran
    Thanks! Will give it a try.
  5. Sep 11, 2025 at 4:30 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    The problem with touching up any metallic paint when using a touch up bottle is getting it to match. If you don't shake the paint really, really well, you have absolutely no hope of a match. On top of that, you're using single stage lacquer to touch up basecoat / clearcoat original equipment paint. And the bigger the area you're trying to touch up, the worse the problem gets. Touch up bottles are really made just for very small chips.
    I'd propose that for the size of the areas you're trying to touch up, nothing but a professional shop is going to get even close. Sorry.
  6. Sep 11, 2025 at 5:22 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    When I inquired about having some bodywork done at the local body shop, the owner showed me the PPG book on paint. There’s something like 11 different shades of Magnetic Gray Metallic. It’s noticeable when you compare the shades to each other.
  7. Sep 11, 2025 at 6:33 AM
    Too Stroked
    Tom
    The only shade he has to worry about is the one shown on the paint code on the door jamb tag.
  8. Sep 11, 2025 at 7:04 AM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    In the PPG book, they’re all listed as 1G3 paint code.
  9. Sep 11, 2025 at 7:08 AM
    slater
    slater Well-Known Member
    San Diego
    24 white Tacoma TRD Sport 2wd
    Reality check here....
    If its anything other than white, it will NEVER match....
    Especially metallic silvers, grey, etc....
    jamestcurran[OP] likes this.
  10. Sep 11, 2025 at 7:37 AM
    Dogota
    Dogota 2015 DCLB
    Mark
    Seattle, WA
    I use Dr Colorchip on a couple of my vehicles and like the product. (My friends say Dr Colorchip is easier to use than the similar product "Langka" Color Blob.)
    But, results really depend on the size, depth, age, and characteristics of the damage, as well as the surrounding paint condition. It helps hide alot, but it doesn't perform miracles.
  11. Sep 11, 2025 at 10:51 AM
    jamestcurran
    Thanks folks. Yeah, the door jam says 1G3 but as you say, it seems to cover a pretty broad spectrum.
    I had head that the Dupli-Color Perfect Match was good so picked up a can, but also found it to be too light.
    I really don't need it perfect, just need it not to be an eye sore. Some people point to the color match improving with coats, but, yeah, the clear-coat seems to be an important step.
  12. Sep 11, 2025 at 12:24 PM
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    Take it to a professional and let them do it
  13. Sep 11, 2025 at 2:51 PM
    Fish Taco 4x4
    Fish Taco 4x4 Well-Known Member
    NC
    2013 TRD OR
    I used the Toyota 1G3 pen to fill in a medium sized gash on the roof from the PO that was starting to rust and it came out absolutely terrible. The color pen did do an ok job on small rock chips but I found that the Toyota clear coat in the pen actually made the repair spots more noticeable and turned them into a silver shade. Definitely wouldn’t recommend the pen for filling in anything larger than small chips.
  14. Sep 11, 2025 at 3:32 PM
    ThatguyJZ
    ThatguyJZ Instagram: thatguyjz
    Jim
    TRIAD, NC
    2014 MGM DCSB 4x4 TRD Off Road
    A TRD OR built into a Baja/PRO hybrid
    Well I have a much older bottle of Toyota touch up paint. Same color as you. It seems to match fairly close. I always use a separate paint brush, depending on the size of repair.
    You can fill the area with enough coats that it's slightly raised, then carefully come in and wetsand it down to level it. Then follow with some compound on a buffer and it should blend better and be less obvious
  15. Sep 11, 2025 at 3:51 PM
    Shotgun Clay
    Shotgun Clay Well-Known Member
    My wife scraped the maroon metallic paint on hr hyundai. I bought a kit from Paint Scratch. You can’t tell it’s been touched up until you get close enough to see my lousy brush work.
  16. Sep 11, 2025 at 5:55 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    You aren’t fixing a chip that’s half the size of a penny with any touch up paint. There are ways to do it diy but it will be time consuming. Post up some pics of the chips.
    steveo27 likes this.
  17. Sep 11, 2025 at 7:45 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    Paint touch ups should be judged by the "10 foot rule". Meaning, if you can't tell it's there from 10 feet away then you did well.
  18. Sep 12, 2025 at 3:14 AM
    jamestcurran
    Amen!
  19. Sep 12, 2025 at 5:32 AM
    slater
    San Diego
    a tip that is key to success, taught to me by my bodyshop techs at work...
    Dap the paint into the damage using multiple thin applications.
    Even if the application is on the heavier side, it will shrink down once it dries & you will need more..
    Dont ever brush it on when applying, regardless how big the scratch or damage is, thats what makes it look like shit most of the time.
  20. Sep 12, 2025 at 5:49 AM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Automotive Touchup has the best color match of all the paint colors from what I have seen.
    However, silver is a PITA an any metalflake makes it even worse.
    I had a front bumper cover recently repaired [idiot backed into me] and repainted and they did a FANTASTIC job color matching 9 year old silver flake. I was so amazed that I actually asked to speak to the painter, shook his hand, and congratulated him on a great paint match and spray. [laid it on so the paint flop matched the rest of the car paint.]
    That is a sign of a great painter.
    However, you will never get a metallic touch up paint flop close, it's just the way it is. [using a brush] Most touch up paints are way to thick in the first place and they get worse every time you open them up.
