Fabtech, ProComp 6" lift or more. Pictures
Discussion in 'Suspension' started by toku58, Jul 2, 2009.
  1. Dec 15, 2015 at 6:07 PM
    NABeast
    NABeast Un-Sub’d
    Paul
    Florida
    '08 4wD
    ImMrYo mirror bracket. A/C, P/W, Tilt, Cruise, AM/FM CD
    I need to just break down and regear already. There is no downside to it. You get what you pay for and its worth it.
    Neutral and Blacktacoma23 like this.
  2. Dec 15, 2015 at 6:10 PM
    Neutral
    Neutral Well-Known Member
    Fella
    Alabama
    14 SR5, 25 SR5
    14 4.5" RCD, Pelfreybilt armour, Fox coilovers/shocks, Alcan leaf springs, 4.56 gears, 35's 25 Stock
    You won't regret it.
    NABeast[QUOTED] likes this.
  3. Dec 15, 2015 at 6:18 PM
    NABeast
    NABeast Un-Sub’d
    Paul
    Florida
    '08 4wD
    I was thinking about ordering from ECGS, get assembly's and return the cores. Get it done in one day. It seems my diffs are pretty toasted already, gray fluid from the rear diff everytime I change it(3 times already in 27k) and the front makes noise in 4wd. It's definitely time...
    Neutral likes this.
  4. Dec 15, 2015 at 6:25 PM
    Neutral
    Fella
    Alabama
    14 SR5, 25 SR5
    I ordered mine through the last ECGS Group Buy. They usually do it around Labor Day though. That saved me like $200.
    Edit: I only bought front and rear gears though. They usually discount the gears more than everything else. Unfortunately they don't discount the assembly's though.
  5. Dec 16, 2015 at 4:11 AM
    Overkill07
    Overkill07 Tacoitis
    Warren
    Texas
    14 TRD O/R DC MGM
    A few audio upgrades, tinted windows, remote start because it f'n hot in Texas! 6in Fabtech DB lift, 17x9 Fuel Trophy wheels, 315/70/17 Duratracs,BAMF 80in sliders w/kickout, Prinsu cab rack w/30in Heretic light bar, custom bedside decals, custom hi-lift jack brackets, US Offroad front bumper w/winch, bed rack with RTT, CB, Short wave base station, Ultra gauge, color matched grille surround, an ungodly amount of recover gear, ARB fridge, hood struts, RotoPax, traction pads.
    What is the reasoning behind you having to change your diff fluid 3 times already? Did you submerge it without a breather mod?
  6. Dec 16, 2015 at 4:38 AM
    NABeast
    NABeast Un-Sub’d
    Paul
    Florida
    '08 4wD
    I bought the truck stock with14k,installed the lift all seemed fine. Around 22k I was going to take a 3000mile trip so I figured I'd change the fluid,and it came out gray. So I thought yeah maybe contamination since I didn't have by breather hose on yet. So I installed right after. I did my fluid again after my trip and it was gray again,I realize you don't get all of it out but still gray and shinny for me. The front diff makes noise but the fluid is clean as hell,go figure. The truck was super clean when I bought it, but it must have a story to tell. It's all good, it just gives me more motivation to regear.
  7. Dec 19, 2015 at 3:36 AM
    pinchetaco
    pinchetaco Well-Known Member
    Winston Salem, NC
    06 Taco 6 inch ProComp Lift 35's
    6 inch ProComp Lift, 35s, ProComp Wheels, 4.88 gears, Debadged, BHLM, Dome Light Mod, Trailer Plug Relocated
    I think mine are way over that, but ive got 4.88s with 35s
  8. Dec 20, 2015 at 4:10 AM
    Warputer
    Warputer Dirt Road Inspector
    Lake Murray, South Carolina
    2011 TRD Off Road
    9" of Super Bro lift
    On this Pro Comp stage 1 kit......I'm curious if this top plate & rubber spacer in the coil are needed to be added back in when I swap to the new 886 coils?
  9. Dec 20, 2015 at 5:49 AM
    2ndGenJonny
    2ndGenJonny Well-Known Member Vendor
    Jon
    Gilbert, AZ
    If the 886 coils don't include shocks that are as long as that that whole coilovers + spacer, yes they will need to go back in if you want to keep your height.
  10. Dec 20, 2015 at 5:55 AM
    Warputer
    2011 TRD Off Road
    Thank you Jon. Right now the truck looks like a hot rod from the 70's with ladder bars. The ARB bumper has compressed the front, stock coils to nothing & the rear is still lifted. I have SUPER RAKE. These 886's should do the trick.
  11. Dec 20, 2015 at 6:10 AM
    2ndGenJonny
    Jon
    Gilbert, AZ
    The 886 & 887 are heavy springs but I have no idea what # they translate to
  12. Dec 20, 2015 at 7:42 AM
    Manwithoutaplan
    ID
    I change my tranny and diff oil all the time. Those 4.56's get really hot so I figure I might as well change the oil out often. Plus the yota master mechinx today me the more you change it the better.
  13. Dec 20, 2015 at 7:46 AM
    Manwithoutaplan
    ID
    You sir need to get better shocks. I need to go sas and sell you my icons :).
    2ndGenJonny likes this.
  14. Dec 20, 2015 at 7:52 AM
    2ndGenJonny
    Jon
    Gilbert, AZ
  15. Dec 20, 2015 at 4:15 PM
    Manwithoutaplan
    ID
    :confused: :notsure:
  16. Dec 20, 2015 at 4:39 PM
    2ndGenJonny
    Jon
    Gilbert, AZ
    It's Trump agreeing with you. I should meme it but I thought you would get it. :)
  17. Dec 20, 2015 at 4:41 PM
    Manwithoutaplan
    ID
  18. Dec 21, 2015 at 7:06 AM
    Warputer
    2011 TRD Off Road
    With driving 30K miles a year....coil overs that need rebuilds are not a good option. Going with OME 886 coils, Billys set to 0 & TC UCA's.
    Acerwin likes this.
  19. Dec 21, 2015 at 7:33 AM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    What makes you think that coil overs need to be serviced or rebuilt more often that any other shock ? That is a complete myth.
    Blacktacoma23 likes this.
  20. Dec 21, 2015 at 7:36 AM
    Acerwin
    Acerwin The unNORM NORM
    Andrew
    South Carolina
    Toyota Tundra
    When do coilovers need to be serviced/rebuilt?
