Fact or Fiction
Discussion in 'Detailing' started by Thorpedo26, May 5, 2011.
  1. May 5, 2011 at 8:11 PM
    Thorpedo26
    Thorpedo26 [OP] Well-Known Member
    Brandon Thorpe
    Justin TX
    2006 silver 4 cylinder
    Blacked out badges, weathertechs, painted grill, cut tailpipe, removed mud flaps, black head lights, red calipers, tinted tails, front and rear bilsteins are here along with fatbobs spacer and aal awaiting install, also a set of 16 inch pro comps are here and 265/75/16 dynapros
    i was looking up hail repair because i bought my tacoma with some hail dimples, i stumbled apon a diy where you put dry ice on the surface of the car where the dint is for a couple minutes then heat it with a blow dryer. the drastic temp change causes the dent to expand and pop out.:eek: is this possible? or a tall tail
    - Thanks Brandon
  2. May 5, 2011 at 8:17 PM
    Speed Nut
    Speed Nut Well-Known Member
    I'd give it a try. You can't make the damage worse.
  3. May 5, 2011 at 8:17 PM
    spares
    spares Canadian Bacon
    New Brunswick, Canada
    06 DCSB TRD Sport
    From what I gather, it works... how bad's the damage? could trying it really hurt? and if im not mistaken, they use a inverted can of compressed air for the cooling.
  4. May 6, 2011 at 7:41 AM
    Thorpedo26
    Brandon Thorpe
    Justin TX
    I might have me a weekend experiment then!!
  5. May 6, 2011 at 7:49 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I'd see if someone can confirm this... I'd be afraid of screwing up the paint job or cracking the paint.
  6. May 6, 2011 at 7:53 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Only really works on large dents. Smaller ones you'll have less luck with but give it a try. Instead of dry ice, take a can of compressed computer keyboard duster, turn it upside down and spray the affected area with it.
  7. May 7, 2011 at 12:43 PM
    georgeandkanoa
    georgeandkanoa the point is simply this
    jeff
    calgary
    07 tacoma trd
    bilstein5100's front tinted windows access cover pioneer stereo weathertechs grillcraft grill kc's behind cbi sliders
    keep us updated
  8. May 7, 2011 at 1:16 PM
    OffroadToy
    OffroadToy kokanee smoker
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    My last truck got nailed in a hail storm...more than 100 dents in the hood alone. I tried the dry ice on a 100 degree day and it didn't do a dam thing. Like mentioned it might work on larger dents. I also tried the keyboard compressed air without any luck.
  9. May 7, 2011 at 1:38 PM
    TACOMA TRD
    TACOMA TRD Well-Known Member
    Tom
    PA
    2011 MGM SPORT DC 4x4
    Alpine HU, Apline 6.5 3 way Speakers, Access Cover.
    If your talking only a few dents, I just had some PDR ( paintless dent removal) done on my truck. They guy did a amazing job. Had a big dent with the car door scratch in the center of my door, it was like it never happened when he was through. Even wet sanded the scratch and completly was gone. It was 75.00 for first dent, then like 20.00 for each additional. Not bad.
  10. May 7, 2011 at 1:40 PM
    TACOMA TRD
    Tom
    PA
    PS... Cheaper method... I used this once on my wifes car. It also worked. Picked it up at harbour freight. the method you claim I heard works, but you need to be careful.
  11. May 8, 2011 at 5:28 AM
    Thorpedo26
    Brandon Thorpe
    Justin TX
    No luck with the air can, im thinkin my hail dents are waaay to
    Small for it to "pop " will have to pay $ for pdr.
  12. May 8, 2011 at 10:09 AM
    Thorpedo26
    Brandon Thorpe
    Justin TX
    maybe ill give that pops a dent a try out of curiousity, going to do some research on it first.
