Fabtech, ProComp 6" lift or more. Pictures
Discussion in 'Suspension' started by toku58, Jul 2, 2009.
  1. Jul 18, 2014 at 6:20 PM
    #9301
    2ndGenJonny
    2ndGenJonny Well-Known Member Vendor
    Jon
    Gilbert, AZ
    The race series LCA from TC has zerk fittings for the bushings, I'm referring to the uni ball that needs to be lubed (especially on the lowers)
    I will also recommend that you be very careful with those zerk when installing. Make sure the threads are clear of powder coat and position them facing out so you can easily lube them with the wheels on.
  2. Jul 18, 2014 at 6:41 PM
    #9302
    NCtaco914
    NCtaco914 MALLIN'CRAWLIN'
    NEIL
    NORTH CAROLINA
    17' DCSB TRD O/R
    That's interesting! Never knew they were extended.. So how much lift are you getting out of them? Beats having the big coffee can spacer till CO's. Would running extended springs be to risky also? Then I could really ditch spacers all together. I'm looking for about 7" of lift on the front. I just want the control arms to have a slight angle just to gain more clearance
  3. Jul 18, 2014 at 6:53 PM
    #9303
    BORNWILDGUY
    BORNWILDGUY Well-Known Member
    Rich
    Florida
    2020 TACOMA TRD SPORT DCLB LIFTED W KDMAX-PRO XT TUNE
    FULLY LOADED WITH THE TECH PACKAGE, LEATHER, JBL SYSTEM W UPGRADED JBL SPEAKERS IN AL DOORS AND SUB, LED HEADLIGHTS, MOONROOF, EXTANG FULL TILT COVER, NFAB SIDE STEPS, OEM ROOF RACK, TRD PRO TAILS, COLOR MATCHED TRD PRO GRILL WITH WHITE RAPTOR LIGHTS, 15% TINT ALL THE WAY AROUND, TINTED WINDSHIELD 50%, BILSTEIN 6112'S W 650# SPRINGS AND 1/4 SPACER, ICON LEAF SPRINGS W 5125 REAR SHOCKS, WELD LEDGE 6 WHEELS 18 X 9 -12 W 275/65R18 TOYO AT III LOAD C TIRES
    Running the longer shocks isn't going to hurt anything as they were designed for the db lift. They are just longer so you don't have to run the std coilovers and the 4" top hat spacer. If you are wanting that much lift just run 2ea 1/2 top plate spacers on each side. You will also need to get the longer bolts to replace the std ones in your top hat on the coilover so you can run the spacers. Im right at 5 3/4 front lift with my set up running just one 1/2 top plate spacer on each side and a 1/4 on driv side for the taco lean. You need to remember the 4" and 6" basic kits for bds and zone in the front are the same except on the 6" kit they give you a small preload spacer that goes on top of your coilspring between the top hat. The top hat spacer on both kits is identical.
    Here is where I got mine at.
    http://www.cumminsperformanceparts.com/rcdf4be5e122t0.html
  4. Jul 18, 2014 at 7:01 PM
    #9304
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    Delrin is still a good idea for the LCA's, it is an upgrade over poly, stronger and no need to lube.
  5. Jul 18, 2014 at 7:07 PM
    #9305
    NCtaco914
    NEIL
    NORTH CAROLINA
    17' DCSB TRD O/R
    Perfect, thanks for the clarity! Definitely better option than the standard 5100's then. I guess I'll just order a cheap spacer for the top and run the pre load also. Only conflict is how much does that pre load spacer add as far as lift?
  6. Jul 18, 2014 at 7:11 PM
    #9306
    BORNWILDGUY
    Rich
    Florida
    Just run the longer 5100's and the top plate spacer. I would take out that small preload spacer to help give you a better ride and just run the top plate spacers.
  7. Jul 18, 2014 at 7:18 PM
    #9307
    NCtaco914
    NEIL
    NORTH CAROLINA
    17' DCSB TRD O/R
    Well looks like I'll be adding that to the list...lol I'll probably get a few different sizes so I can get it exactly where I want. Thanks for the help! Stoked I can ditch the big spacer from the start
  8. Jul 18, 2014 at 7:47 PM
    #9308
    Warputer
    Warputer Dirt Road Inspector
    Lake Murray, South Carolina
    2011 TRD Off Road
    9" of Super Bro lift
    :mad: Just laughed so hard I swallowed my chew.
  9. Jul 19, 2014 at 12:22 PM
    #9309
    Manwithoutaplan
    ID
  10. Jul 19, 2014 at 3:28 PM
    #9310
    Warputer
    2011 TRD Off Road
    78,000 miles.....front, driver wheel bearing is shot.....$106 for the part.....going in tomorrow....:mad:
  11. Jul 19, 2014 at 3:31 PM
    #9311
    Manwithoutaplan
    ID
    Why don't you do it yourself yo. You are old you should have all the mechinx background and tools. :)
    And old man power to get the bolts off.
  12. Jul 19, 2014 at 3:36 PM
    #9312
    Warputer
    2011 TRD Off Road
  13. Jul 19, 2014 at 3:44 PM
    #9313
    Manwithoutaplan
    ID
  14. Jul 19, 2014 at 3:48 PM
    #9314
    Warputer
    2011 TRD Off Road
    I'm sure the 1.25" wheel spacers helped kill the bearing early. The price we pay to be badass mall krawlerzs!! :rolleyes:
  15. Jul 19, 2014 at 3:50 PM
    #9315
    Manwithoutaplan
    ID
    You on 35 or 33's?
    Wheel spacers, tars, and bumper are probably the factors.
  16. Jul 19, 2014 at 4:00 PM
    #9316
    Warputer
    2011 TRD Off Road
    33's now.....and yes the added weight on the front didn't help.
  17. Jul 20, 2014 at 12:02 PM
    #9317
    Warputer
    2011 TRD Off Road
    Wheel bearing in.....forgot the rotor dust shield and had to take all the bolts loose again. Dammit all!
  18. Jul 20, 2014 at 12:10 PM
    #9318
    2ndGenJonny
    Jon
    Gilbert, AZ
    I took those shields off because I was tired of rocks and mud getting stuck in there and making a ton of noise. I also bashed one on a rock and it started to bind on my caliper when it got hot.
  19. Jul 20, 2014 at 12:13 PM
    #9319
    Warputer
    2011 TRD Off Road
    I thought about it Jon.....the shield had a few small rocks wedged in it. And the shield was bent.......rubbing the edge of the rotor. I had to put some hammer love to it.
  20. Jul 20, 2014 at 1:32 PM
    #9320
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    Holy Shite ! :eek: Just saw this on the LT thread, TC for the win ! Just kidding :D
