Fabtech: Yay or Nae?
Discussion in 'Product Reviews' started by LeadFootCaliKid, May 27, 2010.
Would you run Fabtech suspension on your truck?
  1. I already do and love it!
    12.3%
  2. YES!
    22.8%
  3. Indecisive
    30.4%
  4. HELL NO!
    34.6%
  1. Aug 3, 2011 at 11:01 AM
    #101
    creedler
    creedler Well-Known Member
    Max
    Eugene, Oregon
    Stock for now
    Old build in sig
    With the upgraded dirt logic shocks for the price of the stage 1 kit I would consider it. :rolleyes:
  2. Aug 17, 2011 at 12:30 PM
    #102
    vprgts
    vprgts Well-Known Member
    Walter
    Centreville, VA
    Tacoma TRD Off Road Hybrid
    285/70/17 Nitto Ridge Grapplers, Wescott designs pre collar lift, rough country power side steps, Truxedo pro x15 soft roll up bed cover, OEM bed mat, OEM bed swing out box, OEM Trd pro front skid plate, aftermarket pro grill, diode dynamics led fog lights,
    After many hours/days of researching 6" lifts for Tacomas...Fabtech is the only way to go. Now having driven/wheeling 5000+ miles on the Fabtech...2 thumbs up!
  3. Nov 15, 2011 at 12:14 AM
    #103
    Scummy
    Scummy SCUMBAG CUSTOMS
    Phelan, CA
    hopped up 96 single cab 5 lug 4 banger
    Fabtech uppers and spindles, extended shackles in rear, k&n intake, flowmaster exhaust, and much more to come
    I have one. Its the uppers, spindles, and coils. The coils bow like hell but I've launched the hell out of it and have had no problems yet. But id rather save up and get a lt kit.
  4. Nov 15, 2011 at 1:22 PM
    #104
    Erik65
    Erik65 Dog slave
    Erik
    Oxford, MA
    2011 Timberland Mica TX Pro DC
    Stainless exhaust, 16" TRD wheels, 285x75x16 MTR Kevlars, Icon Stage IV, Icon Secondary shock hoop with adjustable remote reservoir bypass shocks, ATO shackle flip kit, AP U-bolt flip, AP Skids (IFS, transmission, T-case, diff cover)
    OK so here's my $.02: I just bought my '11 Tacoma TX in May and I am completely against having to shell out for suspension AND replacement fenders to install LT. It just seems ridiculous to pull off perfectly good fenders and then have to color match some goofy looking fiberglass jobs to make this work. I am NOT going to pre-load my suspension to achieve a measly 2-3" of lift to be able to install tires just slightly larger than the OE ones and no appreciable gain in ground clearance. I know Old Man Emu makes good stuff but it kind of falls into the same lack of impact category as the spacer style suspension. I enjoy hillclimbs and would like to be confident dealing with average type obstacles--not much for rock crawling through fields of boulders but am planning on rock rails. SOOOOO what's left other than the 6 inch drop bracket suspensions like Fabtech or a custom job that would probably be as much or more than the buttload needed for LT??? Hit me!
  5. Nov 15, 2011 at 1:49 PM
    #105
    06RadiantRed
    06RadiantRed Well-Known Member
    CA-Bay Area
    2006 Tacoma 4x4 TRD Off Road - RadRed!!
    ICON ext. Travel Coilovers, TC UCAs, Fox 2.0 FJ Rear Shox + 2"AAL rear
    The measly 2-3" coil lift with larger tires is going to give you more ground clearance than the 6" lift.
  6. Nov 15, 2011 at 2:28 PM
    #106
    Erik65
    Erik65 Dog slave
    Erik
    Oxford, MA
    Don't want the extra stress of preloading the suspension--seems counter productive if not outright destructive.
    Maybe I should look at Pro Comp............
  7. Nov 15, 2011 at 3:47 PM
    #107
    lightmup
    lightmup Well-Known Member
    Utah
    07 db cab TRD sport 6" fabtec lift 33-13.5-20
    AFE intake, Gibson cat back exhaust, Fabtec 6"lift, King remote resy coilovers, Light Racing UCA's , Allpro front bumper,PIAA fogs, 3 KC slim lights, Optima battery, Weathertech flour mats, Tinted windows, Wheels and tires, Back up camera, 10" shallow mount kenwood sub
    Have you looked at the allpro LT kit? I think you can run up to a 33/12:50 with out changing you fenders.
  8. Nov 15, 2011 at 4:11 PM
    #108
    bruth
    bruth Well-Known Member
    Brian
    Alamo ca
    2000 access cab 4x4 Tacoma
    Total chaos is currently shipping
    Thanks Creedler I will look up the dirt logic set up
  9. Nov 15, 2011 at 5:36 PM
    #109
    Erik65
    Erik65 Dog slave
    Erik
    Oxford, MA
    I'll check that out--thanks!
