F/S Icon extended travel coilovers NIB
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by n0rth, Mar 17, 2012.
  1. Mar 17, 2012 at 9:28 AM
    n0rth
    n0rth [OP] Well-Known Member
    J.W.
    Idaho
    09 Tacoma 4X4 SR5
    2009 Tacoma Access Cab SR5, 4wd, 2.7L URD S/C, 4:88's ARB lockers, 36x9.8r16 Radial TSL
    SOLD...
    I bought these planning to make the switch but have since changed my mind and am going to stick with my OME set-up.
    These are new in the box and include a spanner wrench 1000.00$ shipped. 100$ cheaper than DSM or Metal Tech and includes a spanner.
    ICON Vehicle Dynamics
    '05-'11 Toyota Tacoma 6 Lug
    0"-2.5" Replacement Extended Travel
    Coilover Shocks
    ICON 5-8635-
    Spanner Wrench for ICON
    ICON 19-8000
  2. Mar 17, 2012 at 10:12 AM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    These will out perform OME like night and day! Might as well put them on and try them out? GLWS
  3. Mar 17, 2012 at 10:23 AM
    n0rth
    J.W.
    Idaho
    09 Tacoma 4X4 SR5
    For sure these will outperform my OME's, it's a matter of spring rates and the Icons are to lightly sprung for what I want. Thanks for the bump.
  4. Mar 17, 2012 at 11:10 AM
    Rakso
    Rakso CeRaTi
    OsKaR
    California
    09 PreRunner SR5
    King RR w/adjusters, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    Sick deal. Glws
    I payed like $1200 for the same coils with no spanner
  5. Mar 17, 2012 at 11:37 AM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    Cool......sick build man, your trucks a beast!
  6. Mar 17, 2012 at 12:15 PM
    Taqoma
    Taqoma Well-Known Member
    Brennan
    Los Angeles
    2011 TRD Off-Road
    TRD Supercharger, TRD CAI, Camburg LT, Fox 2.5x8 coilovers, Fox 2.0 bumps, Deaver e30 leafs, Fox 3.0x18 triples, Avid sliders, Yaesu 2900R, Pro Comp 7089 16x8, DDM 55w HID Hella 500FF, DDM 35w HID headlights, Magnaflow 11255 muffler, PLX DM-100 OBDII, Autometer Ultra-Lite II Boost gauge, Flex Pod gauge mount, LSK tube bumper, McNeil fenders, Fiberwerx bedsides, 285/75/16 Toyo MT's
    how you could have a pair of CO's just chillin in your hands and NOT put them on!!!???
    you sir have great self control ;)
  7. Mar 17, 2012 at 5:57 PM
    HuntnTruk
    HuntnTruk Tacohead
    Kevin
    New York-not the City
    Indigo SR5 4x4
    WWWHHHYYY????? I just dropped some cash on a Shoei helmet. These would be much cooler. I need to sleep on this one.
  8. Mar 17, 2012 at 10:44 PM
    Silvertacomao6
    Silvertacomao6 Well-Known Member
    Ogdensburg,Ny
    06 TRD DC relatively factory
    I have a few stupid questions so here goes.
    I have a 2006 DCLB and had a base model Fabtech 6" lift. Have Mickey T's 315/75/r17's on. Front scrubs but I am aware of cutting body mount for clearance (they scrub). These coil overs are extended travel, so are they in between stock and Long travel? Just bought icon add a leaf for rears to eliminate the rear sag.
    Will this lift my truck some more( hope so)? Also stock rear shocks on now. What will compliment these shocks on rear from icon? Also can or should I use stock uca's with these or new lower control arms or do I need new ones?
    The long and short is I want a smoother ride and more travel and height. Should I go with Long travel kit. Also will the add a leaf help the ride because it rides like a lumber wagon now?
    Any advice would be appreciated from you or anyone.
    This info will help me decide if I want these as well.
