F_ _ _ _ N TPMS Light?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MTLTaco, May 5, 2011.
  1. May 5, 2011 at 11:47 AM
    MTLTaco
    MTLTaco [OP] Well-Known Member
    Montreal
    09 Double Cab TRD
    Light came on this morning when I started the truck. I haven't checked the tire pressure yet but all 4 don't look low at all. I know I don't have a sensor in the spare. Any idea why the light would be on? Thanks guys
  2. May 5, 2011 at 12:14 PM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    Mine has triggered off the spare but you having an 09 are not suppose to have one in there. Maybe you do in CA? You have to drop the spare to find out. I would check your pressure & reset the system per the owner's manual. If that doesn't lose the light, drop the spare "just in case" you did end up with one there. Next it could be a bad sensor. Here is a helpful link
    http://www.toyotatpms.com/
  3. May 5, 2011 at 12:17 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah if you havent checked them then you need too. I know mine would come on even if it was 2-3 pounds off. Make sure after you check and refill them to the proper pressure to hit the reset button under the bottom of the steering wheel under the dash board.
  4. May 5, 2011 at 12:18 PM
    himmie
    himmie No.
    Sarah
    AZ-WI
    08 TRD Off Road 4x4
    Yes.
    I'm currently dealing with a TPMS light that will not go away. All of the tires appeared fine but when checked they were: 38, 33, 35, 35 and the spare was N/A. So, apparently the spare is dead and two of the tires are more than 3 psi different from each other. That's enough to set it off.
  5. May 5, 2011 at 12:50 PM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    Are you sure about that? it's common to set a front/rear pressure bias to help control over-steer. The bias could be as as much as 5 lbs, but that's pretty rare.
    If true, that is just another form of suckage being visited upon the motoring public!
  6. May 5, 2011 at 12:52 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Thats why 05-07 rocks, dont like TPMS? unplug the stupid thing and be done with it :D
  7. May 5, 2011 at 12:59 PM
    JdMeF9SiR2
    JdMeF9SiR2 FN Wheels
    Corona, CA
    05 Tundra 06 Tacoma 14 FJ Cruiser 19 Tundra
  8. May 5, 2011 at 5:48 PM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    Been living with a TPMS light for a year now. Destroyed the valve stem on one of the sensors on a rock. Not worth it to me to buy new ones and paying to have them programmed.
  9. May 5, 2011 at 6:00 PM
    travelingman
    travelingman What would Scooby do?
    Brian
    Ohio
    07lb4x4DC
    ticking eng.mo,ventvisors,locking tailgate,wheelmasters ss spare tire inflation line,weathertech mats
    The light's on because you need to check your tire pressure.
  10. May 5, 2011 at 6:00 PM
    bama trd
    bama trd Well-Known Member
    Alabama
    2007 Silver Tacoma TRD Off Road
    Painted Grill with painted Land Cruiser emblem,Tinted Windows, BF Goodrich AT 275/70/17's on 4 Runner SR5 Rims, Bilstein 5100 front and Rear, debadged, fog light on anytime mod,
    I disabled my TPMS light
  11. May 5, 2011 at 6:02 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    IIRC, the 05's didnt have TPMS at all:rolleyes:
  12. May 6, 2011 at 4:42 AM
    buddywh1
    Philly PA
    07 DC SR5 4x4
    not on 07's up... if you unplug the tpms ecu the light stays on all the time. i think that only works on 06's but if anyone has done it on 07's and KNOWS it works, and how to find the tpms ecu, inquiring minds want to know!
    a couple of of my wheel sensors corroded after winter and the other day when checking pressure, a core didn't spring back. it's not worth the 300 dollars for two sensors and reprogram so i took all four off the road wheels and put it them in a pressurized PVC pipe.
    but one sensor (at least) is reporting it's defective, the light flashes and won't take a set. only thing left (since I don't believe the ecu unplug trick works) is put tape on the light...
  13. May 6, 2011 at 4:57 AM
    bama trd
    Alabama
    I've disabled the light on two 2008 Tacomas , did a quick right up with a few pics - if you search" Disabled TPMS on my 2008" , you'll see it , Good luck if you choose this route
  14. May 6, 2011 at 5:21 AM
    buddywh1
    Philly PA
    07 DC SR5 4x4
    Yah! found it! so pulling the blue wire high turns the light out... I wonder if putting a 1K current limit resistor instead of the fuse link would work still? that way I know there's no chance of burning out the gate that wants only 5 volts.
    The current will be limited to just a few mA so its safe if the wire should contact ground... no need for the fuse link!
    Don't know which is harder or riskier... this mod or the tape on light trick! Maybe this one's safer since I'm not messing with the instrument cluster... hmmm
  15. May 6, 2011 at 6:38 AM
    BlueT
    NorthEast
    If your sensors are broken I would disconnect the whole thing and forget about it. If you want to put resistor that should work too.
    That TPMS is crap anyway, too bad they don't give you choice when you buying truck. I would ask them to remove it and give me $1000 back :rolleyes:
    I thought 09+ TPMS is tied to VSC so disconnecting it will make VSC Gods angry.
  16. May 6, 2011 at 6:42 AM
    The_Hodge
    SC
    not sure, but i dont see why it would be. two different systems for two different uses.
  17. May 6, 2011 at 6:55 AM
    Biff
    Biff What could go wrong?
    Winnipeg
    07 SR5 Doublecab
    Bilstein 5100's all around, fronts set to 1.75, 18" Method Race Wheels, 285/60/18 Cooper Zeon LTZ
    Couldn't you just pull the LED bulb out of the dash that lights up the TPMS?
  18. May 6, 2011 at 9:48 AM
    coolreed
    coolreed Well-Known Member
    Reed
    OKC
    2019 Toyota Tacoma TRD Pro
    Goodyear Wrangler Dura Track Pro Tires, K&N Cold Air Intake, Pedal Commander.
    1. Be sure all your tires are inflated properly and identically.
    2. Reset your TPMS monitoring circuit by pressing the reset button under the dash by the steering wheel. You must hold the button for a few seconds. This will reset the monitoring circuit to the current air pressure.
    If that does not solve your problem you may have a bad sensor.
  19. May 6, 2011 at 10:43 AM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    What pressure is considered to be low by the TPMS system?
  20. May 6, 2011 at 11:04 AM
    BlueT
    NorthEast
    mine kicks in at 28.9 psi
