Fabtech, ProComp 6" lift or more. Pictures
Discussion in 'Suspension' started by toku58, Jul 2, 2009.
  1. Apr 30, 2015 at 10:59 AM
    Manwithoutaplan
    ID
    classic
  2. Apr 30, 2015 at 11:00 AM
    2ndGenJonny
    2ndGenJonny Well-Known Member Vendor
    Jon
    Gilbert, AZ
    I need to see this picture!!!
  3. Apr 30, 2015 at 11:01 AM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    ill look through pats build.. i think its in there somewhere
  4. Apr 30, 2015 at 11:01 AM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    I was actually able to fit 14's by doing a hoop and new axle tabs. Learned a cool trick for measuring leaf pack flex limits during that process. First jack up the ass end as high as you possibly can and put jack stands under it. Jack it up much higher than needed just to get tires off because you will need room to droop the leaf pack completely. While your leaf pack is on the truck measure the thickness of the leaf pack. Then while the pack is still on the truck remove your u-bolts and remove all of your leaves but the top one ( which is usually the top two due to the wrap ) so you are leaving the main leaf connected to the truck. Then measure the thickness of the remaining one or two leaves, subtract that from the total pack thickness and then cut a 2x4 chunk to match that thickness and serve as a mock up spacer. Put your u-bolts back on with that wood spacer in place in place of your other leaves. Then your leaf pack will be so weak you can very easily flex it to its compressed and extended limits with just a floor jack. image.jpg image.jpg That allows you to easily measure and plan where your top hoop and axle tabs will need to be.
  5. Apr 30, 2015 at 11:04 AM
    NCtaco914
    NCtaco914 MALLIN'CRAWLIN'
    NEIL
    NORTH CAROLINA
    17' DCSB TRD O/R
    Yes, those bds/fox rear shocks are shy of 30" extended and about 17" collapsed. Im not sure If I would actually gain any travel with them relocated though. Probably just easier to measure for new shocks if I were to buy the expo's
  6. Apr 30, 2015 at 11:13 AM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    The leaf pack is just a pile of 10 pieces of metal with small bolt through the middle...take that bolt out and you can do whatever you want. Are you wanting to add a 1/4 or 1/2" to compensate for the weight of your bumper and full size spare ?
    If you have not done it before and you want to come down to SD I can help you with it. If you are adding more thickness or even a shim you do have to buy a couple of those new center pin bolts which are cheap. They come really long and you simply chop them off when you are done.
  7. Apr 30, 2015 at 12:19 PM
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    2011 Mall Crawler
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Nittos, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tint, 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, Trail Gear bumper, Crown brake lines F/R
    Yes!
  8. May 3, 2015 at 8:13 AM
    Glueman
    Glueman Yersinia pestis
    Utah
    The Plague....
    6 inch Douche Bag lift...what else do I need?
    Got my new Relentless sliders Line X coated. Nice material, but I'm not a fan of the cost.... Welding them on next weekend.
  9. May 3, 2015 at 8:14 AM
    2ndGenJonny
    Jon
    Gilbert, AZ
    They look nice, how much were they?
  10. May 3, 2015 at 9:08 AM
    Glueman
    Utah
    The Plague....
    The line X was $250! :mad: Sliders were $550 (DOM tubing)
  11. May 3, 2015 at 9:38 AM
    Manwithoutaplan
    ID
    Might take you on the offer.
  12. May 3, 2015 at 5:55 PM
    Warputer
    Warputer Dirt Road Inspector
    Lake Murray, South Carolina
    2011 TRD Off Road
    9" of Super Bro lift
    Very nice!
  13. May 3, 2015 at 7:20 PM
    2ndGenJonny
    Jon
    Gilbert, AZ
    Did this come with a coating of anal ease and a butt plug to at least stretch you out before you got raped?
  14. May 4, 2015 at 6:59 AM
    Glueman
    Utah
    The Plague....
    No it did NOT. That's what made me so mad....
  15. May 5, 2015 at 5:53 PM
    2ndGenJonny
    Jon
    Gilbert, AZ
  16. May 5, 2015 at 6:38 PM
    NCtaco914
    NEIL
    NORTH CAROLINA
    17' DCSB TRD O/R
  17. May 5, 2015 at 8:06 PM
    2ndGenJonny
    Jon
    Gilbert, AZ
  18. May 6, 2015 at 4:55 AM
    NCtaco914
    NEIL
    NORTH CAROLINA
    17' DCSB TRD O/R
    Wow secondary shock on a DB is where I draw the line :der:
  19. May 6, 2015 at 6:02 AM
    2ndGenJonny
    Jon
    Gilbert, AZ
    Just to play the devils advocate here, but why draw the line there?
  20. May 6, 2015 at 6:32 AM
    NCtaco914
    NEIL
    NORTH CAROLINA
    17' DCSB TRD O/R
    I just personally wouldn't "dual purpose" a DB....Those uppers and lowers are sweet though
