Fabtech 3" Coilover lift (help)
Discussion in '1st Gen. Tacomas (1995-2004)' started by Rstandridge, Apr 9, 2010.
  1. Apr 9, 2010 at 12:15 PM
    Rstandridge
    Rstandridge [OP] Member
    Rich
    Citrus County
    1999 Tacoma SR5 4x4
    I have just recently bought set of dirt logic coilovers for my 99 tacoma and it says on the instructions not to go over 2 inches. I was looking for 3 inches to clear 33x10.5 R15's. Is this because of my Cv joints? How do i get the full 3 inches without damage. Also what is recommended to match the rear to fit the same tires. This is all new to me so any help would be great!
  2. Apr 9, 2010 at 1:38 PM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    yeah, it's because of your cv's. basically, crank them down to the point where you still have an acceptable cv angle and call it a day. might have to down grade in tire size. you'll want something like a 1.5" AAL out back to level the truck with 2" and some change up front
  3. Apr 9, 2010 at 3:18 PM
    quattrokiwi
    quattrokiwi Well-Known Member
    Bruce
    Nor Cal
    04 Tacoma, Limited, TRD, Locked, Geared, 4x4
    I have the fabtech coilovers and am no where near 3" of lift, and fit in 33s, actually 285/75/16, but they are 33s.
    I'll measure my lifted truck compared to my stock one tonight and let you know how much I actually have.
  4. Apr 9, 2010 at 5:39 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    just get a diff drop kit, and then you can get your 3" lift. The diff drop lowers your diff. about 1" and helps with your cv joints.
  5. Apr 9, 2010 at 8:44 PM
    Rstandridge
    Rich
    Citrus County
    1999 Tacoma SR5 4x4
    What diff. drop kit is good? Also do I need to get some new shocks for the rear to lift it higher? Thanks alot by the way.
  6. Apr 9, 2010 at 8:46 PM
    Rstandridge
    Rich
    Citrus County
    1999 Tacoma SR5 4x4
    I will be anxiously waiting, much appreciated!! What did you do to the rear to even yours out to the front?
  7. Apr 9, 2010 at 10:23 PM
    ETaco23
    Evan
    PNW
    go to toytec, there a vendor here. And they have everything you will need. The diff. drop, and AAL's and shocks.
    2" AAL's (add a leaf) will lift your rear level with your front, and you will also need new rear shocks. The bilstein 5100's are awsome!
  8. Apr 10, 2010 at 7:58 AM
    quattrokiwi
    Bruce
    Nor Cal
    So this is measured from centre of hub to the edge of the wheel flare/fender. I have 2.25" lift with the fabtech. No rubbing issues. But i did have to bend over the pinch weld.
    In the back is a one inch block (truck came like this) and is sagging, so it will soon to be dakars in the rear giving about 2" of lift
  9. Apr 10, 2010 at 8:00 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    It only lowers the front of the diff 1". That equatees to about .5" drop at the axels, and given the length of the axels, only comes out to about a 2* change....If that. The Diff drop is not worth it. In some cases, it has made things worse.
  10. Apr 10, 2010 at 8:19 AM
    quattrokiwi
    Bruce
    Nor Cal
    I should have noted that also, I don't have a diff drop kit. Never saw the point as Chris says.
  11. Apr 10, 2010 at 12:22 PM
    Rstandridge
    Rich
    Citrus County
    1999 Tacoma SR5 4x4
    Thanks alot guys! I am now looking at the 2" AAL and blistein 5100 shocks for the rear. Do you guys recommend to convert the auto to the manul locking hub for full 3" on the front. If so would the 2" in the rear match the front? I think i am saying it right anyways?
  12. Apr 16, 2010 at 11:47 AM
    steveneddy
    steveneddy Member
    steven
    arkansas
    04 tacoma 4x4
    Just a few, 3" suspension, 3" body, billet grille, smoke headlights and corners , herculiner bed liner, double chrome rollbar with 4 kc's, diamond plate tool box,and latest edition 17" wheels wrapped in 35-12.50-17 bfg mt km2's
    another thing you might wanna look at is a rough country lift they aren't the most plush riding but i think i paid about 165 on ebay the spacers for front are actually only 1.5 " but that spacing and added compression gives 3" there aluminum so they dont squash over time have had on for two years kit comes with add a leafs for rear still a little higher in the back, kit comes with the little one inch spacers for front diff and longer bolts for instillation, with a medium offset 9" wide wheel i was able to run 285's , sure this lift isn't for everyone but two years no broken axles have noticed putting cv axle at more angle is causing wear in a circle around the boot but no leaks or tears yet
  13. Apr 16, 2010 at 12:13 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    If we're talking about the Cepek Rough Country, you can have it. It was /is the biggest piece of shit lift around, & I mean that goes all the way back to their developement days & inception right here in El Cajon,CA. Dick Cepek was a mediocre offroad racer at best, I think he co-piloted with Parnelli Jones one time on the Baja 1000, but Jones declined to invite him back ,was quoted as saying that "He slows me down." So Cepek joined Armstrong rubber developement or some shit & came up with the tire thing first ( GOOD IDEA ) then the suspension & lift kits ( HORRIBLE IDEA ) You guys think Toyota has shitty leaf springs, the Cepek design/build was all about making it look like you could go "Robby Gordon" with ease at any moment , when in reality, one good weekend of easy 4 wheeling was more than enough to flatten out the leaf packs front & rear & completely blow any seals you had in those cheap shitty Monroe shocks they'd buy off the shelf, drain'em & refill with a heavier ,inferior hydraulic fluid & sell them as re-engineered valve bodys & shafts, absolute Bullshit ( No gas shocks in those days guys)
    I almost went to work for them doing installs back in the early 80's, but a friend of mine talked me out of it saying " Look man, you don't want people to think that YOUR responsible for the crap you're installing on their trucks." & more I thought about it , the more sense it made...
    Thats all I got to say about Cepek Products, from past experience, I'm not a fan.....:eek::eek::cool:
  14. Apr 16, 2010 at 7:17 PM
    ETaco23
    Evan
    PNW
    Wow.... didnt know that! New wrinkle! :) But it has to make somewhat of a difference, I would think.
  15. Apr 16, 2010 at 8:03 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    In many cases, It makes vibes worse.
  16. Apr 17, 2010 at 7:06 PM
    tacomamonster
    tacomamonster New Member
    01tacoma 4cyl
    all pro front and rear bumpers, 8500 winch, 285/75/r16 nitto terra with moto metal 951 black,hid conversian on headlights, x2 100watt fog lights
    i got three inches in the front and two in the back and can fit 285/75/16 with minimal rub at full flex no diff drop everthing work great no just gota get rid of the open diff in front and back with air lockers next buy i should be all set. just wish i didnt have a 4cyl but its all good.
  17. Apr 17, 2010 at 10:38 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Can you give some more detail on that?
    What was the situation where things got worse? Were new vibes introduced by adding the diff drop kit or were there already vibes and adding the 1" drop made them worse?
    Was it on a 1st gen or 2nd gen truck?
    Thanks for the feedback.
  18. Apr 18, 2010 at 6:46 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Most of the issues I have heard, have been on the second gens. The first gens dont seem to have front end vibes when lifting.
  19. Apr 18, 2010 at 9:48 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Good information. Thanks.
    Unfortunately, I did get some vibs from lifting. That is why I was curious about the dif drop kit.
  20. Apr 21, 2010 at 8:00 PM
    Rstandridge
    Rich
    Citrus County
    1999 Tacoma SR5 4x4
    Got everthing in and the install will be this weekend hopefully! Thanks to all for the advice and help. Great forum!!!!
