Fabtech, ProComp 6" lift or more. Pictures
Discussion in 'Suspension' started by toku58, Jul 2, 2009.
  1. May 3, 2012 at 2:38 PM
    #3481
    COMAtose HI
    COMAtose HI Well-Known Member
    2012 TRD SPORT 4x4
    6" Procomp Stage 1 Suspension Lift, Custom 6" Alcan Springs, N-Fab Side Steps, Husky Floor Liners, Wet Okole Seat Covers, Debadged, Weathertech Side Window Deflectors, 13" Antenna from AntennaX.com, 35% Tint for front windows, Procomp 7032 Series 18x9 wheels, 33x12.50 Nitto Mud Grappler tires
    nice!!! lol i need to get some wheel spacers so my tires stick that far out in real life.
  2. May 3, 2012 at 3:03 PM
    #3482
    pa blaster
    pa blaster Well-Known Member
    Scott
    central pa
    2024 GMC Canyon AT4X AEV
    cops round here would stop ya in a heartbeat for that
  3. May 3, 2012 at 3:08 PM
    #3483
    pa blaster
    Scott
    central pa
    anybody :spy: my shed i got this last load to put in then i gotta sell sell sell :laugh:
  4. May 3, 2012 at 3:14 PM
    #3484
    Oregon TRD
    Oregon TRD "GO DUCKS" Edition
    Ross
    Steel Panthers bathroom floor!
    2005 Mall Krawler
    6" Fabtech Lift, 35" Fierce M/T 17" Eagle Alloy Sim bead locks Naked girls in the bed 10.1" DVD head unit Two 7" Headrest Monitors PS2 in glove box
    I tried making Mud Grapplers.....about as close as I could get.
  5. May 3, 2012 at 3:16 PM
    #3485
    COMAtose HI
    2012 TRD SPORT 4x4
    yea you will have trouble passing a safety check inspection in hawaii with tires sticking too far out of the fender. i think it makes the truck look so much nicer!!!
  6. May 3, 2012 at 3:16 PM
    #3486
    COMAtose HI
    2012 TRD SPORT 4x4
    thats sick!!!! looks good man
  7. May 3, 2012 at 3:17 PM
    #3487
    COMAtose HI
    2012 TRD SPORT 4x4
    how's my avatar?
  8. May 3, 2012 at 3:23 PM
    #3488
    Oregon TRD
    Ross
    2005 Mall Krawler
    :headbang:
  9. May 3, 2012 at 3:30 PM
    #3489
    COMAtose HI
    2012 TRD SPORT 4x4
    just called alcan springs...my leaf packs just shipped and should be here in 3 days!!!! :woot:
  10. May 3, 2012 at 3:31 PM
    #3490
    Oregon TRD
    Ross
    2005 Mall Krawler
    AMEN BRUTHA!!!! :D
  11. May 3, 2012 at 4:05 PM
    #3491
    joshua721
    joshua721 Well-Known Member
    16 f150 xlt v6
    So now im sitting on a pile of parts and getting everyone together next saturday to put them all on. any suggestions/tips from any one that did there own lift?
    im thinking of spraying everything down a couple days in advance with some breakfree/liquid wrench.
    any odd size sockets or tools ill need? doing the fabtech with coilovers and alcans so no blocks if that helps.
  12. May 3, 2012 at 4:17 PM
    #3492
    Oregon TRD
    Ross
    2005 Mall Krawler
    LOL - Black headlight mod....:D
  13. May 3, 2012 at 5:31 PM
    #3493
    Manwithoutaplan
    ID
    Little Mini Meet at Golden Coral Today.... Look at that 6 inch Brappness to the right :D
  14. May 3, 2012 at 5:38 PM
    #3494
    Manwithoutaplan
    ID
    here is the list
    Need
    14mm
    17mm
    19mm
    20mm(maybe)
    21mm (maybe if you have aftermarket wheels you need this size for the gorilla key.)
    22mm(maybe)
    24mm (maybe)
    IF you have a torch that would make easier than a sawzall.
    sawzall
    Grinder
    blocks of wood
    bugge Cords
    jack/jack stands
    Ball Joint Separator for the uca ball joint and Rack and pinion ball joint.
    Impact wrench
    Torq Wrench
    You might have to take off the Brake dust cover because mine was making a grinding noise. But you could try to re bend it. Make sure you got to Alignment Shop right way.
    Would not be a bad idea to spray it with Liquid Wrench.
    My lift with the pro comp coils took day and half. At the time i did my pro comp i had buddy help me because i had no idea what i was doing.
    THe direction for pro comp were pretty good i am guessing their the same for fabtech.
    You adding UCA's or No???
  15. May 3, 2012 at 5:50 PM
    #3495
    joshua721
    16 f150 xlt v6
    no UCA's at this point not sure if they are needed, i dont plan on offroading much this is my daily driver work truck, it was time for tires so i figured f it im lifting it. Using a friends shop with a lift so i wont be on the ground working on it and having a few friends help im hoping to knock it out in one day.
    everything on the list makes sense but the bungee cords.
  16. May 3, 2012 at 5:53 PM
    #3496
    Manwithoutaplan
    ID
    Bungee cords would be for the brake Calipers so their not hanging on the Brake lines.
    Well putting on a lift you should knock it out in day. The Back part should be alot easier than the front. Because you have to cut the cross member.
  17. May 3, 2012 at 6:00 PM
    #3497
    joshua721
    16 f150 xlt v6
    should i do the cab mount chop or wait to see how bad it rubs? im mounting a set of cooper discover at3 315/70/17 abit over 34 inchs
  18. May 3, 2012 at 6:18 PM
    #3498
    pa blaster
    Scott
    central pa
    chop it i just did after about a month of bitchen about the rubbing
  19. May 3, 2012 at 6:22 PM
    #3499
    Manwithoutaplan
    ID
    yes i would do it i was rubbing pretty bad on the driver side cab mount. You also might have to hammer down the vertical pinch weld. I was hitting that bad. If you can find a local welder they charge like 100 bucks.
    I am running 315/70/17 on 17x8 inch rims
  20. May 3, 2012 at 6:50 PM
    #3500
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    That's weird I have 35x13.3's and can't hit the body mount if I try?
