Factor 55 - added point of failure?
Discussion in 'Recovery' started by RevivalOL, Dec 18, 2017.
  1. Dec 18, 2017 at 1:18 PM
    RevivalOL
    RevivalOL [OP] Well-Known Member
    Pete
    Berkley, MI
    2017 TRD Off-Road DCLB
    Thinking about getting a Factor 55 flat link, and started to wonder if this introduces another possible point of failure in the line when winching. I get that it’s a closed system vs. a hook. But the hook connects directly to your tree saver, where you need to also add a shackle if you use a Factor 55. I haven’t seen these in use before, but am I overthinking this?
  2. Dec 19, 2017 at 12:43 PM
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    Overthinking it. The chances of failure under typical loads is incredibly small.
  3. Dec 19, 2017 at 12:46 PM
    90yota
    90yota Instagram: 90_yota
    Dixon, CA/Truckee,CA
    88 T4R / 15 F350
    Stock....ish
    Only thing to be worried about is making sure you installed the c clip correctly so the pin is locked in.
  4. Dec 19, 2017 at 1:01 PM
    RevivalOL
    Pete
    Berkley, MI
    Yeah the more I thought about this, a hook also has a pin that can fail, plus it’s an open system.
  5. Dec 19, 2017 at 1:03 PM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
    I always use a shackle on a tree saver strap, regardless of winch hook or link setup. you always want to hook metal to metal whenever possible. rigging 101.
    RogueTRD and RevivalOL[OP] like this.
  6. Dec 19, 2017 at 5:53 PM
    BlindingWhiteTac.
    BlindingWhiteTac. Well-Known Member
    Thomas
    Vancouver, WA
    07 LQ4 4L80E
    Just the essentials and no extra fluff.
    If you're using synthetic look at Factor55's "Splicer." When I get around to a winch that's the way I'm going.
