FABTECH DIRT LOGIC SHOCK ADJUSTMENT
Discussion in 'New Members' started by YOTAGIRL7, Aug 13, 2011.
  1. Aug 13, 2011 at 8:38 AM
    YOTAGIRL7
    YOTAGIRL7 [OP] Member
    DOES ANYONE KNOW HOW TO ADJUST DIRT LOGIC SHOCKS ON AN '06 TACOMA? CANT FIND IT ANYWHERE ONLINE.
  2. Aug 13, 2011 at 8:41 AM
    yotamikez
    yotamikez Street glide or die
    Valrico
    04 civic & 08 Street glide
    MAYBE A PICTURE WOULD HELP. BUT IF ITS LIKE ANY OTHER COIL OVER IT SHOULD USE A SPANNER WRENCH. Right?
  3. Aug 13, 2011 at 8:44 AM
    RAT PRODUCTS
    RAT PRODUCTS Raw Strength Equipment
    Farmington, MN
    Cummins Coal Rollin SOB
    Smokin with a smarty.
    ^^Dude might not like female species.
    If you want to adjust them because the ride is stiff, you would have to revalve them. If you want to adjust the height, spanner wrench.
  4. Aug 13, 2011 at 8:48 AM
    yotamikez
    Valrico
    Didn't notice she was a female.... BUT I DID NOTICE THE CAPS LOCK WHICH SEEMS LIKE SHE IS YELLING...
  5. Aug 13, 2011 at 10:13 AM
    yotamikez
    Valrico
    :eek: yay
  6. Aug 14, 2011 at 6:42 AM
    YOTAGIRL7
    Haha sorry caps lock was on... not yelling. Thanks for the info.
  7. Aug 14, 2011 at 6:49 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    MAKE SURE YOU JACK THE TRUCK UP OFF THE GROUND WHEN ADJUSTING THEM IT WILL MAKE IT MUCH EASIER
  8. Aug 14, 2011 at 7:09 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    do you want to change the stiffness of the shock??
    or do you want to change the ride height?
  9. Aug 14, 2011 at 7:27 AM
    yotamikez
    Valrico
    So did you get your issue resolved?
  10. Aug 16, 2011 at 9:09 AM
    YOTAGIRL7
    havent had time to mess with it yet. do i need a special spanner wrench or can i get it at an auto parts store?
  11. Aug 16, 2011 at 9:10 AM
    YOTAGIRL7
    eric- looking to adjust the stiffness of the shock.
  12. Aug 16, 2011 at 12:03 PM
    YOTAGIRL7
    i just found the spanner wrench on 4wheelonline.com thanks guys.
    i dont think they need to be rebuilt theyve only got about 4,000 miles on them.. maybe im wrong?
  13. Aug 16, 2011 at 12:16 PM
    RAT PRODUCTS
    Farmington, MN
    To adjust the stiffness you need to revalve, nothing to do with a spanner wrench. The spanner will lower the shock, which might cause tire rub issues depending on the lift height and tire size.
  14. Aug 16, 2011 at 12:29 PM
    YOTAGIRL7
    ok thanks. i have 33x12.50-18s on now and they are rubbing, so maybe i need to get the spanner wrench to raise the shock?
  15. Aug 16, 2011 at 1:46 PM
    RAT PRODUCTS
    Farmington, MN
    It is possible as long as you are not maxed out on the rest of the suspension geometry. Is it 4 wheel drive? Pics of everything up front would help. Also raising the shock will probably make the ride even stiffer.
