F5 -38 offset on stock Sport
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoBoTRD, Nov 3, 2018.
  1. Nov 3, 2018 at 4:30 PM
    TacoBoTRD
    TacoBoTRD [OP] Member
    2018 TRD Sport 4x4
    New member here! Excited about my 2018 Taco! I’m pulling trigger on new wheels this week. I love the Ray10 but out of stock. Next option is the F5 17x9 3.50” BS. My understanding is this is a -38 offset. I’m on stock suspension and leaning towards the Nitto Ridge Grapplers 265/70R17. Like most I want the biggest tire/wheel combo with minimal rubbing. Will this set up work? Other solutions? Thank you in advance.
  2. Nov 3, 2018 at 4:40 PM
    airsickbuffa1o
    airsickbuffa1o Well-Known Member
    Anthony
    2017 Silver TRD OR
    OVtuned 1.03
    That's a pretty extreme offset, you should expect some rubbing. My -10 offset stealth 6s rub on the mudflap and there isn't a ton of clearance when turning with 265/70/16s
  3. Nov 3, 2018 at 4:44 PM
    TacoBoTRD
    2018 TRD Sport 4x4
    I was afraid of that. I’m going to pull the mud flaps off. It’s been very difficult to find a wheel with a -12 or -10 offset that doesn’t look played out.
  4. Nov 3, 2018 at 4:47 PM
    airsickbuffa1o
    Anthony
    2017 Silver TRD OR
    OVtuned 1.03
    Well, you may need to do more to fit -38s. There is a user on here that has the F5 on 265/70/17 tires with no lift that I believe had to cut the cab mount to keep from rubbing. I would avoid anything over -10 offset on a stock suspension unless you want to do trimming.
  5. Nov 3, 2018 at 5:46 PM
    ToyCrawl
    ToyCrawl Active Member
    2018 OR.DBC.SB.4x4
    SCS F5 matte black 285/75/16 Nitto Ridge Grappler 5100 set to 0 with OME 887 and Icon tubular UCA front 5100 with 1” block rear Roadwire leather interior Color keyed rear bumper Side marker light tint Mirror turn signal tint Pro grill Black exhaust
    You’re going to rub like your getting a deep tissue massage with that offset and no lift.
  6. Nov 4, 2018 at 4:12 AM
    TacoBoTRD
    2018 TRD Sport 4x4
    I’m going to head a different direction. Now to find a less offset wheel. Thank you!
