Factory 2017 Tonneau Cover loose by tailgate
Discussion in '3rd Gen. Tacomas (2016-2023)' started by cwilliams, Sep 9, 2016.
  1. Sep 9, 2016 at 7:12 PM
    cwilliams
    cwilliams [OP] Active Member
    Chris Williams
    2005 Tacoma 2WD 4CYL
    None yet
    The front is rock solid but the back can be lifted up about an inch. Is there a way to adjust this tighter? I took off the cover by the catch pins and they don't appear to adjust. Thank you kindly.
  2. Sep 9, 2016 at 7:36 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    I remember someone having this issue but they found out they weren't fully pushing down and locking the rear in. Not sure if there is an actual adjustment. Maybe the mount itself?
  3. Sep 9, 2016 at 7:44 PM
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
    If I remember correctly, you have to open tailgate, close cover and press securely, then close tailgate. I looked at this at the dealer when trying to figure out what options I wanted. There are much better aftermarket bed covers out there.
  4. Sep 10, 2016 at 4:28 AM
    cwilliams
    Chris Williams
    None yet
    Thank you VERY much you were absolutely right. I needed to close it first but then also give it a pretty good slam and it closes tight. I know a lot of folks diss this cover and I had owned a Extang Solid Fold which was really good but I don't find this cover bad at all. My solid fold worked the same way but I guess time will tell. I do like that it's covered under the 3/36 warranty also. Thanks again for the tip you really fixed me up!
  5. Sep 10, 2016 at 5:21 AM
    daddy_o
    Bossier City, La
    No problem, that's what this forum is all about.
