Fabtech, ProComp 6" lift or more. Pictures
Discussion in 'Suspension' started by toku58, Jul 2, 2009.
  1. Nov 28, 2015 at 5:04 PM
    hcm
    hcm Well-Known Member
    2007 AC 4x4 TRD Offroad
    Yeah I agree with that. They're more of the old school style. Any recommendations for 17s that'll fit my truck?
    Acerwin likes this.
  2. Nov 28, 2015 at 5:07 PM
    2ndGenJonny
    2ndGenJonny Well-Known Member Vendor
    Jon
    Gilbert, AZ
    That's a tough one man! I always head towards wheels people don't have. I had PC 7069s on my DB build and I have Sequoia wheels on my new build.
    I spend a good amount of time in the dirt and I just won't buy super expensive wheels anymore due to rock damage.
  3. Nov 28, 2015 at 5:13 PM
    hcm
    I feel the same way. I'm looking for something that not many people have and that are also cheap. I don't offroad much now, but I'm trying to get into it more, so 18" rims aren't really going to cut it.
  4. Nov 28, 2015 at 5:19 PM
    hcm
    First off, are you sure that the 6" kit is exactly what you want? If you've read through this thread at all, you've probably noticed that it takes a lot of work (and money) to get a DB Lift to be capable offroad, and even then, it still won't be as suited offroad as a mid range mid-travel setup. That being said, DB lifts look great, and if you don't plan on offroading, are a good way to get height and larger tires (especially for the price offered). Could you give some more info on what he's including in the kit?
  5. Nov 28, 2015 at 5:21 PM
    bigl110
    bigl110 Well-Known Member
    Laurence
    Virginia
    2018 dcsb sr Barcelona red 4x4
    I've read every page on here and I don't wheel at all. I just bought a 2011 dbcb and my intentions from the jump were to lift it 6 inches. I'll post a link in a sec
  6. Nov 28, 2015 at 5:22 PM
    bigl110
    Laurence
    Virginia
  7. Nov 28, 2015 at 5:23 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    No not that... Remember...The DB spindle flips the tie rod end to the top of the spindle vs the bottom like OE. Because the tie rod end flips up to the top it comes dangerously close to the back lip of the rim.
  8. Nov 28, 2015 at 5:23 PM
    hcm
    Seems kind of odd that he wouldn't take pictures of the actually DB and other components themselves. Based on his description, it sounds like everything is there.
  9. Nov 28, 2015 at 5:25 PM
    bigl110
    Laurence
    Virginia
    Yea I'm going to see if he already removed it from his truck for pics. My only real issue is if I can get the local offroad shop or 4wheel parts to install it but I have met some guys on here that have installed them before so I could get some help without all the $ being spent on install
  10. Nov 28, 2015 at 5:28 PM
    hcm
    There's welding involved but as long as you can get that done, the rest of the install is do-able.
  11. Nov 28, 2015 at 5:29 PM
    bigl110
    Laurence
    Virginia
    Does the crossmember put on have to be welded? If so that means he had to cut his off? Or is it bolted on after the stock one is cut off?
  12. Nov 28, 2015 at 5:34 PM
    hcm
    You have to cut out part or maybe all off the front crossmember then weld in the new crossmember. Here's fabtech's instructions: http://www.fabtechmotorsports.com/files/FT26026i.pdf
  13. Nov 28, 2015 at 5:46 PM
    2ndGenJonny
    Jon
    Gilbert, AZ
    I say no on a used DB or even a new DB. But if you must DB go BDS.
  14. Nov 28, 2015 at 5:47 PM
    Acerwin
    Acerwin The unNORM NORM
    Andrew
    South Carolina
    Toyota Tundra
    The SCS sr8's
  15. Nov 28, 2015 at 5:48 PM
    hcm
    I thought the SR8's backspacing was like 4.3
    Acerwin[QUOTED] likes this.
  16. Nov 28, 2015 at 5:49 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    They look pretty sweet to me on a 3rd gen Tacoma:D
    1BA37FB3-6382-4A84-829A-474604DCA4E6_zps_106e6877c6b5ea202210577b3f437818888bb291.jpg
    6B607CF0-EE99-49B5-8DB1-86CD97F4946E_zps_4e70e3af435fedc671b652bfafe95d6f24198c7f.jpg
  17. Nov 28, 2015 at 5:49 PM
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    Not sure they're just sexy as a motherfawker
  18. Nov 28, 2015 at 5:51 PM
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    The 17x8.5 is 4.30" bs and the 16x8 is 4.00" bs:thumbsup:
  19. Nov 28, 2015 at 5:52 PM
    hcm
    So the F5's are your only wheels (not 18" or 20") that have 4.5 bs or more?
  20. Nov 28, 2015 at 5:55 PM
    bigl110
    Laurence
    Virginia
    I was actually set on a zone 6 inch lift which apparently is a sister company to bds but it's $600 cheaper for a stage 1 plus I can upgrade to fox coil overs down the road but I saw that deal on Craigslist and have been pondering my decision
    Blacktacoma23 likes this.
