Factory alarm system going off
Discussion in '3rd Gen. Tacomas (2016-2023)' started by InfernoTacoCO, Sep 4, 2023.
  1. Mar 7, 2025 at 11:33 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    You could probably pull the fuses easier than unplugging the horn. There were 2 in our 4Runner which were promptly pulled while working on the battery issue that caused it to go off in the first place.
  2. Mar 7, 2025 at 11:43 AM
    oogielaflick
    oogielaflick Well-Known Member
    Keith
    2019 Toyota Tacoma TRD Sport 4-door; Prvious 23 year owner of 1996 Tacoma
    Quicksand with hood protector, color matching decals on tailgate latch, mudflaps, glovebox, and tailgate hitch cover.
    I actually ended up just unplugging the horn. Someone here said that for factory installed alarms, they put an additional horn on the right side under the hood, next to the fender. Sure enough, I looked and there it was! So for now, I just unplugged the horn. It was not hard once I figured out how to unplug it! So far,so good...
    InfernoTacoCO[OP] likes this.
  3. Mar 7, 2025 at 1:41 PM
    RedWings44
    Michigan
    Yeah there's a fuse for each one under the hood too. Then you don't have to worry about introducing moisture and corrosion into the connectors if you ever want to use them again.
  4. Mar 14, 2025 at 4:55 AM
    InfernoTacoCO
    InfernoTacoCO [OP] Well-Known Member
    Hannah
    Denver, CO
    2017 Inferno Orange Toyota Tacoma TRD Offroad
    Westcott Design 0° Sliders, Falken Wildpeak AT3’s, OTT Tune, Interior/Exterior LED lighting, Raptor Lights, WeBoost 4G-M Signal Boost Amp, Trail Grid Pro Front/Rear Anytime Camera, OEM Tailgate Actuator & Wiring, 20% Ceramic Tint.
    take it to the shop and have them check the wiring on that driver door, door sensor wire. Chances are it is grounding out and causing the alarm to trip.
