Fabtech, ProComp 6" lift or more. Pictures
Discussion in 'Suspension' started by toku58, Jul 2, 2009.
  1. Sep 14, 2013 at 11:11 AM
    #7361
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    :rofl: that was a good thread
  2. Sep 14, 2013 at 11:16 AM
    #7362
    Warputer
    Warputer Dirt Road Inspector
    Lake Murray, South Carolina
    2011 TRD Off Road
    9" of Super Bro lift
    Winches are on my wish list......behind a sound system. The stock stuff stinks, especially when using the Aux cable to an Ipod or phone. :mad:
  3. Sep 14, 2013 at 11:16 AM
    #7363
    Manwithoutaplan
    ID
    Yes it was almost up there with renting a front bumper :laugh:
  4. Sep 14, 2013 at 11:20 AM
    #7364
    Manwithoutaplan
    ID
    Yea I hear you on that one. Still have been able to get clear answer on what kinda system I would need for a stero cause I listen to mostly hard rock and heavy metal.
    As far as for the winch might have to bite the bullet go with Xeon 10k s.
  5. Sep 14, 2013 at 6:07 PM
    #7365
    2ndGenJonny
    2ndGenJonny Well-Known Member Vendor
    Jon
    Gilbert, AZ
    I am done with mods for a bit now cause I am VERY happy with my results! I did just install new headlights today cause my blacked out @ home ones started to fill up with water.
    I have noticed that this thread is dying, WTF?
    The front end took about 4 hours and the rear took about 2 hours with making all of the adjustments to the front to level it out.
  6. Sep 21, 2013 at 1:30 PM
    #7366
    WhiteMud
    WhiteMud Well-Known Member
    British Columbia
    2017 DCSB TRD Sport
    What tire sizes are you guys running on an 18" wheel? I'm beyond confused what to get.
    Seems like my only options are a 285/65/R18 or 285/75/R18..
  7. Sep 21, 2013 at 2:26 PM
    #7367
    2ndGenJonny
    Jon
    Gilbert, AZ
    Do you have a lift? I assume so since you are posting in the 6" thread. A lot of these guys run 35x12.50 because they can. I run a 285x75, but on a 17" wheel.
    You have no pics so I cannot see for myself. So please, give us some info so I can attempt to help you.
  8. Sep 21, 2013 at 4:24 PM
    #7368
    WhiteMud
    British Columbia
    2017 DCSB TRD Sport
    6 inch BDS.
    I heard you still have to trim a lot for 35's. Apparently 295/70/18's work pretty well.
  9. Sep 21, 2013 at 4:36 PM
    #7369
    2ndGenJonny
    Jon
    Gilbert, AZ
    Yea, 35s need trimming and gears at some point for sure. I used to run a 295x70 but I just like the taller thinner tire more and have zero issues with rub even after I dropped down to 5"
    Are you planning on an MTR or AT?
  10. Sep 21, 2013 at 6:29 PM
    #7370
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    Any of you guys need a carrier bearing drop? I have a beefed taco one for sale
  11. Sep 21, 2013 at 7:01 PM
    #7371
    808Renato
    808Renato Well-Known Member
    Renato Medeiros
    Kauai
    16 MGM DC 4x4 6spd Manual
    12" Bulletproof! Kauai as y
  12. Sep 21, 2013 at 7:44 PM
    #7372
    WhiteMud
    British Columbia
    2017 DCSB TRD Sport
    Definitely a MTR. I'm afraid a 35 tire will cause to many issues. I'm thinking a 295/70 will provide a nice beefy look and I don't mind the wide tire look?
  13. Sep 21, 2013 at 7:49 PM
    #7373
    2ndGenJonny
    Jon
    Gilbert, AZ
    Do you already have wheels? How come you dont have any pictures up?
  14. Sep 21, 2013 at 8:00 PM
    #7374
    WhiteMud
    British Columbia
    2017 DCSB TRD Sport
    I have everything except tires, I'm beyond confused on what size to get
  15. Sep 21, 2013 at 8:01 PM
    #7375
    2ndGenJonny
    Jon
    Gilbert, AZ
    What does BDS specs say?
  16. Sep 21, 2013 at 8:16 PM
    #7376
    WhiteMud
    British Columbia
    2017 DCSB TRD Sport
    They say a 35" tire, with a 18 or 20" wheel. But from what I've heard you'll still have tons of rubbing without issues. That's why I'm thinking if I go a bit smaller, I will have less possible rubbing issues.
  17. Sep 21, 2013 at 8:18 PM
    #7377
    2ndGenJonny
    Jon
    Gilbert, AZ
    Both Toyo and Nitto make tires in 295x70r18 and Ive had both. I can honestly say I didnt care for either one. I now have the Toyo ATII and this tire is awesome! Agressive tread design, high miles and great factory warranty of 55k.
  18. Sep 21, 2013 at 8:33 PM
    #7378
    WhiteMud
    British Columbia
    2017 DCSB TRD Sport
    Did you have any rubbing issues with that tire size?
  19. Sep 22, 2013 at 6:34 AM
    #7379
    2ndGenJonny
    Jon
    Gilbert, AZ
    Rubbing will happen if you have the wrong offset wheel. I rubbed on my sway bar at full crank because it was next to impossible to find a wheel I liked in the offset that PC suggested. I even went with a PC wheel and they didn't make it in that offset (f#ckers) I ended up taking off my sway bar like most of the guys on TW do and dont regret it one bit or miss it.
    If you like the fat mtr look, go with the 295. Its almost as wide as the 35 just not as tall. You wont need to re-gear and save a bit of $ over the 35.
    Both the nitto and toyo are aggressive and noisy when low on tread and expect 45k or less out of them if you spend more time on the street.
    Bottom line IMO, the Toyo ATII is still the better choice and they make it in that size. Thats my 2c, take it or leave it.
    Good luck man!!:D
    EDIT: put up some pictures & make a signature! show off your taco!!
  20. Sep 22, 2013 at 8:05 AM
    #7380
    BORNWILDGUY
    BORNWILDGUY Well-Known Member
    Rich
    Florida
    2020 TACOMA TRD SPORT DCLB LIFTED W KDMAX-PRO XT TUNE
    FULLY LOADED WITH THE TECH PACKAGE, LEATHER, JBL SYSTEM W UPGRADED JBL SPEAKERS IN AL DOORS AND SUB, LED HEADLIGHTS, MOONROOF, EXTANG FULL TILT COVER, NFAB SIDE STEPS, OEM ROOF RACK, TRD PRO TAILS, COLOR MATCHED TRD PRO GRILL WITH WHITE RAPTOR LIGHTS, 15% TINT ALL THE WAY AROUND, TINTED WINDSHIELD 50%, BILSTEIN 6112'S W 650# SPRINGS AND 1/4 SPACER, ICON LEAF SPRINGS W 5125 REAR SHOCKS, WELD LEDGE 6 WHEELS 18 X 9 -12 W 275/65R18 TOYO AT III LOAD C TIRES
