Fabtech, ProComp 6" lift or more. Pictures
Discussion in 'Suspension' started by toku58, Jul 2, 2009.
  1. Apr 19, 2014 at 7:22 PM
    #8421
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    If at all humanly possible do not buy any of those "pre fab" CO's. They say they are for a 6" kit but they are NOT going to give you the height or the travel you want they are intended for street trucks. The Icon's are not tall enough and do not give you the full travel your truck is capable of. The Fox's in the BDS kit -same thing, none of them maximize the available travel. Listen to Scarlet4x4 he ran into that issue and had to drop down a bit, I ran into the same too which is why I ended up going the full custom route through King. Take your CO's off and cycle your suspension and measure from the bottom of the upper CO bucket to center of the lower shock bolt eye. All they need for a custom shock build is full droop and full compression. I have been through the exact same scenario recently so feel free to PM me if you want my phone # for any advice !
  2. Apr 19, 2014 at 7:45 PM
    #8422
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    Spent the day at Dirt King yesterday getting my new 14" Kings installed :) Super stoked with the results ! I forgot to take pictures when we were cycling it with the wheels on so I will post some pictures of it flexed later.
    Couple of tips to share :
    1. Easy way to flex your leaf pack when you are building hoops and need to determine full droop and full compression is to take apart your leak pack leaving only the main 2 leafs that are wrapped. Measure the thickness of your leaf pack and cut a piece of tubing to insert in the place of your leaf pack ( like making a lift block out of a short chunk of tubing ) then put your u-bolts back on. This allows you to easily flex you springs with just a jack and retain the actual axle stack height.
    2. With a 6" leaf pack you can easily fit a 14" shock by building a hoop that goes to the top of the wheel well - no bed cutting required just trim the plastic inner liner. The 14" shock will even allow you to cut off the OE lower mounts on the axle and weld on new shock tabs centered on the axle.
    I included a couple of photos of full droop and full compression - and YES with the tire on it will go to full bump with a 35" tire. Fender flare trimming required of course. It is a true 14" of stroke with a King shock not 14" minus internal bumps etc. This gains you over 6" of additional travel vs the PC shocks or anything mounted to your stock locations :) I do have to change my rear hose fittings, we originally thought we would be mounting the resi's to the frame so DSM is going to change them for me this week.
    Edit - I just realized that photo is not full droop there is a block on the jack and a jack stand under the pumpkin too but that photo shows you the leaf pack disassembled with the tubing used as a spacer etc.
    Edit #2 - I'm so tired today I forgot to thank the guys at Dirt King, their customer service is incredible and their fab work is so clean. They squeezed me into their schedule yesterday and they knew my truck is my only vehicle so they stayed until 2am to get it all done for me ! On top of that they taught me a ton of stuff while I was hanging out all day with them.
  3. Apr 19, 2014 at 7:56 PM
    #8423
    2ndGenJonny
    2ndGenJonny Well-Known Member Vendor
    Jon
    Gilbert, AZ
    So how much travel?
  4. Apr 19, 2014 at 8:17 PM
    #8424
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    Sorry I just edited my post I meant to say " a true 14" of stroke ". With the rear end it is straight stroke = travel which is why I keep preaching maximizing stroke by taking those compressed and extended measurements and ordering accordingly.
    Edit - the PC's and pretty much any other shock mounted to your OE locations only provide 8-9" of travel so it is a gain of + 5-6" of travel ! :)
  5. Apr 20, 2014 at 3:27 AM
    #8425
    angrysamoandude
    angrysamoandude Active Member
    Grand Junction, Colorado
    2009 Toyota Tacoma
    265/75R16 BF Goodrich tires, K&N Cold Air Intake,
    Holy shit there are some sick Trucks on here... I have a long way to go:)
  6. Apr 20, 2014 at 8:33 AM
    #8426
    2ndGenJonny
    Jon
    Gilbert, AZ
    :thumbsup:
    Welcome to TW.
