Factory 6MT Concerns
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Forestryguy, Jun 28, 2022.
  1. Jun 28, 2022 at 12:18 PM
    mauctopa
    mauctopa Well-Known Member
    I did the overland tune and 5:29s on my 6mt and it drives pretty good now. Reverse sucks still lol
    StandardTaco and BLtheP like this.
  2. Jun 28, 2022 at 12:19 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    What tires you running for the 5.29s?
  3. Jun 28, 2022 at 12:20 PM
    mauctopa
    33s but currently shopping for 35s
  4. Jun 28, 2022 at 12:21 PM
    BLtheP
    Plano, TX
    Cool. Drive pretty good on the 33's?
    Edit: Lol you already said it drives pretty good, so whoops. Guessing it's peppy at least.
  5. Jun 28, 2022 at 12:23 PM
    mauctopa
    yes , but depends on you expectations. Gas mileage took a hit but it off roads better imo
    BLtheP[QUOTED] likes this.
  6. Jun 28, 2022 at 12:24 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    Almost 5 years I have had my truck. I love it. I did 2 mods that make life with the transmission easier, I did the URD short shifter kit and the 2lo mod.. This was for my liking... not necessary. I prefer the shorter shifter throws and I like the option of 2 low when I need it. Previous 4x4's I had i would simply unlock the hubs... 2 low can help with vehicle control and clutch life driving in reverse up a slope.
    Neither of these are a requirement to drive the manual Tacoma. I always modify my vehicles to my liking.... I still enjoyed the truck stock and never even considered an automatic version.
    Your fears are unfounded and if the info is from TW, then it is from a small subset of people like me the enjoy modifications to make thier vehicle work more for them... we are definitely not normal...
    OZ TRD, 02Duck and doublethebass like this.
  7. Jun 28, 2022 at 12:31 PM
    bigoldbeef
    bigoldbeef Well-Known Member
    18 DCSB OR MT, 22 DCSB OR AUTO
    I’ve got an auto & a manual. If you ever tow anything & live in a hilly/mountainous area get the auto.
  8. Jun 28, 2022 at 12:33 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    The problem is more the engine than the transmission. Old school truck engines got their torque at much lower rpm. And both transmission and axles were geared lower 30 years ago. But manufactures have tried everything to squeeze 1-2 more mpg's out of them at the loss of performance.
    Newer engines are designed to work better with automatics than manuals. An old school truck often got max torque at engine speeds as low as 2000 rpm. A 3rd gen Tacoma needs 4600 rpm. Combine that with higher axle and transmission gear ratios makes it a lot harder to get a manual moving forward or in reverse. This is particularly true when backing up inclines. Doing so with a trailer is near impossible. The torque converter in an automatic eliminates this issue.
    Here is the short version. If you want to drive your Tacoma like a sports car then a manual might suit you. If you want a truck to tow or do work with you want an automatic. NO ONE uses a manual anymore for serious towing or hauling. Virtually all big trucks on the road including busses and even 18 wheelers are now using automatic transmissions because they work better. You haven't been able to buy a 3/4 or 1 ton truck in 20 years with a manual. And some of those pickups are rated to tow 30,000 lbs.
    And if you don't like the way your automatic shifts there is no law saying you can't manually put it in the gear that works best for you at the time. They can be used just like a manual, just without the clutch.
  9. Jun 28, 2022 at 12:45 PM
    Forestryguy
    Forestryguy [OP] Well-Known Member
    2022 SR5 Access Cab 4x4
    Great info, I am beginning to think members of this forum are a little more “fine tuned” with there trucks than me.
  10. Jun 28, 2022 at 12:48 PM
    CalcityRenegade
    CalcityRenegade Well-Known Member
    Calgary, Alberta, Canada, Earth
    2023 T4R ORP KDSS
    Do I like driving it better with certain upgrades/mods? Yes. Would I still drive it without those mods? Also yes.
  11. Jun 28, 2022 at 12:49 PM
    Forestryguy
    I definitely will be using my truck for work/ driving like a truck. Have no interest in “sports car driving”. I thought the manual would be better for towing
    OZ TRD, 33yrsoftoys and Junkhead like this.
