Fabtech, ProComp 6" lift or more. Pictures
Discussion in 'Suspension' started by toku58, Jul 2, 2009.
  1. Jul 15, 2013 at 4:05 PM
    #7061
    Manwithoutaplan
    ID
    dont ride to high you might run into over pass.
  2. Jul 15, 2013 at 4:06 PM
    #7062
    YotaMatt
    YotaMatt Livin Low, Ridin High
    West Point VA
    12 PreRunner DC TRD Sport
    Spidertraxx 1.25" spacers in front and rear, 4" Maxtrac Spindles,Billy 5100s at 0", OME 885 Springs, 1/4" top spacer on both sides, 1.5" AAL, 3" Block, 1.5" 4crawler driveshaft spacer, 17x9 XD Spys with 35x12.50 Nitto Mud Grapplers, Magnaflow offroad Stainless Exhaust, Volant Intake with scoop,Camo emblems, BHLM, Tinted tailights, Anytime fog mod,Alpine Type R 12, Kicker 1000 watt amp,600 watt 4 channel memphis and all memphis components, 35%tint front all the rest at 5%, Hella 500s with sylvania zxe bulbs, sylvania zxe headlights, sylvania zxe fogs, Weathertech digi fits, flyzeye blue/white, LED map dome license plate lights, Redline hood struts, Tailgate EZ Down, Custom TRD Camo Browning Edition Bedsides, Camo wet okoles, Ridgid Dually bed lights, SOS Concepts Tire Carrier
    Dis is mah dream :rolleyes::D
  3. Jul 15, 2013 at 4:15 PM
    #7063
    Manwithoutaplan
    ID
  4. Jul 15, 2013 at 8:35 PM
    #7064
    ayunk04
    ayunk04 Well-Known Member
    Adam
    Pittsburgh
    trd off road
    6 inch pro comp
    NEED HELP! Ive had my truck for about 3 months now 6 inch pro comp stage 1, and ive had this vibration problem from 22-30mph. Accelerating or slowing down through these speeds. Starting to get very annoyed with it. I installed the beefed cb drop kit and still have it. Is anyone else having this problem?.... any feedback would be appreciated.
  5. Jul 15, 2013 at 8:38 PM
    #7065
    littlejouf22
    littlejouf22 Member
    Jordan
    Gainesville, FL
    05 Prerunner 4.0L Access Cab TRD OR
    6000k HID Hi/Low, 6000K Fogs, 2 Sundown Audio 12's 4 Cubic Foot Box Tuned at 32 Hz, LED license plate lights, UWS Low Profile Black Toolbox, Bilstein 5100s all fours, Maxtrac Spindles, 1.5" AAL and 3" Block, 5% Tint all Around
    Here's mine recently lifted: Maxtrac Spindles, 5100s, 1.5" AAL and 3" Block
    Chevy sucks :p
  6. Jul 15, 2013 at 9:15 PM
    #7066
    2ndGenJonny
    2ndGenJonny Well-Known Member Vendor
    Jon
    Gilbert, AZ
    There are a ton of threads on this exact issue man. Some will say its the driveline angle and to swap to a single driveshaft and other will point to the blocks. Your best bet is to research a good driveline shop in your area and have them take a look at the angles and also your driveline and make a recommendation. Good luck.
  7. Jul 16, 2013 at 11:05 AM
    #7067
    Oregon TRD
    Oregon TRD "GO DUCKS" Edition
    Ross
    Steel Panthers bathroom floor!
    2005 Mall Krawler
    6" Fabtech Lift, 35" Fierce M/T 17" Eagle Alloy Sim bead locks Naked girls in the bed 10.1" DVD head unit Two 7" Headrest Monitors PS2 in glove box
    :thumbsup:
  8. Jul 16, 2013 at 2:08 PM
    #7068
    Warputer
    Warputer Dirt Road Inspector
    Lake Murray, South Carolina
    2011 TRD Off Road
    9" of Super Bro lift
    I have had the same vibration (same speed also) sense the lift was added. The vibration isn't bad enough for me to lose any sleep though. My old Jeep had way worse issues with vibes. It would eat rear pinion seals about every 12 months.....I guess 12" of lift added to the issues.
    Looks badass! Good to see someone else running nonblack wheels for a change.
