fabtech conversion to long travel
Discussion in 'Long Travel Suspension' started by 7tac0ma7, Jul 8, 2010.
  1. Jul 8, 2010 at 2:58 PM
    7tac0ma7
    7tac0ma7 [OP] Member
    Spencer
    humboldt
    99 Tacoma 6" lift/fiberglass fenders
    6" fabtech lift, king coilovers, 5125 rear bilsteins, 2.5" skyjacker softride leaf springs, 33x12.50 toyo mt's, 15x10 ion alloy powdercoat wheels, downey fiberglass front end, k&n air filter, flowmaster dual exhaust, factory e-locker
    I have a 99 tacoma with a 6" fabtech lift and am wanting to convert to long travel suspension. Would I be able to buy a kit that works with my current suspension?
  2. Jul 8, 2010 at 3:09 PM
    stroM-
    stroM- @alteregoadventure
    Santa Rosa, California
    2006 4X4 TRD OR
    no, Long travel is a totally different way to run suspension. You will have to loose your drop bracket lift.
  3. Jul 8, 2010 at 3:12 PM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    someone just posted the same shit
  4. Jul 8, 2010 at 3:15 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    Execpt this guy actually has a 6" and is trying to go LT.
  5. Jul 8, 2010 at 3:15 PM
    borderbrat
    borderbrat Watching Chris4x4 o.O
    Jeremy
    Victoria BC, Canada
    2012 DCLB, STOCK..But not for long
    (old truck 2008 AC ....PIAA fogs, led "puddle" lights, bed lights, in cab 115V, Toyota Devil emblem, Randy Ellis light bar with LED light bar, OME 885 and Dakar leaf springs OME shock all round, 2.5 Gal OBA system with air horns, iPod adapter, scangauge on blend mount, magnaflow catback, bike fork mounts, tinted 2009 tails.)
    doubtful unless you want it to be even higher and one couldn't guarantee it would work or be reliable if it did. your best bet is to lose the drop bracket lift. Of course the piece of the front crossmember that was cut out will need to be welded back in. Then the whole new LT kit installed.
  6. Jul 8, 2010 at 3:22 PM
    amaes
    amaes Cuz Stock Sucks
    Alex
    Chandler, AZ
    2011 FJ Built
    ICON Stage 6, RCI Skids, Blacked out
    Ok so you are able to mount a TC Long Travel Kit to your truck with the 6" on but.... Its one of the dumbest ideas out there. I have a TC kit and my truck leans like crazy around turns and with a 6" lift you are just asking to roll over. Long travel trucks are low 3" of lift tops because your center of gravity is lower and better for high speeds. also normally those 6" kits aren't really meant to take that kind of beating. You best bet is to take of the 6" and replace the cross member then add the Long Travel kit. or just keep the 6".
