Factory Alarm Issue
Discussion in '3rd Gen. Tacomas (2016-2023)' started by sidd76, May 9, 2022.
  1. May 9, 2022 at 4:40 PM
    sidd76
    sidd76 [OP] Member
    2017 Tacoma SR5 extended cab long bed 4x4
    I've got a factory alarm by "Tracker" on my 2017 SR5 tacoma, bought car brand new. I started noticing issues arming the alarm from the key fob a few weeks ago. The problem is intermittent. Sometimes I can arm my alarm and sometimes I can't. I have to walk around and away from my car until I get to the perfect spot and then I can arm the car.
    Replaced battery on my 3 button H chip remote key fob and tried using a backup 3 button H chip remote key fob with new battery that I had as a spare. Nothing works.
    Is there a transponder or an antenna that I need to replace inside the car, or is there a way to reset the alarm system?
    I'm also thinking about just getting a new alarm system and having the factory one taken out.
    Anyone run into the same problem? What options do I have? I'm really open to suggestions and ideas.
    Thanks in advance.
  2. May 9, 2022 at 5:26 PM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    The factory alarm is Toyota OEM not tracker. So it sounds like you might have a dealer add on alarm. If it really is an add on, there are so many ways to wire them that I’d personally look at pulling it out first, go back to stock and see how things work. With an luck they used a harness plug-in and you don’t have to rewire anything, just move some connectors about.
    Chew likes this.
  3. May 9, 2022 at 5:45 PM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    You add any new leds or something else that can be interfering?
    Chew likes this.
  4. May 9, 2022 at 5:50 PM
    JJ Diablo
    JJ Diablo Well-known member.
    JJ.
    CT
    2021 Cement TRD Sport Premium
    BOSS HTX Snowplow, Bilstein 5100s, Vled reverse light kit, Vled interior lighting, FitCamX dashcam, Timbren SES
    Agree . “Tracker” is not a factory alarm. Find Tracker customer service and contact them. They should be able to get you in touch with a dealer who services that brand for help.
    Chew likes this.
  5. May 9, 2022 at 6:40 PM
    sidd76
    sidd76 [OP] Member
    @Diablo169 Ugh I hate going to the dealer. Thanks letting me know that Tracker is not factory didn't know that. I figured I bought the car new and figured it was a factory alarm not dealer installed. That makes sense. I was not familiar with that brand.
    @RX1cobra The only thing I installed was raptor lights from Cali-Raised. How can that affect my alarm?
    @mutely Thanks for info. I think I'm just going to take it to a car audio shop and just have them replace the alarm. I can do it myself but honestly I don't have the time, but I do have the money.
    JJ Diablo likes this.
  6. May 9, 2022 at 7:07 PM
    RX1cobra
    19 OR
    LEDs can give off interference that can weaken the fobs range. If this started happening after their install unplug them and see if it changes anything.
  7. May 9, 2022 at 7:24 PM
    Clearwater Bill
    Billy
    Largo Florida
    Remove the alarm to the trash, dont bother replacing.
