[F/S] ICON S2 SECONDARY 2.5 VS RR SHOCKS & TOTAL CHAOS SHOCK HOOP SET [F/S]
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by RAD, Sep 29, 2020.
  1. Sep 29, 2020 at 8:04 AM
    RAD
    RAD [OP] Well-Known Member Vendor
    Rad
    LAX & LOGAN
    I'm selling a set of Icon Dynamic S2 2.5 VS RR secondary shocks & Total Chaos Fabrication standard dual series shock hoops. This set-up is intended for the factory stock length only. The Icon S2 shocks were rebuilt with new seals and oil. I'm including a pair of brand new Icon shock hose as well. They have absolutely no miles on them and they're ready for a new home. There is no pitting on the lower shafts as I ran a black boot cover for protection. There is normal wear as you'd expect from a used set. The Total Chaos dual shock hoops come as seen with the top mount grade 8 screws. There isn't any other hardware include with the shock hoops as you'll need a fabricator to weld them on. The hoops are in great condition but could use some new paint.
    Location 91436 of Southern California
    Price $1,050 FOR THE TOTAL SET
    [ICON DYNAMICS S2 2.5 VS RR SECONDARY SHOCK DETAILS]
    SOLD
    OVERVIEW
    ICON Vehicle Specific (V.S.) 2.5 Series shocks are designed and built to give your vehicle outstanding performance off-road and a smooth ride on the street. These shocks are configured specifically for each application in both length and damping tune. Like all ICON'S Shock Absorbers, V.S. 2.5 Series shocks are 100% rebuildable and 100% revalveable. For piggyback and specific remote reservoir applications, ICON'S unique use of a 6061 billet aluminum manifold a few inches below the top cap of the shock creates an internal Bump Zone that when used creates an additional 20% of damping force. This additional force helps prevent harsh bottom outs and controls the suspension when compressing at high velocity. If you are looking for a more user defined tune, consider looking into the Compression Damping Control Valve (CDCV) or the Omega Series bypass shocks.
    FEATURES & BENEFITS
    • Premium grade 5WT shock oil for consistent suspension damping along a wide temperature range​
    • CAD plated, precision machined 1026 DOM steel shock body for maximum durability and corrosion resistance​
    • Remote reservoir design improves heat dissipation to reduce shock fade during prolonged use​
    • 6061 aircraft grade aluminum CNC machined components​
    • ICON’s internal “Bump Zone” increases damping by 20% to provide more control as the shock approaches full compression​
    • PTFE lined spherical bearings and application specific mounting hardware​
    • 7/8” diameter induction hardened, chrome plated shock shaft​
    • All ICON 2.5 Series Piggyback and Remote Reservoir shocks can be upgraded to ICON’s Compression Damping Control Valve (CDCV)​
    • One piece digressive piston design with vehicle specific valving for unsurpassed performance and ride quality on and off-road​
    • 100% Revalveable​
    • Nitrogen charged monotube design with remote reservoir​
    • 100% Rebuildable​
    [​IMG][​IMG][​IMG][​IMG]
    [​IMG] [​IMG]
    [TOTAL CHAOS FABRICATION SHOCK HOOPS STANDARD SERIES DETAILS]
    DUAL SHOCK HOOPS - STANDARD SERIES LCA
    2ND GEN TOYOTA TACOMA 2005-2015
    PART# 86612
    PRICE $802.50
    Description:​
    • Maximize vehicle dampening control when you install a dual 2.5" shock mount system.​
    • 4130 prebent chromoly shock hoops are designed to install secondary 2.5" piggy back or bypass shocks.​
    • Reinforces the factory coil bucket and helps reduce flex. Lower profile design keeps the hoop from contacting the inner fender well.​
    • Flush mount top plate allows hoop to be used with shocks that use bolts or studs on upper mount.​
    • Upper shock tabs are tacked in place to aid in secondary shock location set up.​
    • Flush mount top plate eliminates the need to trim the inner fender well for rear bolt installation.​
    • This kit is designed to be installed with the TC 86500 Standard boxed lower control arms.​
    • Lower shock mounting clevis and bump stop relocation brackets are included.​
    • Grade 8 hardware included.​
    • Does NOT work with factory lower control arms.​
    [​IMG] [​IMG] [​IMG]
  2. Oct 1, 2020 at 11:55 AM
    RAD
    Rad
    LAX & LOGAN
    These will give you some street cred.
    Island Cruiser likes this.
  3. Nov 23, 2020 at 10:26 AM
    RAD
    Rad
    LAX & LOGAN
    SOLD
