Fabtech, ProComp 6" lift or more. Pictures
Discussion in 'Suspension' started by toku58, Jul 2, 2009.
  1. Apr 17, 2014 at 7:33 PM
    #8361
    BORNWILDGUY
    BORNWILDGUY Well-Known Member
    Rich
    Florida
    2020 TACOMA TRD SPORT DCLB LIFTED W KDMAX-PRO XT TUNE
    FULLY LOADED WITH THE TECH PACKAGE, LEATHER, JBL SYSTEM W UPGRADED JBL SPEAKERS IN AL DOORS AND SUB, LED HEADLIGHTS, MOONROOF, EXTANG FULL TILT COVER, NFAB SIDE STEPS, OEM ROOF RACK, TRD PRO TAILS, COLOR MATCHED TRD PRO GRILL WITH WHITE RAPTOR LIGHTS, 15% TINT ALL THE WAY AROUND, TINTED WINDSHIELD 50%, BILSTEIN 6112'S W 650# SPRINGS AND 1/4 SPACER, ICON LEAF SPRINGS W 5125 REAR SHOCKS, WELD LEDGE 6 WHEELS 18 X 9 -12 W 275/65R18 TOYO AT III LOAD C TIRES
    Good way to do it. Just so you know the 4" and 6" the braketry is the same. Only difference is on the 6" they give you a small preload spacer that goes between the coil spring and top hat and the 6" comes with a 4" rear block versus a 3" on the 4" kit.
    If looking at the bds basic kit you might want to consider the zone kit as well. Zone and bds are both owned by the same company Sport Truck Usa. The kits are almost identical and you will save a lil money getting the zone. They also make a 4" and 6" as well. This kit can also be upgraded to different coilovers as well if you want later on whether icon or fox.
  2. Apr 17, 2014 at 8:02 PM
    #8362
    StealthTaco
    StealthTaco www.ecgfabrication.com
    Alec
    NC
    05 Black Tacoma TRD Sport 6-speed
    The zone does look the same...but no lifetime warranty like the bds :spy:
    Definitely wouldn't mind saving $500 though. Guess I'll have to try and find anyone with the kits and how their lifts are holding up.
  3. Apr 17, 2014 at 8:05 PM
    #8363
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    Alright...new rule for the DB thread - no more DB bashing by DB owners, sure give people good advice about how to go about it properly but if I hear " might as well go LT " one more time I'm gonna puke. Add up everything to build an LT truck and you will find that statement is just not accurate at all.
    Buying custom CO's in no way costs as much as a LT kit and it's not that much more $ for the travel you gain. Remember that gaining just 2" of stroke at the CO form a custom built CO = 4" travel at the wheels. Unless you are comparing the cost of a real CO to the garbage cheap CO's that come with a DB kit then yes it is a lot more.
    There is nothing wrong with a DB truck IMO - the problem is the crappy DB kits with garbage CO's and blocks.
    Higher COG sure I will concede that fact but they do make spacers to widen your stance if you want to offset that...but technically the wider 35x12.5's you can fit with a DB add 4" + of width to your stance to offset the 6" of lift which is technically the same COG as a 2" lift on OE tires...ready debate
    Vent complete :)
  4. Apr 17, 2014 at 8:06 PM
    #8364
    BORNWILDGUY
    Rich
    Florida
    Btw I have the zone that's why I recommended it. Bought the 4" and upgraded it to a 6"
    Zone Offroad Products Warranty
    To the original retail purchaser, Zone OffRoad Products guarantees all its products are free from defects in material and workmanship for as long as that purchaser owns the vehicle on which such products were originally installed
  5. Apr 17, 2014 at 8:12 PM
    #8365
    StealthTaco
    Alec
    NC
    Well I missed that haha. Hows the ride vs. stock? I'd eventually ditch the block for a new leaf pack
  6. Apr 17, 2014 at 8:19 PM
    #8366
    BORNWILDGUY
    Rich
    Florida
    Ride is nice. Def install a new leaf pack and ditch the block. I went with the all pro expo w a 2" block w the bilstein F4-BE5-B110-T5 in rear and in front installed the longer bilstein 5100's used on the rcd kit f4-be5-e122-to and a 1/2 top plate spacer on both sides and 1/4" on driv side for the taco lean w extended ss brake lines front and rear as well. It is a solid kit and you won't be disappointed.
