Fabtech, ProComp 6" lift or more. Pictures
Discussion in 'Suspension' started by toku58, Jul 2, 2009.
  1. Feb 22, 2014 at 10:00 PM
    #8081
    2006KJ
    2006KJ Well-Known Member
    Front Royal VA
    It's not my first choice but found a used that I'm interested in.
    So will the pro comp stage 2 with cool overs work on a 2012?
    Pro comps website only shows a stage 2 for 05-2011 and a stage 1 only for 2012
  2. Feb 23, 2014 at 12:14 AM
    #8082
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    2011 Mall Crawler
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Nittos, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tint, 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, Trail Gear bumper, Crown brake lines F/R
    Ride would be better than PC c/o's
  3. Feb 23, 2014 at 12:41 AM
    #8083
    2ndGenJonny
    2ndGenJonny Well-Known Member Vendor
    Jon
    Gilbert, AZ
    I cannot express to you enough that the PC C/o's are crap off road. In fact, the whole kit is just not made for it. The amount of pre load on the fronts and adding blocks in the rear is just bad news for any functional off roading. I've been over this and so have a few others on this thread. If you are totally sold on going 6 inches, look at just doing the DB/spindle set only from PC, Fabtech or BDS and call them directly to inquire but DO NOT pull the trigger until you are 100% certain. Buying a used kit at a good price is never a good idea.
    If you are in the for the look and never go off road, by all means do the 6". If you want to crawl over rocks, go fast down a wash and use the truck to its maximum capability.. you need to do more homework.
  4. Feb 23, 2014 at 6:57 AM
    #8084
    2006KJ
    Front Royal VA
    Thanks for the advice. For the price of this used kit I was going to do alcan leaf pack in the back instead of blocks. But if the pro comp coil overs are 'that' bad ill just avoid it all together and save up for the BDS with fox hardware. I do not off-road my truck (have a 06 long armed rubicon on 35s for that). But I would like it to ride very well and soak up washboard roads and poor condition dirt roads. I guess you get what you pay for haha
  5. Feb 23, 2014 at 7:23 AM
    #8085
    Warputer
    Warputer Dirt Road Inspector
    Lake Murray, South Carolina
    2011 TRD Off Road
    9" of Super Bro lift
    Or if you live in the South.....and just hit mud holes.....this kit is fine. :p Especially a Stage 1 with upgraded shocks & rear leafs.
  6. Feb 23, 2014 at 8:01 AM
    #8086
    2ndGenJonny
    Jon
    Gilbert, AZ
    The degressive rate icons are great at soaking up washboard roads, I can personally speak to just how well they do that because those kind of roads are all over where I live. Maybe one of these other guys can speak to Fox shocks. Regardless, they are all comparable and rebuildable. You don't even need remote reservoirs, they just look cool.
  7. Feb 23, 2014 at 8:05 AM
    #8087
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    Trust what Scarlett4x4 is saying the PC CO's are complete crap they purposely build them stiff as hell and they are also not serviceable or rebuildable unless you send them to PC and they offer no valving options etc. The internals in a PC CO are junk piled in a non serviceable sealed cartridge.
    If you are looking to run 35's I would offer this advice also - I would even tell you to be careful about BDS w/ Fox for one reason - no 6" kit actually clears 35's with a 4.5 BS wheel ( wich you must run to clear the spindles ) without trimming, cutting, hammering, removing flaps and inner fender liners and chopping your cab mount. Even just daily driving in and out of driveways over bumps with your wheel turned you have the potential to rip lugs off of your tires and tear up your fenders etc. I love the look of my DB kit but the fact is I had to go to 8" in the front with $4k custom King CO's to truly fully clear 35's under all circumstances.... If you can just buy the DB brackets and spindles etc only and do everything else custom such as the Alcan's you mentioned. Otherwise just run a 33 IMO.
  8. Feb 23, 2014 at 8:07 AM
    #8088
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
  9. Feb 23, 2014 at 8:57 AM
    #8089
    Manwithoutaplan
    ID
    Just go SAS then you will be good to go. Let wyatt build your shit, i am heading that direction.
  10. Feb 23, 2014 at 9:04 AM
    #8090
    2ndGenJonny
    Jon
    Gilbert, AZ
    A 285x75r17 is a 34 and will have no issues and still look really good. You will not need to regear or cut.
    MWOAP is going the route like eatabullet did. Make the DB do awesome and then rip it all apart and go SAS. The bottomine is, do your homework and listen to those of us that have dropped the $$$ so you don't have to.
  11. Feb 23, 2014 at 9:09 AM
    #8091
    Manwithoutaplan
    ID
    I have figured if i go play truck then i am back to square one :(. It would be about the same price if i ripped my kit off went sas.
  12. Feb 23, 2014 at 9:21 AM
    #8092
    2ndGenJonny
    Jon
    Gilbert, AZ
    Not sure what kit you are looking at to swap into but I've found older Toyotas for under 6g that are ready to crawl.
  13. Feb 23, 2014 at 3:28 PM
    #8093
    Blacktacoma23
    2011 Mall Crawler
    :worthless:
  14. Feb 23, 2014 at 3:33 PM
    #8094
    Warputer
    2011 TRD Off Road
    ^^^Matt has spoken. :D
  15. Feb 23, 2014 at 4:04 PM
    #8095
    Ridendirtywhips
    Ridendirtywhips Well-Known Member
    Sacramento
    06 prerunner
    Procomp 6" with 20x12 fuel wheel w/ 35 toyo tires.
  16. Feb 23, 2014 at 4:09 PM
    #8096
    Ridendirtywhips
    Sacramento
    06 prerunner
  17. Feb 23, 2014 at 4:11 PM
    #8097
    AaronArf
    AaronArf Well-Known Member
    Aaron
    VA Beach
    2023 LR OR DCSB
    Do yourself a favor and skip the DB lift. :D I hate mine. :eek: When it's time, I think I'm going long travel or SAS depending on where I get stationed next.
  18. Feb 23, 2014 at 4:32 PM
    #8098
    2ndGenJonny
    Jon
    Gilbert, AZ
    I feel like I just saw my evil twin with 20 inch rims :eek:
    I love the honesty of a few of the members in this thread in particular. No Bullshit and nothing but the truth. You don't get that in a lot of places.
  19. Feb 23, 2014 at 4:45 PM
    #8099
    Glueman
    Glueman Yersinia pestis
    Utah
    The Plague....
    6 inch Douche Bag lift...what else do I need?
    Don't get me wrong, I love my truck but after a few years of "educating myself" I would have done a few things differently. I like my lift but with it comes a few issues that I'm not fond of. It is still very capable on and off road (after a lot of work!). LT is a good way to go but it has it's own issues to deal with. SAS is awesome but expensive and hard to sell after it's done. Anyway, I love my truck but hind sight is 20/20. :anonymous:
  20. Feb 23, 2014 at 5:07 PM
    #8100
    2ndGenJonny
    Jon
    Gilbert, AZ
    Jason, I'm expecting full pictars and measurements of the finished product. You went the same, but totally different direction than I went (if that even makes sense) I'm interested to see what kind of travel and clearance you have when its all said and done.
