Fab-tech or Ranchos
Discussion in 'Suspension' started by feliciap117, Dec 6, 2013.
  1. Dec 6, 2013 at 8:55 AM
    feliciap117
    feliciap117 [OP] New Member
    Felicia
    05 crew cab, TRD off-road package.
    3 inch lift, 17 inch wheels, flowmaster 40 series, and cold-air intake.
    I have an 05 Tacoma and am wanting to get a whole new suspension. I can't decide between the Fab-tech setup or the rancho setup. I want a smooth ride but not a "marshmallow suspension." What do you recommend to put on it? Thanks!
  2. Dec 6, 2013 at 9:08 AM
    Downsouth Motorsports
    Downsouth Motorsports Downsouth Motorsport Vendor
    Lakeside, Ca. 92040
    2017 4-Runner Dirt King Long Travel King 2.5 Coil-Over / 2.5 Bypass Front and Rear ICON Rear Upper and Lower Arms ICON Rear 2" Springs 34" x 10.50" x 17 Toyo Tires on 17" x 9" RaceLine Wheels
    I would recommend you look into the RCD kit.
    Most drop down bracket kits are very similar other than the shocks. In the case of rancho and fabtech, you are basically getting the same shock, they are a generic valved Monroe shock.
    With a RCD kit you are getting a specifically valved Bilstein shock, giving you a better ride and more control.
    Micah