  7. Apr 17, 2014 at 8:23 PM
    #8367
    StealthTaco
    Alec
    NC
    I was considering a custom Alcan leaf pack, but that decision won't come for a while anyways. Thanks for the help! One more question...I have 17s...you think they can fit with spacers?
  8. Apr 17, 2014 at 8:28 PM
    #8368
    BORNWILDGUY
    Rich
    Florida
    Not sure on that one as it would depend on the inside of the wheel you would be using. The reason they recommend 18's is because the tie rod is moved to the top of the spindle mount. I am not fond on running wheel spacers.
  9. Apr 17, 2014 at 8:33 PM
    #8369
    StealthTaco
    Alec
    NC
    Hmm. I know blacktacoma23 is running 17 ballistic jesters with spacers on his bds kit. So hopefully I would be able to do the same with the zone.
  10. Apr 17, 2014 at 8:34 PM
    #8370
    Max713
    Max713 Well-Known Member
    Max
    Eugene, OR
    2017 MGM TRD OR
    That's what I did :broccoli:
  11. Apr 17, 2014 at 8:39 PM
    #8371
    BORNWILDGUY
    Rich
    Florida
    The zone and bds spindles are the same it just depends on the inner part of the wheel that you plan to use. Me personally I like a 18" wheel.
  12. Apr 17, 2014 at 8:41 PM
    #8372
    StealthTaco
    Alec
    NC
    Sweeeet :bananadance:
    I like the 17" myself, hopefully I can make it work!
  13. Apr 17, 2014 at 8:44 PM
    #8373
    BORNWILDGUY
    Rich
    Florida
    You might be able to. If you get a spacers make sure to get a hubcentric ones.
  14. Apr 17, 2014 at 8:48 PM
    #8374
    StealthTaco
    Alec
    NC
    Thats the plan. Thanks for your help man.
  15. Apr 17, 2014 at 8:50 PM
    #8375
    BORNWILDGUY
    Rich
    Florida
    Not a problem. :thumbsup:
  16. Apr 17, 2014 at 11:27 PM
    #8376
    Warputer
    Warputer Dirt Road Inspector
    Lake Murray, South Carolina
    2011 TRD Off Road
    9" of Super Bro lift
    I run 16's with spacers. :D
  17. Apr 18, 2014 at 3:08 AM
    #8377
    YotaMatt
    YotaMatt Livin Low, Ridin High
    West Point VA
    12 PreRunner DC TRD Sport
    Spidertraxx 1.25" spacers in front and rear, 4" Maxtrac Spindles,Billy 5100s at 0", OME 885 Springs, 1/4" top spacer on both sides, 1.5" AAL, 3" Block, 1.5" 4crawler driveshaft spacer, 17x9 XD Spys with 35x12.50 Nitto Mud Grapplers, Magnaflow offroad Stainless Exhaust, Volant Intake with scoop,Camo emblems, BHLM, Tinted tailights, Anytime fog mod,Alpine Type R 12, Kicker 1000 watt amp,600 watt 4 channel memphis and all memphis components, 35%tint front all the rest at 5%, Hella 500s with sylvania zxe bulbs, sylvania zxe headlights, sylvania zxe fogs, Weathertech digi fits, flyzeye blue/white, LED map dome license plate lights, Redline hood struts, Tailgate EZ Down, Custom TRD Camo Browning Edition Bedsides, Camo wet okoles, Ridgid Dually bed lights, SOS Concepts Tire Carrier
    Get the bds...less cutting involved...best kit I've installed hands down...if you can afford it get the kit that comes with the fox coilovers. .the ride is awesome...I've installed a zone as well and the quality in the bds is alot better
  18. Apr 18, 2014 at 5:57 AM
    #8378
    BORNWILDGUY
    Rich
    Florida
    There is the same amount of cutting in both kits 7 1/4". The ride will also be the same on the basic kits or you can add the fox or icon coilovers to both.
  19. Apr 18, 2014 at 6:03 AM
    #8379
    YotaMatt
    West Point VA
    The zone that I did required the entire crossmember to be cut out where the bds just had a small section to be removed on the drivers side
  20. Apr 18, 2014 at 6:06 AM
    #8380
    YotaMatt
    West Point VA
    Also being as you are 2wd the cutting isn't as much as on the 4wd lifts...As you are not clearing for driveshaft and front diff...this is why most db lifts the entire rear crossmember has to be removed...A very drop bracket on a 2wd I've done required no cutting at all
