Factory alarm went crazy on me!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by locster, Jan 3, 2015.
  1. Jan 3, 2015 at 2:02 PM
    locster
    locster [OP] Well-Known Member
    Luke
    Orange County, CA
    2014 DCSB 4x4
    I pressed the key fob to lock the door and the car horn just went off nonstop. I had to unplug the battery to shut it off, and now I can't plug it back in without it going off again.
    Is there a way to turn off the factory alarm or reset it? I can't use my truck now. I still have full factory coverage on it, but I can't even drive it to the dealership if I wanted to.
    What would cause it to trip the car horn like that? A bad ground?
  2. Jan 3, 2015 at 2:42 PM
    TacomaRobert
    TacomaRobert Well-Known Member
    Can you disconnect the horn? Or does the alarm shut the system down? Try using other key ... keeping this one way out of range?
  3. Jan 3, 2015 at 2:46 PM
    WeberSarge
    WeberSarge Well-Known Member
    Kevin
    Ohio, Illinois
    '08 SR5 TRD 4X4 Quad Cab , '77 FJ40
    Stock for now...
    I'll bet the button is stuck on the remote..
    Sarge
  4. Jan 3, 2015 at 2:50 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    X2
    My first thought.
  5. Jan 3, 2015 at 4:09 PM
    locster
    Luke
    Orange County, CA
    2014 DCSB 4x4
    I removed the horn relay, and everything still works fine. But as soon as I drop the relay back, the horn goes off.
  6. Jan 3, 2015 at 4:21 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Is the horn constant or is does it go on and off?
  7. Jan 3, 2015 at 4:32 PM
    locster
    Luke
    Orange County, CA
    2014 DCSB 4x4
    Constant on when it goes off.
  8. Jan 3, 2015 at 5:39 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    Sounds like the relay to me. Mine did the same thing a month ago. Swapped the relay and haven't had a problem since.
    Electrical should be under warranty, correct me if I'm wrong guys. If nothing else is effected, I'd pull the relay and take the truck to the dealer. That way they can put a new one in and it will be there if it is another issue with the electrical system causing it.
  9. Jan 6, 2015 at 5:52 AM
    hotrod53
    hotrod53 Well-Known Member
    Lynd
    Pittsburgh, PA
    ‘14 DCLB Sport, ‘18 TCH, ‘13 TCH
    Weathertech floor liners moded to hold OEM floor mats, weathertech vent visors, Toyota bed mat, LEER 100XL cap, hood gasket mod to stop whistling.
    Doesn't the alarm typically give you an intermittent beep..beep..beep alarm? If so I would agree that the contacts in the relay got welded shut.