  7. Apr 20, 2014 at 10:46 AM
    #8427
    redtacoma88
    redtacoma88 Well-Known Member
    John Austin
    TN
    2012 TRD Off Road
    See Build Page...
    So I figured I might post my plan in here, just to get some feedback and any advice y'all can give!
    Right now I have a 3" Spacer/Block lift with 32" tires, it has been fine but not too great. Every few weekends I tow my Polaris RZR XP900 on a 12' trailer. Power is fine with the 32s everything works well.
    But this summer im really wanting to go the 6" lift direction. From the start I knew I would not want to get the 35s because towing 2000lbs would not be fun! So I want to get 33s... but I do also want something wide. So whatever lift I decide, I will also have a custom leaf pack made to help any sag issues when towing.
    So the rims im planning on getting are the 18x12 Fuel Hostages, and I'm not sure about tires yet. Either a 33x12.5 or a 33x13.5. Looking at Nittos and Micky thopsons.
    So let me know what yall think! Thanks!
  8. Apr 20, 2014 at 11:01 AM
    #8428
    sedmondson72
    sedmondson72 Well-Known Member
    Steven
    Grafenwoehr, Germany
    07 DCSB 4x4 TRD
    07 DCSB 4x4 TRD, 6" Fabtech Stage2 lift, Alcan 6" springs, Timbren Bump Stops, Allpro U-Bolt flip kit, Brute Force Fab front and rear bumpers, Pro Comp wheels, NFab nerf bars, Line-x rocker panels, grille & bushwacker fender flares, Herculiner interior floor, Leer Line-x'd topper, Road Wire Leather
    I have the Fabtech Stage Two 6" lift with 285/70/17. Love the stance with these tires.
  9. Apr 20, 2014 at 5:01 PM
    #8429
    2ndGenJonny
    Jon
    Gilbert, AZ
    What's wrong with keeping the wheels you have?
    How much wheeling and what type do you do?
    I ask for good reasons so I can give you my personal opinions. I should put this with a disclaimer because a few of us DB guys will give you a straight up no BS opinion. We have been there and done that with these lifts. So before I open up a conversation that has been beat to death here in the 6" thread. I advise that you just start scrolling back some pages or look for responses from myself, MWOAP and Aaron I believe.
  10. Apr 20, 2014 at 5:17 PM
    #8430
    YotaMatt
    YotaMatt Livin Low, Ridin High
    West Point VA
    12 PreRunner DC TRD Sport
    Spidertraxx 1.25" spacers in front and rear, 4" Maxtrac Spindles,Billy 5100s at 0", OME 885 Springs, 1/4" top spacer on both sides, 1.5" AAL, 3" Block, 1.5" 4crawler driveshaft spacer, 17x9 XD Spys with 35x12.50 Nitto Mud Grapplers, Magnaflow offroad Stainless Exhaust, Volant Intake with scoop,Camo emblems, BHLM, Tinted tailights, Anytime fog mod,Alpine Type R 12, Kicker 1000 watt amp,600 watt 4 channel memphis and all memphis components, 35%tint front all the rest at 5%, Hella 500s with sylvania zxe bulbs, sylvania zxe headlights, sylvania zxe fogs, Weathertech digi fits, flyzeye blue/white, LED map dome license plate lights, Redline hood struts, Tailgate EZ Down, Custom TRD Camo Browning Edition Bedsides, Camo wet okoles, Ridgid Dually bed lights, SOS Concepts Tire Carrier
    This is a smart thing to do...Once my 35s wear out I'm dropping to 33s and wide 20s...I tow my can am xmr and 8 foot trailer and it kills it..fuel mpg is terrible. .trans shifts alot...also I run nittos because I love them..they look good and ive had good luck with them. .With that being said they are very heavy
  11. Apr 20, 2014 at 5:21 PM
    #8431
    BORNWILDGUY
    BORNWILDGUY Well-Known Member
    Rich
    Florida
    2020 TACOMA TRD SPORT DCLB LIFTED W KDMAX-PRO XT TUNE
    FULLY LOADED WITH THE TECH PACKAGE, LEATHER, JBL SYSTEM W UPGRADED JBL SPEAKERS IN AL DOORS AND SUB, LED HEADLIGHTS, MOONROOF, EXTANG FULL TILT COVER, NFAB SIDE STEPS, OEM ROOF RACK, TRD PRO TAILS, COLOR MATCHED TRD PRO GRILL WITH WHITE RAPTOR LIGHTS, 15% TINT ALL THE WAY AROUND, TINTED WINDSHIELD 50%, BILSTEIN 6112'S W 650# SPRINGS AND 1/4 SPACER, ICON LEAF SPRINGS W 5125 REAR SHOCKS, WELD LEDGE 6 WHEELS 18 X 9 -12 W 275/65R18 TOYO AT III LOAD C TIRES
    12's look nice but if you want a nicer ride I would stick with an 18 x 10 especially if you are only going with a 12.50 wide tire.
