Factory Batteries
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wood714, Aug 15, 2023.
  1. Aug 15, 2023 at 1:20 PM
    LeakyAC
    LeakyAC Captain jackass
    2016 SR5 Access Cab 2.7 4x4 Super White II
    -Uni filter secondary air pump mod -A/C drip line extension mod -ARB F + R diff breathers relocated -ARB front recovery point -"Tow Package" class V receiver + oem 7/4 plug + aux ATF cooler -Toyo Open Country ATIII 245/75R16 -Yellow fog lights (amber Lamin-X w/ PIAA amber H16s) -BakFlip G2 tonneau cover -TRD Pro grille -Body-matched bumper caps -Blackout emblems -Husky X-Act Contour floor liners -RokBlokz mud flaps -oem bed mat Not yet installed: -0" lift Bilstein 5100 F + R w/ 4Runner front shock lower bolt swap -Total Chaos LCA cam tab gussets
    it's a literal matter of time.
    keep an eye on your trip odometers, when they reset to 0 after shutting the car off, go buy a new batt pronto.
    BlackTRD4Me, David2431 and ernscott like this.
  2. Aug 15, 2023 at 1:21 PM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    To me the life of a battery depends on a number of factors. All of the factors together will determine life. Most people will find their battery life or years is pretty constant for them:
    • where you live, temperature plays a large factor
    • miles driven + time sitting at and idle
    • how often start cycle is engaged
    • amount of power draw, after market electronics can pull a lot of power.
    • to me brand and price you paid has little effect
    • other factors that don't come to mind
  3. Aug 15, 2023 at 1:25 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    We take a scientific method. Checking battery voltage via obd2
    ABA180 likes this.
  4. Aug 15, 2023 at 1:27 PM
    LeakyAC
    fancy!
  5. Aug 15, 2023 at 1:34 PM
    Vlady
    Issy, WA
    Trying to be infront of the truck..
  6. Aug 15, 2023 at 1:44 PM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    Replaced mine after 2.5 years. ( 2021 SR5 ).
    Replaced the wife's Subaru after 2.5 years the same day.
    It's a thing.
    In June of 2025 I will replace both of them again.
    It's a thing.
    The entire month of July was 110~119 in Arizona - we just don't dck-around with waiting to see how much
    life we can get out of a battery. Every 2 years. It's a thing.
    MannyS, Chew, ernscott and 1 other person like this.
  7. Aug 15, 2023 at 2:01 PM
    BabyBilly
    BabyBilly Well-Known Member
    Billy
    2020 Pro
    I agree, and if I was getting some slow starts or had reason to believe the battery was bad I'd replace it. I also carry a jump booster in the truck if it does decide to crap out, and run a scangaugeII so I can always see the voltage and trans temps.
  8. Aug 15, 2023 at 2:06 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    In my professional experience, I’d say the average battery life is ~5 years. Seen them last anywhere from a month to maybe 12 years max. A lot of times they die out on the dealer lots and get jumped or replaced.
    Weather and use/deep cycles also play a big role on how long they last
    David2431 likes this.
  9. Aug 15, 2023 at 2:18 PM
    wood714
    wood714 [OP] Got any Quaaludes?
    Kevin
    East Coast Florida
    2018 4x4 V6 SR5
    I keep a NOCO jumper thing in my truck, just in case.
    I live in NE Florida, but the truck is kept in my garage. My 2000 TJ set outside and I had a Advance Auto Silver Series battery in it. After 7 years it was still going strong, but I replaced it right before we were expecting a hurricane...just in case.
    LeakyAC likes this.
  10. Aug 15, 2023 at 5:17 PM
    PilotguyPA28
    PilotguyPA28 Well-Known Member
    Trip
    2020 Metallic Gray Limited
    A month after I bought my 2020 Limited the battery was dead. Opened the hood and there was almost zero water in it. Jumped it and took it to the Toyota dealer who tested it and said it was ok. If I didn’t start it in 5-7 days it was weak. Did this for 2 years and finally had it tested again. Said it didn’t test bad so no warranty battery. I finally bought a new 7 year battery. Now I can let it sit for 2 weeks and still get a strong start. Pitiful OEM batteries.
  11. Aug 15, 2023 at 5:20 PM
    Tacospike
    Two Trucks
    My original lasted 28 months
    BLtheP likes this.