  9. Jul 16, 2013 at 2:33 PM
    #7069
    Manwithoutaplan
    ID
    well if ppl in so cal wouldn't have worn out chrome so bad I would have pick it but it is :puke:
  10. Jul 16, 2013 at 3:02 PM
    #7070
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    2011 Mall Crawler
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Nittos, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tint, 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, Trail Gear bumper, Crown brake lines F/R
    4" or 6" spindles? mad clearance!
  11. Jul 16, 2013 at 3:21 PM
    #7071
    YotaMatt
    West Point VA
    Hell yea..now im not the only one with over 6" of lift that doesnt have a db lift...spindles ftw!!!
  12. Jul 16, 2013 at 3:45 PM
    #7072
    BORNWILDGUY
    BORNWILDGUY Well-Known Member
    Rich
    Florida
    2020 TACOMA TRD SPORT DCLB LIFTED W KDMAX-PRO XT TUNE
    FULLY LOADED WITH THE TECH PACKAGE, LEATHER, JBL SYSTEM W UPGRADED JBL SPEAKERS IN AL DOORS AND SUB, LED HEADLIGHTS, MOONROOF, EXTANG FULL TILT COVER, NFAB SIDE STEPS, OEM ROOF RACK, TRD PRO TAILS, COLOR MATCHED TRD PRO GRILL WITH WHITE RAPTOR LIGHTS, 15% TINT ALL THE WAY AROUND, TINTED WINDSHIELD 50%, BILSTEIN 6112'S W 650# SPRINGS AND 1/4 SPACER, ICON LEAF SPRINGS W 5125 REAR SHOCKS, WELD LEDGE 6 WHEELS 18 X 9 -12 W 275/65R18 TOYO AT III LOAD C TIRES
    Agrees
  13. Jul 16, 2013 at 4:29 PM
    #7073
    Ugly Betty
    Ugly Betty Well-Known Member
    mark
    TX
    85 extra cab on propane
    1985 ex cab, 92 toyota pickup, 95 4runner
    I had the same issue, tried both size cb drops and nothing worked. Was going to get a 1 piece ds but before I got a chance I changed the block and stock leafs out for Alcan 6 in leafs and the vibes stopped.
  14. Jul 16, 2013 at 6:23 PM
    #7074
    ayunk04
    Adam
    Pittsburgh
    trd off road
    6 inch pro comp
    Thanks! this is what ill have to try next once I get a little $ saved up
  15. Jul 16, 2013 at 7:09 PM
    #7075
    littlejouf22
    littlejouf22 Member
    Jordan
    Gainesville, FL
    Spindles are badass! Way more ground clearance then a DB lift would ever get you. Measured my rear diff and its sitting about 12" clearance! :thumbsup:
  16. Jul 16, 2013 at 7:11 PM
    #7076
    littlejouf22
    littlejouf22 Member
    Jordan
    Gainesville, FL
    4" Maxtrac Spindles with Bilstein 5100's set at 2.5". Yeah she sits high! Plus girls still think its a 4WD most of them don't know what CV axles are haha :cool:
  17. Jul 17, 2013 at 2:51 AM
    #7077
    YotaMatt
    West Point VA
    This is true..people dont even believe me when I tell them its 2wd...im like..why would I make that up? :rolleyes:
  18. Jul 17, 2013 at 5:20 AM
    #7078
    55chevy05taco
    55chevy05taco Well-Known Member
    Tallon
    lewis county, Washington
    05 V6 SR5 4x4 DCLB
    3" rough country spacer lift, mastercraft wild cat AT2, dual pipe magnaflow, billet grill, rocker guards(?), weld kit front plate winch bumper, 4x55w hella black magic 500's, k&n cold air intake, black badges, smoked OEM tails, bestop supertop,
    Just installed my procomp stage 2..
  19. Jul 17, 2013 at 5:26 AM
    #7079
    55chevy05taco
    Tallon
    05 V6 SR5 4x4 DCLB
    What would ya'll recomend I do in the rear, I have stock leaf pack, aal n blocks.. shackle flip should (fingers crossed) be done this weekend.
  20. Jul 17, 2013 at 6:32 AM
    #7080
    09taco4x4
    09taco4x4 Well-Known Member
    Louisiana
    09 DCLB TRD Sport 4x4
    Valant cold air intake kit Borla catback exhaust 6" Pro Comp Stage 1 Walker Evans 2.5's w/ TSB spring and add-a-leaf Light racing upper a-arms 285/70/R17 Dynapro ATM tires 17x9 XD wheels
    What size tires?