    Nittos are a good tire but check out the toyo at II's too.
  12. Apr 20, 2014 at 6:24 PM
    #8432
    redtacoma88
    John Austin
    TN
    2012 TRD Off Road
    See Build Page...
    Thanks so much! Yeah I really like the look of wide 18's and 20's with 33s! Now I have this RZR i have no need to offroad my truck, so its all looks from now on!
  13. Apr 20, 2014 at 6:52 PM
    #8433
    AaronArf
    AaronArf Well-Known Member
    Aaron
    VA Beach
    2023 LR OR DCSB
    This ^
    :rofl:
    Although I see this thread is headed back in the right direction though... 18x12s. Hopefully chrome right :facepalm:
    In all seriousness, rotating mass has just as much to do with power loss as taller tires. Nittos look sweet and wear nice. Except they are stiff and heavy. Be mindful of back spacing
  14. Apr 21, 2014 at 8:30 AM
    #8434
    Oregon TRD
    Oregon TRD "GO DUCKS" Edition
    Ross
    Steel Panthers bathroom floor!
    2005 Mall Krawler
    6" Fabtech Lift, 35" Fierce M/T 17" Eagle Alloy Sim bead locks Naked girls in the bed 10.1" DVD head unit Two 7" Headrest Monitors PS2 in glove box
    HOLY SHIT!!!!!!
    I thought you sold that beast a long time ago.
    Welcome back man.
  15. Apr 21, 2014 at 8:23 PM
    #8435
    09taco4x4
    09taco4x4 Well-Known Member
    Louisiana
    09 DCLB TRD Sport 4x4
    Valant cold air intake kit Borla catback exhaust 6" Pro Comp Stage 1 Walker Evans 2.5's w/ TSB spring and add-a-leaf Light racing upper a-arms 285/70/R17 Dynapro ATM tires 17x9 XD wheels
  16. Apr 22, 2014 at 5:37 AM
    #8436
    2ndGenJonny
    Jon
    Gilbert, AZ
  17. Apr 22, 2014 at 5:39 AM
    #8437
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
    Another Toyo wannabe. Cool lol
  18. Apr 22, 2014 at 6:42 AM
    #8438
    gdb
    gdb Active Member
    '07 4x4 with 4.88's
    Hey RAPR, good to hear from you again.
    Thanks.
  19. Apr 22, 2014 at 10:10 AM
    #8439
    2ndGenJonny
    Jon
    Gilbert, AZ
    :thumbsup:
  20. Apr 22, 2014 at 10:25 AM
    #8440
    NCtaco914
    NCtaco914 MALLIN'CRAWLIN'
    NEIL
    NORTH CAROLINA
    17' DCSB TRD O/R
    Gonna end going DB by the end of summer myself. However, will be going BDS. They seem to have changed the DB typical problems we see from Fabtech, PC, etc..Higher clearance on the DB itself and they dont use those silly trac bar looking things and you can re use your skid plate. Really think its a killer setup myself. Also going to do 35 12.50 17 MTR's which weigh a lot less than Nitto's, Toyo's, etc. Everyone seems to go down the same path around here...Lol
