Factory Alignment for a TRD OR Double Cab Short Bed
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jodadell, Aug 28, 2020.
  1. Aug 28, 2020 at 5:55 PM
    Jodadell
    Jodadell [OP] Member
    Oregon
    2018 TRD OR
    Hi guys, does anyone has the print of the Factory alignment for a Tacoma TRD OFF-ROAD without lift or bigger tires? please I need the exact numbers and not a range, thanks.
  2. Oct 13, 2020 at 2:07 PM
    Scott4032
    Scott4032 Well-Known Member
    Michael
    2020 SR5 4x2 V6
    coming soon!
  3. Oct 13, 2020 at 2:21 PM
    helix66
    helix66 Well-Known Member
    DPRC
    2017 DclB TRDor MgM
    ProGrille,MesoStuff,Tinted,AllPro sliders, RCI ALL skids, BAMF diff skid, KDmaxPro tune, Demello bumper, Warn evo10s, BD s8 & squadrons, Accutune UCAs, Fox 2.5pes, Eibach & Deaver
    Would a long bed work for you?
    I got new tires a few months ago and it was pulling so I had the dealer do an alignment. I think is partly the tires, Cooper sttMaxx 255/85/16
  4. Oct 13, 2020 at 5:39 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I’m not sure what you mean. Most mechanical specs have tolerances.
  5. Oct 13, 2020 at 5:46 PM
    20limited4x4
    20limited4x4 Member
    Central NC
    2020 Silver Sky Tacoma Limited 4x4
    Look for the service manual that’s floating around here. IIRC it was a link to a google drive. It’ll be under the section titled “Suspension: Front Wheel Alignment: Adjustment”.
    If you can’t find the manual, let me know your truck’s model code and I’ll paste it here.
  6. Oct 13, 2020 at 5:57 PM
    Bcjammerx
    Bcjammerx I'm not ALWAYS an a-hole, I swear
    North East Texas
    ‘17 TRD Off-road 4X4
    bigger tires or lift don't matter...why would they? No matter your setup your caster/camber/toe should be at factory specs bruh, and they ONLY give a range, not ABSOLUTES! When I was a tech I strived to get in the middle of that range...but it's a range, best you can get
    ...oh you're lifted 3" better run that camber -2" and caster -3...NOT
    Oh and have you heard of "google"?
    https://www.tacomaworld.com/threads/alignment-specs.540392/
    https://www.tacomaworld.com/threads/alignment-specs-for-a-2019.589515/
    legit 5 seconds of google time ;)
    i should apologize...I'm an asshole but hey...fuck you...I mean...my bad
    Skydvrr, JasonLee and 20limited4x4 like this.
  7. Oct 13, 2020 at 5:59 PM
    Bishop84
    Bishop84 Well-Known Member
    I bump up toe with bigger tires, but thats it. Usually a touch of positive camber and the most caster I can get.
  8. Oct 13, 2020 at 6:03 PM
    Bcjammerx
    North East Texas
    Why? pos caster results in worse handling, pos camber results in outer tire wear and worse handling also...neg camber...TO A POINT...in RACE CARS improves cornering. And anything but ZERO toe (pos or neg) results in increased tire wear! Toe is how STRAIGHT FORWARD your tires are...
    neg toe your tires are like / \
    pos toe they are like \ /
    what the hell man? what led you to this thinking?
  9. Oct 13, 2020 at 6:18 PM
    Bishop84
    Spec is positive camber bro.
    Caster does not reduce ride quality, and with a slightly larger tire it lets you keep the mudflaps. I'm not saying add a full degree, I'm saying 2.5-3.0 is better than 1.5-2.0. Better highway stability, less bump steer are associated to higher caster.
    Toe opens up as you drive, so 0.00 degrees does \ / this while you push forward down the road. Bigger tires push outwards more. So you end up with negative. Also toe wears to the negative so I set it higher to wear towards zero, not to negatives.
    Skydvrr, CBrob and Bcjammerx[QUOTED] like this.
  10. Oct 13, 2020 at 6:27 PM
    Bcjammerx
    North East Texas
    apologies...i hyperbole sometimes (and by sometimes I mean all the time as I hyperbole all the time apparently) and I *edit added*-->incorrectly assume others do too...you didn't mean -5 degrees camber etc etc....i see that now
  11. Oct 19, 2020 at 8:22 AM
    CBrob
    CBrob Well-Known Member
    Rob
    stock 2003 and stock SR 2020
    not a single mod
    The opinions on alignment are so diverse!
    I personally think you have it tight
    Getting an alignment today....
    Bishop84[QUOTED] likes this.