  12. Aug 15, 2023 at 6:04 PM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    I love a good battery thread...my battery has been chugging along since 2017
    BlackTRD4Me, Bigfsur and BabyBilly like this.
  13. Aug 15, 2023 at 6:05 PM
    Taco_mike73
    Taco_mike73 Well-Known Member
    York, PA
    2020 Cement SR5 DCSB 4x4
    Lomax tonneau cover, oem bed lights, AJT Design chrome delete, black out badges & tailgate letters, AVS hood deflector & vent visors, Solkie tech hood supports, interior LED lights, Tufskinz mud guards, RedArc TowPro Liberty, bed mat, kicker speaker upgrade, Hikari ultra H11 low beams, Diode Dynamics SS3 fogs in yellow, Meso customs total taillight stage 1. Coming soon: Compact powered sub install Future mods planned: bigger tires (265/75/16) BILLSTIEN 5100 lift
    I was having issues with the factory battery leaking from the top and making a big mess. Had lots of white crusty stuff on the battery terminals, cables and the hold down bracket. I kept cleaning it with the NOCo cleaner. Then put those NOCo anti corrosion pads and the anti corrosion spray. Still the thing leaked.
    I said something about this to the service advisor at my 15,000 mile service and they agreed that shouldn't happen and replaced it with a 7 year Toyota sure start battery under warranty.
  14. Aug 15, 2023 at 6:06 PM
    BabyBilly
    Billy
    2020 Pro
    you mean you aren't concerned about the alternator self-destructing?
    9th[QUOTED] likes this.
  15. Aug 15, 2023 at 7:36 PM
    #35
    monoman
    monoman Time to get dirty!
    Dave
    Exotic, San Jose, Cal.
    2018 Silver Sky Tacoma SR Access Cab 4X4
    SnugTop SuperSport shell CaliRaisedLED light bar BFG K02 AT’s RCI skid Bilstein 5100's up front, (#2) & 4600 in rear N-2 Designs remote start/keyless entry Anytime 12v outlets... one by shifter & one in bed Daily driver....
    So this morning when I started up my truck for work, it seemed to struggle starting up. Hmmmm. My Tacoma is a 2018 & it appears to be the original battery (bought the truck 2 years ago) so I figured I’d probably be getting a new one soon. I get off work & go to start my truck & nothing…got a jump so I was able to get home. It’s been pretty hot lately so the heat most likely did it in. Bought an AGM like the one I bought for my last Tacoma, had no issues with that one.
  16. Aug 15, 2023 at 7:40 PM
    #36
    316sherm
    316sherm Well-Known Member
    South Louisiana
    2020 Tacoma SR TSS Package 4 Cyl
    Almost 3 yrs and stock. Extreme heat here with mild winters for what it’s worth. I never replace a battery until it’s dead, but I also keep a jump charger with me.:cheers:
  17. Aug 16, 2023 at 12:00 AM
    #37
    Garrett75x
    Garrett75x Well-Known Member
    Torrance
    2017 TRDOR 4x4 JBL P&T
    Pro Grille, Shmellfab rock sliders, Carhartt seat covers
    Costco Interstate enters the chat, 3 years no questions asked warranty and they tell you to bring it in for a new one right before the 3 year mark ;)
    OEM lasted 5 years on my 2017 and showed a little hesitation before I swapped it out for confidence
    monoman and LeakyAC like this.
  18. Aug 16, 2023 at 7:08 AM
    #38
    monoman
    Dave
    Interesting. That's pretty cool. Any chance you know who makes that battery for Costco? :confused:
  19. Aug 16, 2023 at 7:42 AM
    #39
    LeakyAC
    Some fools on here including some clown of a mod harassed me not long ago here for telling people about Costco batt warranty hahaha what dumpster fire this place is.
    Btw most car batts are made by the same makers...Delphi, Johnson Controls etc
    monoman[QUOTED] likes this.
  20. Aug 16, 2023 at 7:43 AM
    #40
    TartanEagle
    TartanEagle Well-Known Member
    '17 ACLB 4x4 MT
    My Taco is a December 2016 build with a January 2017 purchase. Still on original battery.
    Have had two years in Colorado and four in Georgia, so both cold & hot climates.
    It is still going strong.
    Until it doesn't. That's when I'll replace it.
    Not a fair comparison, but I always got 10 years out of each Honda Civic battery (owned it from '93 until '23).
    shakerhood and Bigfsur like this.
