Factory Batteries
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wood714, Aug 15, 2023.
  1. Aug 15, 2023 at 12:42 PM
    wood714
    wood714 [OP] Got any Quaaludes?
    Kevin
    East Coast Florida
    2018 4x4 V6 SR5
    I remember a thread a couple years ago about peoples factory battery only lasting a couple years.
    Just got back from having Toyota do a oil change and asked them to check the battery. Did the same last time.
    They said it's perfect. Bought the truck new on Halloween 2018.
  2. Aug 15, 2023 at 12:45 PM
    greg8765
    greg8765 Well-Known Member
    Greg
    Utah
    2023 Tacoma TRD Off-Road
    Tuff Country Lift, Smart Cap, Tint, Pop & Lock, Door Sill Decals, Rooftop Tent
    2016 - Original battery - Still running strong.
  3. Aug 15, 2023 at 12:52 PM
    BabyBilly
    BabyBilly Well-Known Member
    Billy
    2020 Pro
    3 years of SC summers on my factory battery with no issues. I thought I had a dead battery last year, but I cleaned the corrosion off the terminals and it came right back to life.
  4. Aug 15, 2023 at 12:55 PM
    ernscott
    ernscott Well-Known Member
    2021 Tacoma
    Eventually the alternator will self destruct, because it is overworking itself. I'v seen many go right into overheat mode when I would put them in GM busses with older batteries. The batteries checked good and the vehicles had no trouble starting. Soon as I would replace them the alternators would run cool to the touch. Maybe Toyota is a different beast ? I'v always been on the replace batteries side of the fence. A lot is depending on that battery. Best of luck in your quest.
    Deeahgee and LeakyAC like this.
  5. Aug 15, 2023 at 12:56 PM
    LeakyAC
    LeakyAC Captain jackass
    2016 SR5 Access Cab 2.7 4x4 Super White II
    -Uni filter secondary air pump mod -A/C drip line extension mod -ARB F + R diff breathers relocated -ARB front recovery point -"Tow Package" class V receiver + oem 7/4 plug + aux ATF cooler -Toyo Open Country ATIII 245/75R16 -Yellow fog lights (amber Lamin-X w/ PIAA amber H16s) -BakFlip G2 tonneau cover -TRD Pro grille -Body-matched bumper caps -Blackout emblems -Husky X-Act Contour floor liners -RokBlokz mud flaps -oem bed mat Not yet installed: -0" lift Bilstein 5100 F + R w/ 4Runner front shock lower bolt swap -Total Chaos LCA cam tab gussets
    why do that to yourself tho, batts are pretty cheap
    Chew and ernscott like this.
  6. Aug 15, 2023 at 12:57 PM
    ernscott
    2021 Tacoma
    Compared to the trouble ahead !!
    Chew and LeakyAC like this.
  7. Aug 15, 2023 at 12:58 PM
    BabyBilly
    Billy
    2020 Pro
    have multiple vehicles and don't need to spend money for no reason?
  8. Aug 15, 2023 at 1:02 PM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    I swapped out a perfectly good OE battery for a AGM last year on my 18. For me, I don't want to be dead-cell stranded, so I change lead-acid batteries at 4 years and AGMs when I can hear the starter slow down.
    ernscott likes this.
  9. Aug 15, 2023 at 1:02 PM
    ernscott
    2021 Tacoma
    Now let's talk oil change intervals. Working on multiple vehicles and seeing the more pricy repairs due to lack of maintenance has always been my guide. But to each his own. I will never be sold on lack of it.
  10. Aug 15, 2023 at 1:05 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    My 2010 got 10 years just about on the OEM. Never a hard start even until it died one day. Replaced it right away.
    Pisser is that the replacement didn't last 4 years and I didn't buy a cheapo. Oh well..replaced it and got on with my life.
  11. Aug 15, 2023 at 1:06 PM
    BabyBilly
    Billy
    2020 Pro
    5k for the FI vehicles, 10k (or once a year) for NA vehicles.
    FWIW I agree with you on the maintenance. I've never had a dead battery damage anything, much less kill an alternator. If that happened to me I'd probably change my tune.
    ernscott[QUOTED] likes this.
  12. Aug 15, 2023 at 1:06 PM
    MM_Trkr2020
    MM_Trkr2020 Paddler
    Michael
    GA
    2020 SR5 DCSB 4x4
    ARE Shell with Yakima Racks
    I have the original battery in my truck that was bought new in 2020. It is 3-1/2 years old and still doing fine. I've never had a battery last more than 3 or 4 years in any vehicle I've owned. This summer I drove my Tacoma from Georgia to Idaho. Put 5,000 miles on that trip. I was concerned that the battery might cause problems, but it's still doing fine.
  13. Aug 15, 2023 at 1:07 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    My factory battery developed a bad cell in just under 3 years. I got a new Toyota battery under warranty and it is almost 5 years old. My opinion is Toyota batteries are hit or miss on how long it lasts.
    TacoSR523 likes this.
  14. Aug 15, 2023 at 1:09 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Less than 2 year old truck, just replaced mine because it was making weird startup noises and leaking acid out the top. I suppose all aren’t so lucky unfortunately.
  15. Aug 15, 2023 at 1:09 PM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    2010 with 187K miles. Original alternator which puts out the required voltage around 14.x (depending on the state of charge). I'm on me 3rd battery which is perfectly normal. Batteries older than 5 years have less capacity for sure. No way a lead-acid battery starting battery living in a hot environment will last like a deep-cycle living in 60 degrees and constantly checked for low electrolyte. The Autozone Duralast battery is the exact OEM replacement. If you spend anything more you are wasting your money. Go and pay twice as much for a AGM type battery and get 10% more life. They will die like any other battery. Someone will say "I have an optima and I'm on my 7th+ year". Possible but not average. I have a Trojan 100A flooded lead-acid deep-cycle battery that runs my trolling motor. It's 15 years old and still runs my fishing motor longer than my bladder holds out. It never goes lower than 50% discharged. It's a totally different environment than a hot engine bay.
  16. Aug 15, 2023 at 1:11 PM
    LeakyAC
    Being left stranded somewhere sucks.
    On another note, you own multiple vehicles however $100 on several years of insurance that your vehicle will start is "no reason"?
    Interesting logic....
    Chew likes this.
  17. Aug 15, 2023 at 1:15 PM
    jimmy c
    jimmy c Well-Known Member
    jim
    Port St. Lucie Fl.
    2015 tacoma
    I live in south east fl. My original battery lasted 1 year to the day. Next battery lasted 3 years . I have a 2014. replace every 3 years. I am a certified auto tech working on cars every day. Due to the heat down here, we normally get 3 years on a quality battery. If your pushing 5 years on yours, i would suggest changing it out. I have seen batteries from up north last upwords of 10 years. They dont have the constant heat we do.
  18. Aug 15, 2023 at 1:18 PM
    LeakyAC
    My car lives outside through the -20c winters without a block heater or anything. I usually get about 3 years from a 27f conventional acid batt.
  19. Aug 15, 2023 at 1:18 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Assuming..
    My still going strong since October 2017.
    I still have original 12v battery on 2011build hybrid (12v battery is used to start the engine).
  20. Aug 15, 2023 at 1:19 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    2107, still same Battery. Colder than Hell winters, and Hotter than Hell summers.....
    BlackTRD4Me and Bigfsur like this.
