Factory Bed Divider
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pudge, Dec 26, 2010.
  1. Dec 26, 2010 at 1:03 PM
    pudge
    pudge [OP] Well-Known Member
    Pudge
    Enfield
    Super White Tacoma TRD Pro
    I recently purchased a factory bed divider for my 2010 trd sport. Install was easy enough, but it does not seem to want to slide up the railing. Checked the instructions that were included which tells you to loosen all the threads but it still seems to be stuck at the wheel wells, anyone have the same problem?
  2. Dec 27, 2010 at 3:47 PM
    cotaco05
    cotaco05 Well-Known Member
    Jeff
    CO
    '17 Double Cab Off Road
    I have one on my 05 and I noticed that sometimes the square nuts on the bed divider that sit in the bed rail system can get caught in what seem to be drain holes on the underside of the divider. You should be able to manuipulate the square piece so that it is parallel with the bottom of the bed rail and gently slide the divider forward. Also, it tends to stick if it's not pretty straight in the bed. Hope that helps!
  3. Dec 27, 2010 at 4:17 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    yep,me to.
  4. Dec 27, 2010 at 5:19 PM
    penguins_cc
    penguins_cc Well-Known Member
    Will
    Bellevue, WA
    Timberland Mica Limo!
    Perkins Performance Sliders, Warn 9000, Brute Force Fab front & rear bumper, OME/Dakar lift, full ATO skids and hi-lift mount, satoshi, Wet Okoles, illuminated 4x4 switch, Diff Breather.
    Well written, cotaco05. Only other thing I would add is that I loosen the threads wayyy more than you would think of needing, which seems to help. This thread is giving me an idea to use the cargo divider as a place to mount shovels and hi-lift though (because I can use small strap through the mesh to hold everything)....
  5. Dec 27, 2010 at 6:46 PM
    cotaco05
    Jeff
    CO
    Thanks penguins_cc . I think it would work well as a mounting platform for tools and the like. That's something I've been thinking about doing too. Let us know how it goes if you end up doing anything with it.
  6. Dec 27, 2010 at 10:33 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
  7. Dec 28, 2010 at 5:30 AM
    Jimsc
    Jimsc Well-Known Member
    Jim
    Greenville, SC
    10 PreRunner Double Cab
    Aries Nerf Bars, Cargo Seperator
    I ground down the edges of the slider bolts so they don't get stuck in the drain holes. Works much better now.
  8. Dec 28, 2010 at 5:38 AM
    Jere
    Jere Outdoorsman
    Northern Chester County, PA
    '10 Access SR5 4x4 4cyl
    I have a Trifecta cover, which uses similar slider blocks in the track to attach the front of the cover to. I found that if I wrench the cover blocks on too tight that they crimp the inner edges of the track a little, and then are stubborn about sliding. I probably shouldn't have been quite so aggressive, but I was only using a small hex wrench, and I was assuming I didn't want to risk my cover flying off at 70mph. Anyway, I found that I needed to use something to punch the sliding block back into the track a little to make sliding easier. I didn't have to take the anchor off, just loosen it quite a bit, then tap it with heal of my hand to push the block/nut out of the crimp I had made.
