Fabtech, ProComp 6" lift or more. Pictures
Discussion in 'Suspension' started by toku58, Jul 2, 2009.
  1. May 13, 2013 at 12:35 AM
    #6561
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    2011 Mall Crawler
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Nittos, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tint, 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, Trail Gear bumper, Crown brake lines F/R
  2. May 13, 2013 at 2:59 AM
    #6562
    WhyNotFab
    WhyNotFab Well-Known Member
    Ricky
    Florida
    '08 TRD Off Road
    I bought new shock tabs to raise the lower shock mounts to compensate, but once I took the Fox shocks off, they were only about an inch shorter than the new Fabtech ones, so I put them on for now but will still be raising the tabs asap. I'll only be driving to and from work which is a 6 mile round trip every day until this weekend when I can crank the coilovers to match the rear fender height (one side needs about 1", one side needs just under 2") trim the cab mounts a little if needed, and change my diff & transfer case oil since we ran out of time. Does anyone use the sway bar with the db lift? I put my front skid plate back on and thought the sway bar would have looked completely stupid hanging down there lol plus it does seem to ride smoother now!
  3. May 13, 2013 at 6:55 AM
    #6563
    Warputer
    Warputer Dirt Road Inspector
    Lake Murray, South Carolina
    2011 TRD Off Road
    9" of Super Bro lift
    I was just told the same thing on the phone. Anything over 3" is too hard to keep aligned so they won't do the lifetime.
  4. May 13, 2013 at 8:31 AM
    #6564
    BORNWILDGUY
    BORNWILDGUY Well-Known Member
    Rich
    Florida
    2020 TACOMA TRD SPORT DCLB LIFTED W KDMAX-PRO XT TUNE
    FULLY LOADED WITH THE TECH PACKAGE, LEATHER, JBL SYSTEM W UPGRADED JBL SPEAKERS IN AL DOORS AND SUB, LED HEADLIGHTS, MOONROOF, EXTANG FULL TILT COVER, NFAB SIDE STEPS, OEM ROOF RACK, TRD PRO TAILS, COLOR MATCHED TRD PRO GRILL WITH WHITE RAPTOR LIGHTS, 15% TINT ALL THE WAY AROUND, TINTED WINDSHIELD 50%, BILSTEIN 6112'S W 650# SPRINGS AND 1/4 SPACER, ICON LEAF SPRINGS W 5125 REAR SHOCKS, WELD LEDGE 6 WHEELS 18 X 9 -12 W 275/65R18 TOYO AT III LOAD C TIRES
    Try tires plus, tire kingdom or even sears. Had a 4.5 lift on my Tundra and 5" on this truck and never heard that. Especially since on a drop bracket all you angles are kept like stock unlike a 3".
  5. May 13, 2013 at 9:41 AM
    #6565
    AaronArf
    AaronArf Well-Known Member
    Aaron
    VA Beach
    2023 LR OR DCSB
    Which firestone you go too? On your side of the water or towards Norfolk? I need an alignment and might as well go for the lifetime as well.
  6. May 13, 2013 at 10:52 AM
    #6566
    Warputer
    2011 TRD Off Road
    I read where sagging front springs can cause the tires to wear on the inside prematurely.....this is possible sence I have the ARB bumper & it did drop my front end about 1" or more.
    So....dosen't ToyTec sell a heavier pound spring in stock length? Coilovers are out right now, due to $$ issues.
  7. May 13, 2013 at 1:42 PM
    #6567
    BORNWILDGUY
    Rich
    Florida
    I would just get a set of the eibach springs or a set of ome 884/885 and with the weight of your bumper it should bring it down to where it needs to be. But if your gonna do that might as well replace the front shocks with 5100's at the same time.
  8. May 13, 2013 at 2:28 PM
    #6568
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    I'll see if i can dig up some pics!
  9. May 13, 2013 at 2:48 PM
    #6569
    09taco4x4
    09taco4x4 Well-Known Member
    Louisiana
    09 DCLB TRD Sport 4x4
    Valant cold air intake kit Borla catback exhaust 6" Pro Comp Stage 1 Walker Evans 2.5's w/ TSB spring and add-a-leaf Light racing upper a-arms 285/70/R17 Dynapro ATM tires 17x9 XD wheels
    :popcorn: interest to see if EXPOS will work with my setup too
  10. May 13, 2013 at 4:36 PM
    #6570
    Blacktacoma23
    2011 Mall Crawler
    In the rear 42.5" ground to fender. This with 315's and only weight in the bed is a spare.
  11. May 13, 2013 at 5:05 PM
    #6571
    WhyNotFab
    Ricky
    Florida
    '08 TRD Off Road
  12. May 13, 2013 at 5:49 PM
    #6572
    Warputer
    2011 TRD Off Road
    ^^Awesome!! Has all the goodies on it!
  13. May 13, 2013 at 5:51 PM
    #6573
    Manwithoutaplan
    ID
    I am looking into front bumper goodies :) winch and bumper :)
  14. May 13, 2013 at 6:05 PM
    #6574
    93civEJ1
    93civEJ1 Well-Known Member
    09 DC TRD OR
    Procomp 6" Stage 1, Bilstein 5100's in front, flowmaster 40 series
    I still need to do the cab mount chop on mine.
  15. May 13, 2013 at 6:27 PM
    #6575
    YotaMatt
    YotaMatt Livin Low, Ridin High
    West Point VA
    12 PreRunner DC TRD Sport
    Spidertraxx 1.25" spacers in front and rear, 4" Maxtrac Spindles,Billy 5100s at 0", OME 885 Springs, 1/4" top spacer on both sides, 1.5" AAL, 3" Block, 1.5" 4crawler driveshaft spacer, 17x9 XD Spys with 35x12.50 Nitto Mud Grapplers, Magnaflow offroad Stainless Exhaust, Volant Intake with scoop,Camo emblems, BHLM, Tinted tailights, Anytime fog mod,Alpine Type R 12, Kicker 1000 watt amp,600 watt 4 channel memphis and all memphis components, 35%tint front all the rest at 5%, Hella 500s with sylvania zxe bulbs, sylvania zxe headlights, sylvania zxe fogs, Weathertech digi fits, flyzeye blue/white, LED map dome license plate lights, Redline hood struts, Tailgate EZ Down, Custom TRD Camo Browning Edition Bedsides, Camo wet okoles, Ridgid Dually bed lights, SOS Concepts Tire Carrier
    Nah..need moar lift...I no rub...and no cab mount choppa :cool:
  16. May 13, 2013 at 6:29 PM
    #6576
    93civEJ1
    09 DC TRD OR
    yeah, but your probably not turning 37's x 13.5's. I am but see little offroad yet...wanting to start getting of the beaten path a little.
  17. May 13, 2013 at 6:35 PM
    #6577
    YotaMatt
    West Point VA
    Very soon I will be :spy: and on 20x12s :cool:
  18. May 13, 2013 at 9:32 PM
    #6578
    Blacktacoma23
    2011 Mall Crawler
    How much lift currently?
    not sure how you dont rub right now
  19. May 14, 2013 at 7:45 AM
    #6579
    93civEJ1
    09 DC TRD OR
    6"
    I do rub, if I turn sharply.
    I dont turn sharp and i currently dont go off road hardly ever.
    The only reason I have 37's is cause a local guy with a titan wanted to trade my 35's trail grapplers for his almost new 37" mud graps straight up.
    So I did it.
  20. May 14, 2013 at 8:39 AM
    #6580
    YotaMatt
    West Point VA
    Hmmm....im at 7.5" of lift now...maybe 37s is possible