    Regards
  9. Mar 18, 2012 at 1:26 AM
    RenoTacoma
    RenoTacoma Petrol head
    Sloan
    Reno, nevada
    09 Base 4x4 Tacoma
    3.5" lift 285/70/17
    Shoei ftw, best helmet out there.
  10. Mar 18, 2012 at 2:34 AM
    toytaco11
    toytaco11 Well-Known Member
    Albuquerque
    11 TRD 4x4 lwb doublecab
    coming soon!
    these will only work if the truck already has some sort of lift correct?
  11. Mar 18, 2012 at 3:33 AM
    BulletToothTony
    BulletToothTony Im only a dick 90% of the time
    You can call me Susan if it makes you happy.
    ^^^^ No they replace the stock shock assembly and then you can adjust them to your liking...
  12. Mar 18, 2012 at 9:28 AM
    anethema
    anethema Well-Known Member
    J
    Dawson Creek,BC
    08 TRD OR Access cab 4x4
    ARB Bumper,OEM Roof rack modded for access cab, Allpro Rock Sliders,Icon Adjustable coilovers,More Tie Downs in bed, Firestone Airbags in rear,Block heater
    You will also need a good uniball UCA or you will wreck your stock one.
  13. Mar 18, 2012 at 9:37 AM
    Silvertacomao6
    Ogdensburg,Ny
    Thanks for the info guys. Very helpful. I will be doing some trail riding but not any severe trails or BAJA dune jumping,so am I correct in saying these are a happy medium between stock TRD and a long travel kit?
    Regards
  14. Mar 18, 2012 at 9:54 AM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    If you have a fabtech lift you'll need a specific coilovers made for the 6" lifts. These are to replace for stoch height up to 3" and allow for extra down travel so a uniball uca is needed or the stock ones will break!
  15. Mar 18, 2012 at 10:07 AM
    Keatstaco20
    Keatstaco20 Well-Known Member
    Keaton
    California
    08 access cab debadged lifted
    Fox resi coilivers, rear fox piggys, allpro u bolt flip kit, allpro 3 leaf add a leaf, bhlm, 6000k hid, noyka 2500 yellow fog, black grill/emblem, custom trd decals, magnaflow exhaust, k&n cai, alpine deck plus 12in jl audio 12w3
    These are a great upgrade over stock through some total chaos uppers on and ride into the sunset lol tc has great customer service from what I hear
  16. Mar 18, 2012 at 10:09 AM
    Taqoma
    Brennan
    Los Angeles
    2011 TRD Off-Road
    I can't believe these haven't sold yet.... I would buy them if I wasn't prospecting another user's Icons....
  17. Mar 18, 2012 at 10:17 AM
    SAIRS
    SAIRS Well-Known Member
    Kelly
    Utah
    Super White 2012 Double Cab LB TRD SPORT
    Icon Extended Travel Stage 1, Total Chaos UCA's, Dakkar leaf pack, Beefed DCLB Sliders with extended kickout and custom BSP, Beefed Custom exo-rear tube bumper, Toyota bed mat, tailgate theft mod. Front mudflaps removed, Access LE soft tonneau cover, Weathertech digital floor mat, Weathertech window deflectors, Weathertech license plate frames. future plans = diamond plate tailgate mod, Venture Shield, TRD supercharger...the dream goes on and on....
    Are these just the front coilovers or are the rears included too?
  18. Mar 18, 2012 at 10:21 AM
    Taqoma
    Brennan
    Los Angeles
    2011 TRD Off-Road
    looks like just the front CO's and spanner. if this was for CO's and rear shocks for 1000$ they would've sold before the page could refresh ;)
  19. Mar 18, 2012 at 10:49 AM
    Taqoma
    Brennan
    Los Angeles
    2011 TRD Off-Road
    ahhh!! don't tempt me!!
  20. Mar 18, 2012 at 1:15 PM
    n0rth
    J.W.
    Idaho
    09 Tacoma 4X4 SR5
    Just think, I could ship them tomorrow.......
