Fabrication on the 2nd gen?
Discussion in 'Garage / Workshop' started by Erll, May 17, 2011.
  1. May 17, 2011 at 5:56 PM
    Erll
    Erll [OP] Well-Known Member
    My Name is Erll
    Des Moines, Iowa
    Speedway Blue
    Check my sig
    I am looking advise on a decent TIG welder for my garage. It needs to be AC/DC. Lets hear what you folks use and what your recommendations are. I have 60a of 220 in the garage so that is my power limit. I am really looking forward to doing some of my own fab for my 09 DCSB
  2. May 17, 2011 at 10:35 PM
    Tepidy
    Tepidy Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    you should consider a miller mig welder the 211 is great it can be used either on 110 or 220
  3. May 18, 2011 at 6:51 AM
    viperstd
    viperstd Tacoma convert
    Maryland
    09 4x4 TRD SR5 DC LB
    AllPro Front and Rear trail armor & full skid plates, Demello Hybrid Rock Crushers, Old Man Emu suspension, Warn 8000# winch, PIAA SMR fogs, perforated + heated leather seats, in-dash DVD/NAV/Sound, RE subs
    Not trying to give you a hard time, but if you are asking what TIG welder to buy here, me thinks you might not know how to TIG. Are you a welder or just looking to learn at home and then start fabbing?
    I believe the Everlast Power TIG 200 might be a good fit for you. I haven't used the unit, but the videos I've seen of it makes it look like it burns well/stable. I recommend watching small TIG reviews on youtube.
    Goodluck.
  4. May 18, 2011 at 8:29 AM
    disk_55FL
    disk_55FL Well-Known Member
    disk
    Buckeye
    '17 TRD Sport MT
    He's probably wanting to be able to weld Aluminum....that why he mentioned AC....I'm assuming... :confused: And the DC for the steel / Stainless.
    OP....I'd stay with a big brand name if you plan on keeping it for a number of years.
    You'll be able to get spare parts and service in the future if necessary.
    Make sure whatever AC unit you get ...it should have High Frequency ( for the Aluminum ) also if you plan on doing much Aluminum....get a water cooled torch.....if you have good tap water ( City source ) you may not need a water cooler for the torch.
    Some of the small 250 amp. torches are eacy to handle and some of the parts are interchangeable for the big brand names ....TEC and Weldcraft I believe.
    Keep use posted.
  5. May 18, 2011 at 8:52 AM
    viperstd
    Maryland
    Some good advice above, though, I do think that the Everlast brand is coming in strong and they use Siemans IGBTs.
  6. May 18, 2011 at 9:21 AM
    Erll
    My Name is Erll
    Des Moines, Iowa
    Speedway Blue
    Check my sig
    I am just beginning to learn. My buddy who is a tank welder recommended I start with tig since its the most flexible.
  7. May 18, 2011 at 9:39 AM
    viperstd
    Maryland
    If you are going to only buy one machine, I say buy a TIG too. It isn't nearly as easy to setup or use as a MIG, but it can weld almost anything from something as thin as a soda can all the way up to .2" per pass. I also find TIG welding the most enjoyable. It is like gas welding without feeling like you are standing in a furnace after an hour :D. TIGs also stick weld.
    A combination TIG/Plasma unit is also a good option.
  8. May 19, 2011 at 3:46 AM
    disk_55FL
    disk
    Buckeye
    '17 TRD Sport MT
    If you're not an experienced welder....TIG can be a challenge. If you have trouble walking and chewing gum at the same time you may have problems. Most of the time you'll need both hands ...torch in one , filler in the other and controlling the amperage with your foot ( optional amp control on torch - slide switch - but these can creat other issues ) .
    MIG is easier ....but can get you in trouble on thicker metals ( think trailer hitches ) if you don't know what you're looking for.
    TIG is slow .....MIG much faster. The hobby MIG welder ( machine ) probably won't be welding Aluminum.
    TIG is very versatile ....DC has no max limit on thickness that can be welded ( think
    Nuclear industry ) and as mentioned very thin materials. AC ( Aluminum / Magnesium ) is diferent ( the puddle doesn't turn red in color ...so it takes some getting used to ) and thicker sections may require some preheat depending on your machine.
  9. May 19, 2011 at 4:07 AM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    If you have the fundamentals of oxy fuel welding tig should come easy for you.
    I learned how to tig on a miller Synchrowave 250 dx and a Lincoln powermig 350.
    I would recommend gettin the powermig 350, it's a good all around welder. It can mig, tig, and stick weld.
    You can also do aluminum mig on this machine with the right gun. But not aluminum tig.
  10. May 19, 2011 at 7:04 AM
    Erll
    My Name is Erll
    Des Moines, Iowa
    Speedway Blue
    Check my sig
    I ended up ordering the everlast 225lx for 1000. Delivered
  11. May 19, 2011 at 8:54 AM
    viperstd
    Maryland
    Congrats on the new purchase! Keep us posted and get us some pictures and videos of you burning a nice stack of dimes.
  12. May 19, 2011 at 10:08 AM
    Erll
    My Name is Erll
    Des Moines, Iowa
    Speedway Blue
    Check my sig
    Will do.
  13. May 22, 2011 at 2:37 PM
    Erll
    My Name is Erll
    Des Moines, Iowa
    Speedway Blue
    Check my sig
    should be delivered thurs, i will do an unboxing with pics
  14. May 27, 2011 at 7:25 PM
    Erll
    My Name is Erll
    Des Moines, Iowa
    Speedway Blue
    Check my sig
    Got it. I will post up some pics tomorrow.
  15. May 27, 2011 at 7:28 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Love to see me some fabrication! :popcorn:
  16. May 28, 2011 at 6:41 AM
    Erll
    My Name is Erll
    Des Moines, Iowa
    Speedway Blue
    Check my sig
    will probably start with a front receiver hitch. seems easy enough.
  17. May 28, 2011 at 3:24 PM
    viperstd
    Maryland
    Nice. Let us know how the unit works out.
  18. Jun 5, 2011 at 6:02 AM
    Erll
    My Name is Erll
    Des Moines, Iowa
    Speedway Blue
    Check my sig
    OK so we finally got everything hooked up yesterday and it worked very well. Tig on AC was great and TIG on DCEN also worked fantastic. The arc was so smooth and controlled.
    My buddy was working with me on Stick , but I have a hell of a time getting the arc started. Rods kept sticking.
    I only got a little UV burns on my arms and a nice slag burn on my left hand from a piece that fell into my glove, but all is good for now. I will post pics today.
  19. Jun 5, 2011 at 12:52 PM
    littledvl
    littledvl ride BMX!
    Eric
    Saint Leonard MD
    08 taco dc 4x4 / 15 tundra dc 4x4
    Too many to list
    Good to hear on the tig!
    What kinda stick were you using? When I first learned I used 6010 mainly, it made clean welds, very little slag, very easy to use and learn how to control. Now I keep 6011 and 7018 rods on most jobs I goto, I can usually get the job done with those.
    Would also be a good investment to get a decent leather jacket.:cool:
  20. Jun 5, 2011 at 3:10 PM
    Erll
    My Name is Erll
    Des Moines, Iowa
    Speedway Blue
    Check my sig
    I was working with 7018. Stick is dirty and hot compared to tig. Not really sure why I would do it unless I was out of argon
    This is from that piece of slag that fell into my glove !
