Fabtech, ProComp 6" lift or more. Pictures
Discussion in 'Suspension' started by toku58, Jul 2, 2009.
  1. Mar 1, 2013 at 11:58 AM
    #5841
    Manwithoutaplan
    ID
    will see i think around april or may more like it.
  2. Mar 1, 2013 at 11:59 AM
    #5842
    Manwithoutaplan
    ID
    ok will let you know.
  3. Mar 1, 2013 at 12:34 PM
    #5843
    SuthrnTaco07
    SuthrnTaco07 Well-Known Member
    Kyle
    Huntsville, AL
    2020 Cement Tundra Limited
    None
    These aren't traditional 5100's..
    Bilstein makes a special set of 5100's for the RCD 4.5"-5" DB kit that only has one setting and that setting is 4.5"s.. So I have it set at that setting.
    What is everyone's center of wheel to fender measurements!? The guys running 35's..
  4. Mar 1, 2013 at 12:46 PM
    #5844
    YotaMatt
    YotaMatt Livin Low, Ridin High
    West Point VA
    12 PreRunner DC TRD Sport
    Spidertraxx 1.25" spacers in front and rear, 4" Maxtrac Spindles,Billy 5100s at 0", OME 885 Springs, 1/4" top spacer on both sides, 1.5" AAL, 3" Block, 1.5" 4crawler driveshaft spacer, 17x9 XD Spys with 35x12.50 Nitto Mud Grapplers, Magnaflow offroad Stainless Exhaust, Volant Intake with scoop,Camo emblems, BHLM, Tinted tailights, Anytime fog mod,Alpine Type R 12, Kicker 1000 watt amp,600 watt 4 channel memphis and all memphis components, 35%tint front all the rest at 5%, Hella 500s with sylvania zxe bulbs, sylvania zxe headlights, sylvania zxe fogs, Weathertech digi fits, flyzeye blue/white, LED map dome license plate lights, Redline hood struts, Tailgate EZ Down, Custom TRD Camo Browning Edition Bedsides, Camo wet okoles, Ridgid Dually bed lights, SOS Concepts Tire Carrier
    Not sure if I count...but..mine is 27 1/2 hub to fender. .and 44 1/2 ground to fender. ..on 35s
  5. Mar 1, 2013 at 12:52 PM
    #5845
    SuthrnTaco07
    Kyle
    Huntsville, AL
    None
    That is IDEAL! What suspension setup are you running!?
    Edit.. I just looked and though badass.. You are a PreRunner so it kinda doesn't completely qualify..
  6. Mar 1, 2013 at 12:55 PM
    #5846
    jacko
    jacko Active Member
    Jack
    Destin
    '10 MGM TRD Sport
    6' BDS Lift 35' 1250 17 Toyo M/T 17' XD Revolvers 5% tint all around Yakima racks Debadged all around UWS low profile toolbox 4.88 Yukon gears
  7. Mar 1, 2013 at 12:55 PM
    #5847
    Warputer
    Warputer Dirt Road Inspector
    Lake Murray, South Carolina
    2011 TRD Off Road
    9" of Super Bro lift
    26.25" front
    26.75" rear
    But my front is lower due to the heavy ass ARB bumper.
  8. Mar 1, 2013 at 12:57 PM
    #5848
    SuthrnTaco07
    Kyle
    Huntsville, AL
    None
    Ok.. Let me correct this.. From ground to fender in the center of wheel.
  9. Mar 1, 2013 at 12:58 PM
    #5849
    TuFerLife
    TuFerLife 2 4 LIFE!!!
    Taylor
    Chattanooga, TN
    2011 Ford Raptor (I'm a traitor)
    I'll go measure mine... I've never measured it before
    Edit: about 43.5" in front and rear from ground to center of fender...
  10. Mar 1, 2013 at 1:02 PM
    #5850
    Warputer
    2011 TRD Off Road
    42.25" front, ground to fender
    42.75" rear, ground to fender
    26.25" front, center hub to fender
    26.75" rear, center hub to fender
    ....just walked out side & got this. As I mentioned above.....my front lost close to 1" in height with the addition of this big ass bumper.....and the rear has settled some too since my install last summer.
  11. Mar 1, 2013 at 1:21 PM
    #5851
    SuthrnTaco07
    Kyle
    Huntsville, AL
    None
    Thank you.. Thats not too bad but I'm trying to see what is normal for a 6" lift kit.
    And you're still able to run 35's?
  12. Mar 1, 2013 at 1:26 PM
    #5852
    Warputer
    2011 TRD Off Road
  13. Mar 1, 2013 at 1:27 PM
    #5853
    Manwithoutaplan
    ID
  14. Mar 1, 2013 at 1:30 PM
    #5854
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    2011 Mall Crawler
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Nittos, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tint, 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, Trail Gear bumper, Crown brake lines F/R
    [​IMG] Real clean and no trac bars.
  15. Mar 1, 2013 at 1:39 PM
    #5855
    Warputer
    2011 TRD Off Road
    Dang.....that's a good bit lower than my 16 to 17.5 (but I drive like a granny unless I'm on the trails). What were U getting before the swap?
  16. Mar 1, 2013 at 1:47 PM
    #5856
    Manwithoutaplan
    ID
    u might get little better with the Auto. I think rpms are lower at 65 and 70. I was getting about 270 to 300 a tank.
  17. Mar 1, 2013 at 1:49 PM
    #5857
    Warputer
    2011 TRD Off Road
    We might be close then....I never go 65 to 70. She really sucks up the gas at those speeds, especially on the hills. I'm at 55 on the Interstate & everyone is passing me....fuck em. :D
  18. Mar 1, 2013 at 1:51 PM
    #5858
    Manwithoutaplan
    ID
    that is how i am I drive like grand mama. Are trucks love 2k after that they sux gas like no other.
  19. Mar 1, 2013 at 1:51 PM
    #5859
    Warputer
    2011 TRD Off Road
    Found some freshly carved logging roads out in the woods this week.....the KM2's have been very impressive each time.
    CroResident likes this.
  20. Mar 1, 2013 at 1:52 PM
    #5860
    Manwithoutaplan
    ID
    nice you should keep it like that for while.