  10. Nov 15, 2011 at 6:43 PM
    #110
    platinumb
    platinumb Well-Known Member
    Patrick
    denver
    11 TRD OR DC Supercharged
    supercharger, focal/jl audio sound system, trd cat back
    Spacers pre load your suspension replacing the factory shocks and coils with aftermarket products does not most people do a 3" lift with new coils and longer shocks. I used the toytec ultimate lift and new upper control arms. 3" no preload and yes more ground clearance than a drop bracket lift. All this with a much smoother on road ride than factory.
  11. Nov 15, 2011 at 7:13 PM
    #111
    Manwithoutaplan
    ID
  12. Nov 17, 2011 at 5:03 PM
    #112
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    3 inch coilovers with uca replacement improves your travel, ground clearance and ride quality. Radiant red is also correct in pointing out that with a coilover lift you have more clearance than a 6 inch DB lift. You can also travel faster offroad than with the 6 inch lift. If you choose to go LT, you don't HAVE to get fiberglass fenders. You can just run smaller tires or trim/roll your fenders. Long travel does not give huge lift gains, just usable travel.
    A drawback to DB lift is that you cannot revert back to stock if you want to sell your truck. So its ultimately what you want to do with your truck and how you want it to look.
  13. Jan 27, 2012 at 3:07 PM
    #113
    greenguy3
    greenguy3 BOOM goes the dynamite!
    Ian
    Arkansas
    Dirty A$$ TRD
    Mud and dirt
    So what set up can you get the highest lift with without going LT and replacing fenders and all that? and cost wise? most clearance...if money is no object...
  14. Jan 27, 2012 at 3:11 PM
    #114
    greenguy3
    Ian
    Arkansas
    Dirty A$$ TRD
    Mud and dirt
    At least fabtech is better than procomp!
  15. Jan 27, 2012 at 3:14 PM
    #115
    DTFtacoma
    DTFtacoma Dezert Toy Fabrication Vendor
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    Saying fabtech is better than procomp is like saying a turd sandwich is better than diarrhea soup both of them are crap. ;)
  16. Jan 27, 2012 at 4:27 PM
    #116
    06yoda
    06yoda Well-Known Member
    Tanner
    Clovis, CA/ Emmett, ID
    1996 Landcruiser FZJ80
    The whole point of lifting your truck if wheeling it should be based on getting the most out of your suspension for your needs. Easily stating one would want to have the smallest amount of lift (~3" to maintain a lower center of gravity) to fit the biggest size of tires ( which is what actually gives you the "true" ground clearance) not the percieved ground clearance of a said 6" lift. There is a reason why LT kits are more expensive and why a coilover suspension is slightly less than that, is because they are more efficient, adjustable, etc.
    I'm not knocking the 6" lift but everyone has there reasons for getting one whether it be cheaper, looks, or just want one. But a coilover non-D/B suspension is "Better" than a D/B just like SAS is better than all of em' for General purpose offroading (not you baja guys though).
  17. Jan 27, 2012 at 5:49 PM
    #117
    lightmup
    Utah
    Look at allpro LT you can run 33-12.50 without changing your fenders. Other than that drop bracket lift is the way to go if you don't want to change your fenders. Although you will have to trim your fenders a little either way. All these guys saying you cant wheel hard core offroad with a DB lift are up in the night and the only place you get more clearance on a 3" lift is your front end under your pumpkin and even then not much more everywhere else like approach angle departure angle and between a the front and rear axles you have 3 more inches of clearance. Full LT is always going to kick ass over DB or 3" coils if you want to hall ass in the desert and even some Rock crawling but even them there is trade offs alinement will never be the same with LT. you will need to strengthen every thing frame, spindles,upper shock mount that is if you want to really use it to its potential IE. Camburg, Total Chaos. I think allpro is a good in-between kit not to aggressive doesn't screw with alinement as much and you can still rock crawl because its only 2" wider on each side. For a non go fast desert person the DB is the best for both worlds
    check out lightmup2 on youtube it shows how well a DB lifted taco can do on the rocks and and in the dunes. If you want to get really crazy on the rocks do a SAS. Hole crap that was a long rant sorry hopefully it helped a little.
    DB baby totally capable!:cool:
  18. Feb 15, 2012 at 5:47 PM
    #118
    John Cheong
    John Cheong Active Member
    East Bay, CA
    2001 SR5 PreRunner
    33" falken rocky mountian A/T, 3.5" fabtech lift, Deck plate mod, Painted badges.
    i have a 3.5" coil over lift on mine and its the stiffest and roughest ride ive ever been in. i cant wait until i can have some money to get em out of there
  19. Mar 21, 2012 at 5:48 AM
    #119
    Hootbro
    Hootbro Omnipotent
    Delaware
    2019 SR/SX Tacoma Access Cab 4x4 3.5L
    What are you, 12? Very mature. Did daddy leave his computer on?
  20. Mar 21, 2012 at 5:51 AM
    #120
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    You CANNOT run All Pro LT with 33's without fiberglass fenders. If you get out there and actually use the travel it will bash your stock fenders like a retard on a drum on a set.
