Fabtech, ProComp 6" lift or more. Pictures
Discussion in 'Suspension' started by toku58, Jul 2, 2009.
  1. Dec 20, 2012 at 3:04 PM
    #4841
    N8iV Warrior
    N8iV Warrior Well-Known Member
    Johnny
    Indian Reservation Not by Choice
    07 Silver Dble Cab Trd Sport 6" fabtech lift
    6" Fabtech lift, 34" tires , AFE Cold air intake, Cobra wxst75 cb, Rocky Mountain Radar, L.e.d Headlights, L.e.d maplights,dome light, license plate lights, Tinted frnt windows 35% to match rear windows. ARB bumper with XD-9000 Warn Winch, Pro-Tech HeadAche rack with Pro-Tech Toolbox, Icon Front Coilovers for 6" Fabtech lift, Blacked out Taillights PIAA plasma ION 520 Lights, AFE CAI Pro Dry S Filter, 22" Led light bar, Yakima Mega Warrior basket
    Merry Christmas Tacoma World and God Bless You All.
  2. Dec 22, 2012 at 8:12 PM
    #4842
    AaronArf
    AaronArf Well-Known Member
    Aaron
    VA Beach
    2023 LR OR DCSB
    Depends on what sliders you've got. That's why I went with the beefed medium width sliders. Not as much step area as the oem tubes but more than enough to step on, clean the roof etc
  3. Dec 23, 2012 at 12:44 AM
    #4843
    motorsport36
    motorsport36 Black Lights Matter
    Furnace, AZ
    98 SR5 AC 4x4
    I have finally finished reading 253 pages of what refer to as "truck porn".
    I think I have decided to go with the BDS upgraded kit with the fox shocks.
    I have two questions. My first one involves an earlier post about using total chaos UCA's. Blacktacoma 23 stated that he had to switch from his TC UCA's on his 3 inch lift to a set of TC UCA's with heim joints. Is this required or can I use the TC UCA's from my 3 inch lift that do not have heim joints?
    Also there has been talk about using AP expo and/or Alcan leaf packs. I was going to buy the Alcan, but already have an AP leaf pack. However, it is not the expo. It is the full leaf pack they offer for thrre inch lift kits. Will this one work in place of the expo? The only difference I see is the weight it can handle.
    2013 long bed double cad 4x4 is on the way as the prerunner takes an exit stage left.
  4. Dec 23, 2012 at 1:47 AM
    #4844
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    2011 Mall Crawler
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Nittos, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tint, 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, Trail Gear bumper, Crown brake lines F/R
    Congrats!
    You need Light Racing Uca's or the TC w/ heims (Maybe Icon has compatible for 6" lifts:confused:) I need a little more adjustability out of my TC ucas for perfect alignment.
    Get Alcans in the rear, shox are very long for my expos. and a 6" sping will look better with a long bed.
    Edit: I ran stock ucas for a week and no issues since its stock geometry
  5. Dec 23, 2012 at 6:04 AM
    #4845
    AaronArf
    Aaron
    VA Beach
    2023 LR OR DCSB
    The topic of heim & uniball uca vs standard tubular uca with uniball is A question i was going to ask. If you can run tube uca on a stock truck why would the drop bracket 6" which keeps the geometry relatively the "same" why would you NEED the arms with heim joints.
  6. Dec 23, 2012 at 6:40 AM
    #4846
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    i had a pretty bad bro lean with my pro comp 6" lift and expos in the rear, and expos are quite a bit taller than the standards.
  7. Dec 23, 2012 at 8:43 AM
    #4847
    motorsport36
    Furnace, AZ
    98 SR5 AC 4x4
    This was exactly the point I was trying to make, Thank you boss! well said. If the TC non-heim UCA is a direct replacement for stock setup, and the 6 inch works with stock uca's...why the heck would they not be interchangeable and work???