  12. Jun 28, 2022 at 1:03 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Here we go again with car/truck engine BS…
    tstack22, doublethebass and GBR like this.
  13. Jun 28, 2022 at 1:04 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    MT is better for towing if you have super low first and R, IMO of course.
    That’s why 2WD low mod on MT tacoma makes a world of a difference.
  14. Jun 28, 2022 at 1:51 PM
    danojeno
    danojeno Well-Known Member
    Inland Empire, CA
    2017 Tacoma CCSBORMT Silver
    Elka 2.5DC Camburg UCA Deaver AAL 275/70/17 KO2s
    I love my MT, but that doesn't mean it can't be made better. I plan to do the accumulator delete, tune and re-gear. I've wasted tons of money changing other aspects of the truck, might as well do this stuff too.
    doublethebass likes this.
  15. Jun 28, 2022 at 3:45 PM
    #35
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    My ranger had 207 hp at 5k RPMs and 236 tq at 3200 RPMs, definitely not fast. Decent low end though, high end was non existent. Surprisingly K&N Intake and exhaust actually made a difference.
    I really did not like the reverse on my taco so I installed 2WD low mod, lifesaver. Otherwise I have no issues with the gear ratios. Second could’ve been a hair lower but really it’s fine for me.
  16. Jun 28, 2022 at 3:46 PM
    #36
    33yrsoftoys
    33yrsoftoys Over 40yrs now
    joel
    mid Michigan
    2021 dcsb off road 6 speed manual
    Bilstein 6112's 5th clip 1/4" spacer driver's side. Icon tubular UCA's with Delta joint, wheelers superbumps, ECGS bushing. Allpro standard leaf packs, 5160's, U bolt flip kit with wheelers super bump's, extended stainless steel brake lines, carrier bearing drop. Icon rebounds 17" with Nitto terra grappler G2's 285/70/17's.
    If you like the manuals, you should get a manual. You'll be fine towing, within toyota specs. As far as the automatics are concerned, just do a Google or tacomaworld search on them. There's literally a whole cottage industry that's sprang up, trying to fix their shift times, holding a gear, or not, when to shift, how hard of a shift,,,,. With the manual you don't have any of those problems, you get to make those decisions yourself in real time. That's some of the reasons I chose a manual. Hope this helps.
    OZ TRD, Irons and doublethebass like this.
  17. Jun 28, 2022 at 3:47 PM
    #37
    GBR
    GBR Well-Known Member
    19 TRD OR
    People act like because peak torque comes at 4600 rpm it doesn't have anything below that. Torque is down a whole 15-20 lbs below peak at 2000 rpm.
  18. Jun 28, 2022 at 4:17 PM
    #38
    forana
    forana Well-Known Member
    Kaneohe, Hawaii
    2022 DCSB OR Lunar Rock
    No money, all went to truck...
    I came from the 2nd gen MT and I can say the 3rd gen MT is substantially better. Super fun to drive. I hear good things about the accumulator delete mod but it's a little out of my comfort zone so haven't done it. Is it fine to drive 100% stock? Of course it is. Really fun. But this is TW so you can assume everyone will be screaming to do MODS, TUNES, etc...
    I got the sprint booster and it made driving better but really OK with stock too.
    Also, try find a new truck with a better MT right now....
  19. Jun 28, 2022 at 4:18 PM
    #39
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    I barely go over 2500 RPMs unless I need to pass someone. I really don’t know what that guy is talking about. I can’t even imagine driving around at 4600 rpms haha.
    bush rat, OZ TRD and oneikr like this.
  20. Jun 28, 2022 at 4:19 PM
    #40
    DingleTower
    DingleTower My truck is like yer truck
    Manitoba
    Pro MT - Lunar Rock
    Still haven't done the ADM. Will probably do it in the fall but don't really mind it as is. A friend drove my truck this weekend and was pretty impressed with the transmission. Though we come from farm trucks so take that for what it's worth.
    Reverse isn't that bad. I have done the 2Lo but really only use it for the trailer and even then it's rare.
    Junkhead likes this.
