F/S 130A alternator
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by rctoy, Jul 12, 2012.
Thread Status:
Not open for further replies.
  1. Jul 12, 2012 at 6:59 AM
    rctoy
    rctoy [OP] It's about to get real!!!
    konstantenos
    Pocatello Idaho
    First gen 4door monster in progress
    TRD super charger, URD fuel mods and 2.1 super grip pully, Headers, 2.5" glass pack, Dana 60 front 4 linked, 14bolt rears on chev 63's, 5.38 gears, ARB locker in the front, PSC full hydraulic steering, 18" SAW 2.5" triple rate coils overs, FOA 2.5 air bumps, B&M launch controls, B&M trans cooler, 4 alpine 6X8 type R's amped, Red led rock lights, CBI front and rear bumpers (my design) CBI sliders, 4 riggid dualys front 2 in the rear, custom track bar, ARB snorkle, warn VR8000 winch, Viair 480c twin compressers..
    Just like it says i had a local shop that specializes in rebuilding elcetrical parts take my factory alternator and turn it up to 130A but that still wont cut it. so im looking for a bigger one. Im $150 into this one and it's only got 5,000 miles on it. i was thinking $100 and shipping costs and it's yours.
  2. Jul 12, 2012 at 9:49 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    hmmmm...
    so it truely outputs 130a?
  3. Jul 13, 2012 at 3:21 PM
    rctoy
    konstantenos
    Pocatello Idaho
    At 1800rpm it puts out over 130 blew my 150 amp fuse. that's y i want bigger. Lexus is where it at but it's gonna be pricy.
    Would not recomend if you do alot of low rmp stuff cuz hi amp alternators dont perform at idle
  4. Jul 13, 2012 at 4:34 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    The alternator will only make 130 amps under load when needed not because it can if you blew a 150 amp fuse you got problems. The tow package alt is 130 amps mine does not blow fuses even charging the twin camper batteries and the one in the truck. Stick a Ford cop car alternator on it if you want amps it will do 280 amps and it will cost you close to 10HP to run it full load.
  5. Jul 14, 2012 at 11:01 AM
    rctoy
    konstantenos
    Pocatello Idaho
    I do have problems like i was using more than 150 amps and the alterator put out enough amps to blow the ever living shit outa that fuse. So point being goood alternator, no problem. second Lexus is a toy brand and i would not basterdize my truck with some ford garbage id rather spend some money and stay toyota. Side note SAS's don't count if toyota made one tones id stick toy but they don't, and at least my axle's will be made my Dana not ford.
  6. Jul 14, 2012 at 11:11 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    PM a moderator when you have pics to post. They must be pics of the actual item, and not a manufacture stock photo, or a pic belonging to someone else.
Thread Status:
