Fabtech, ProComp 6" lift or more. Pictures
Discussion in 'Suspension' started by toku58, Jul 2, 2009.
  1. Dec 24, 2012 at 10:54 PM
    #4881
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    Bitch
  2. Dec 24, 2012 at 10:55 PM
    #4882
    Manwithoutaplan
    ID
    Bring it ho bag :D
  3. Dec 26, 2012 at 1:19 PM
    #4883
    motorsport36
    motorsport36 Black Lights Matter
    Furnace, AZ
    98 SR5 AC 4x4
    This was covered to a small degree of page 230 something but I would like some clarification. I understand that if i want to run 16's or 17's on a BDS/Procomp/Fabtech lift I would need to add 1.25 wheel spacers. Will these effect my wheel travel when offroading at all? What are the pros and cons if any? I have this image of my wheels being too far out and hitting my fenders when offroading.
  4. Dec 26, 2012 at 1:30 PM
    #4884
    Warputer
    Warputer Dirt Road Inspector
    Lake Murray, South Carolina
    2011 TRD Off Road
    9" of Super Bro lift
    ^^Plan on 285/75's or bigger....like 305 or 315?
  5. Dec 26, 2012 at 1:32 PM
    #4885
    motorsport36
    Furnace, AZ
    98 SR5 AC 4x4
    I wanna go with 315's
  6. Dec 26, 2012 at 1:32 PM
    #4886
    motorsport36
    Furnace, AZ
    98 SR5 AC 4x4
    But willing to consider depending on circumstance
  7. Dec 26, 2012 at 1:42 PM
    #4887
    Warputer
    2011 TRD Off Road
    From what guys have said, with or without the spacers, to run the 315 a cab mount chop is necessary along with trimming all the lower corners on front plastic fenders. I've trimmed ALOT and still rub sometimes at full turn with the wheel stuffed up into the fender. I didn't go agressive enough with my cab mount chop yet and this is my contact point most of the time. Did the wheel spacer amplify these rubbing issues? Maybe on the plastic fenders but I don't think it effects the rubbing on the cab mount because the wheel is set outward more.
    The simple fix for me would be fiberglass fenders with more flare/opening for the wheels. A Tight budget in the house is hampering this.
    Cblanc3 likes this.
  8. Dec 26, 2012 at 1:44 PM
    #4888
    Warputer
    2011 TRD Off Road
    And with your nice bumper....the only clearance issue would be the rear of the front plastic fenders.
  9. Dec 26, 2012 at 2:15 PM
    #4889
    motorsport36
    Furnace, AZ
    98 SR5 AC 4x4
    I will install and proceed accordingly. I just dont want to make the mistake of getting 16 or 17 inchers and have to use spacers that will limit what i can and cannot do with my truck when i can just get 18's and have no real issues
  10. Dec 26, 2012 at 2:21 PM
    #4890
    My68ur8trd
    My68ur8trd Well-Known Member Vendor
    Justin
    Williamsburg, VA
    2007 TRD OR Dcab 4x4
    URD Catback | TRD CAI | TRD S/C | APR X-1 | DTLT | APR 2.85" Pulley |Fabtech 6" | Icon C/O | Alcan Leafs | 33 Grabber AT2 | 17" XD Addicts
    FYI I run 17s with no spacers.
    You just have to watch the back spacing ( or offset, whichever language you speak)
    Justin
  11. Dec 26, 2012 at 2:39 PM
    #4891
    Manwithoutaplan
    ID
    I have 17's with no spacers either.
  12. Dec 26, 2012 at 2:40 PM
    #4892
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    i run spacers on all 4 corners and have had absolutely no issues with them
  13. Dec 26, 2012 at 2:59 PM
    #4893
    Warputer
    2011 TRD Off Road
    What size wheels Patrick?
  14. Dec 26, 2012 at 3:42 PM
    #4894
    motorsport36
    Furnace, AZ
    98 SR5 AC 4x4
    So if I run 17's what specs should i look for using BDS 6
  15. Dec 26, 2012 at 4:39 PM
    #4895
    PLC721
    Patrick
    Chandler, Az
    17x9 4.75" backspacing. Worked on 6" kit but not my current gusseted spindles. So 1.25" spacers were added
  16. Dec 26, 2012 at 5:34 PM
    #4896
    motorsport36
    Furnace, AZ
    98 SR5 AC 4x4
    Good! That makes looking for wheels much easier. Can I ask for suggestions...17's in black...any ideas?
  17. Dec 26, 2012 at 5:42 PM
    #4897
    PLC721
    Patrick
    Chandler, Az
    Methods, fuels(not the boost I want those :D ), ballistic fab and bmf all make fine looking wheels
  18. Dec 26, 2012 at 5:44 PM
    #4898
    motorsport36
    Furnace, AZ
    98 SR5 AC 4x4
    I'll look into them. Thanks
  19. Dec 26, 2012 at 5:54 PM
    #4899
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    2011 Mall Crawler
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Nittos, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tint, 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, Trail Gear bumper, Crown brake lines F/R
    Wheel bearings wear out faster.
    Us newer guys (08+) have larger knuckles for VSC. some can use 17's most need spacers to go 17's.
  20. Dec 26, 2012 at 6:03 PM
    #4900
    motorsport36
    Furnace, AZ
    98 SR5 AC 4x4
    What spacer are you running on your 17's