  8. Dec 23, 2012 at 8:50 AM
    #4848
    motorsport36
    Furnace, AZ
    98 SR5 AC 4x4
  9. Dec 23, 2012 at 12:58 PM
    #4849
    Manwithoutaplan
    ID
    Might be finally getting 4.56 gears with arb lockers :woot:
    Thanks to my little friend name Vegas
  10. Dec 23, 2012 at 1:01 PM
    #4850
    Blacktacoma23
    2011 Mall Crawler
    Excess caster
    You dont Need them, here is this from a Fj forum
    "If I were you, I would keep the stock arms, or use the total chaos arms with heims. I am running the 6" Rough Country lift, and if Pro Comp is similar, they designed the bracketry to maintain proper caster angle with the stock upper. The non-heim versions of the TC arms will likely have too much caster.
    I ordered the heim version, and actually dialed out some of the caster to get them closer to stock. See this post. UCA offsets and adjustments
    Even with adjustment, they are still not back to stock geometry. When you adjust the heims, TC recommends that you do not unscrew them any more than 1/4 inch from where they are set when you get them. I ended up unscrewing the rears the maximum allowable amount, and turning the fronts in.
    I also had one of the early versions of the Icon billet arms (made when they were Donahoe). These arms are even further away from stock geo when adjusted as close to stock as possible. I had many problems with them, and will never use Icon products other than their coilovers. It is possible they changed dimensions since then. I have never had a single issue with any TC product, and I have their upper arms on my FJ and wifes tacoma, and their front and rear lower arms on my FJ."
    Nice thing about custom Alcans, you can choose:thumbsup:
  11. Dec 23, 2012 at 1:06 PM
    #4851
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    Finally
  12. Dec 23, 2012 at 1:08 PM
    #4852
    Manwithoutaplan
    ID
    eat dirt
  13. Dec 23, 2012 at 1:10 PM
    #4853
    Manwithoutaplan
    ID
    how was dove springs??
  14. Dec 23, 2012 at 2:44 PM
    #4854
    Blacktacoma23
    2011 Mall Crawler
    :woot: :yay:
  15. Dec 23, 2012 at 3:00 PM
    #4855
    pa blaster
    pa blaster Well-Known Member
    Scott
    central pa
    2024 GMC Canyon AT4X AEV
    :ohsnap:
  16. Dec 23, 2012 at 3:08 PM
    #4856
    motorsport36
    Furnace, AZ
    98 SR5 AC 4x4
    Totally get that is the great thing about ordering Alcans, but I am asking what the drop in height is after they settle. Therefore giving me a good idea on what height to order them. Also would you order 1/2 inch higher on lean side?
  17. Dec 23, 2012 at 5:32 PM
    #4857
    Warputer
    Warputer Dirt Road Inspector
    Lake Murray, South Carolina
    2011 TRD Off Road
    9" of Super Bro lift
    Freshly carved logging roads provide quite a bit of fun.
  18. Dec 23, 2012 at 5:41 PM
    #4858
    My68ur8trd
    My68ur8trd Well-Known Member Vendor
    Justin
    Williamsburg, VA
    2007 TRD OR Dcab 4x4
    URD Catback | TRD CAI | TRD S/C | APR X-1 | DTLT | APR 2.85" Pulley |Fabtech 6" | Icon C/O | Alcan Leafs | 33 Grabber AT2 | 17" XD Addicts
    I ordered my alcans for 350 lb extra carrying capacity for that very reason. and 6" lift
    My springs are over 2 years old and the truck still sits just at tough tail high ( which is what I wanted)
    Justin
  19. Dec 23, 2012 at 5:49 PM
    #4859
    AaronArf
    Aaron
    VA Beach
    2023 LR OR DCSB
    Good info on the UCA options and issues! Interested in anyone else's alignment info on trucks with the 6" lift and non heim tubular uppers. Were you able to get it into stock specs. My concern would be finding an experienced alignment guy that can actually utilize the extra adjustment on the TC UCA W/ heims.
  20. Dec 23, 2012 at 5:56 PM
    #4860
    Blacktacoma23
    2011 Mall Crawler
    Im close to spec, you have to remove the UCA's to adjust them:mad: so that took a little. I wouldve gone Light racing uppers but wanted the uniball and strength.
    Best of luck with TC UCA's for 3" lifts!
