Factory brakes vs Aftermarket??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by aidenhardcore, Oct 30, 2012.
Poll closed Nov 29, 2012.
  1. factory
    29 vote(s)
    56.9%
  2. aftermarket
    22 vote(s)
    43.1%
  1. Oct 31, 2012 at 10:27 AM
    aidenhardcore
    aidenhardcore [OP] Well-Known Member
    mike
    boston,ma
    2017 trd off road
    None yet but soon all black.
    Damm you tw people for having your brakes last that long lol. Everyone I talked to said there getting 60 to 80k on there brakes and I'm at 34k and need them. I dont even drive hard on them. No fair:(
  2. Oct 31, 2012 at 10:27 AM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    60k with OEM breaks. When you replace them, get the same exact breaks. No need to get any other type of breaks for our trucks IMO.
  3. Oct 31, 2012 at 10:29 AM
    aidenhardcore
    mike
    boston,ma
    2017 trd off road
    You do have a point. Aftermarket is cheaper but I wanted to go oem just cause it came like that factory. I dont like messing with parts and have different brands in my truck. I like to keep it simple.
  4. Nov 1, 2012 at 9:06 AM
    Hans Moleman
    Hans Moleman Well-Known Member
    Bay Area, CA
    2023 F-150 Powerboost
    I have no problems with the front brakes but the factory rear brake shoes are awful. They squeal whenever I reverse in the morning. I could not put up with it anymore so I had to change them to Wagner's even though they had plenty of life left.
  5. Nov 1, 2012 at 9:25 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    I say go with aftermarket slotted rotors. They improve braking performance with a more aggressive initial "bite".
    BTW, for city driving, put the shifter in "4" instead of "D" to get a bit of engine braking. You will find you are on the brake pedal less often.
  6. Nov 1, 2012 at 11:17 AM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    Stick with blanks and factory or reputable aftermarket pad. You can get lifetime warranty pad from autozone but they may not brake that well and eat rotors.
  7. Nov 1, 2012 at 5:00 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I just had this issue two weeks ago. brakes were squealing and had vibes in the pedal when stopping. i took out the pads and checked the rotors, pads were getting glazed and the rotors were looking low and also checked out as warped from the dealer. had a brake shop check them too with same results. said they could resurface them, but that would be the last of em. ended up saying F it and got new Duralast rotors and pads from autozone and did the change.
    still strange how they needed to be replaced so soon. i am the second owner though so who knows.
  8. Nov 1, 2012 at 6:54 PM
    hardcrazyace
    hardcrazyace Active Member
    tony
    martain ky
    2011 trd off road
    If one side is allmost gone and the other side still good you have a bad brake hose or sticking calaper. Booth sides should be even
  9. Nov 7, 2012 at 5:55 AM
    TacoFMS
    TacoFMS Bubble bubble bubble pop
    Justin
    Louisa County, VA
    Just a vehicle to take trash to the dump
    One or two things modded... Check out the build thread
    dont mean to thread jack, but figured it would be better to just post the question in this thread as opposed to starting a new one. Im looking to swap out the stock pads soon and want an upgraded pad, anyone have any recomendations? I know the ebc green stuff pads are sup to be good but they seem kind of pricey to me. and the hawk pads seem the right price range but i dont know which ones to get? the PC ceramic, LTS semi-metallic, or the HPS? any thoughts and opinions from those that have used them??
  10. Nov 7, 2012 at 6:46 AM
    ManMan
    ManMan Well-Known Member
    Hawk LTS
  11. Nov 7, 2012 at 6:52 AM
    Taco Dan
    Taco Dan Well-Known Member
    Dan
    Tuscaloosa, AL
    07 FJ Cruiser auto 4X4
    Snorkel, Cooper ST Maxx 255/80/17, diff breather relocate, Cobra ultra III cb radio set up Warrior Products front bumper
    i have factory brakes but they are really squeaky, especially in the mornings. ive got new front ones, and the rears probably have 25-30% left on them. The rears are originals and the front were installed by Toyota. ive inspected them and cleaned them and the rotors with brake cleaner, but still get the same squeak. is there a better aftermarket brake that is better?
  12. Nov 7, 2012 at 7:16 AM
    TacoFMS
    Justin
    Louisa County, VA
    thanks, they do a better job of grabbing than the oem? what about noise/dust? only reason why i ask that is because i know ceramics are always shouting they are better with both of those things. but if a semi-met. is good with that stuff than why not get the extra grab of not having ceramic..... again thanks for your input.
  13. Nov 7, 2012 at 7:43 AM
    ManMan
    They had much better stopping than OEM, especially when towing. Noise and dust seem similar to OEM.
    Haven't used ceramic, so I cannot comment directly. But my understanding is reduced noise/dust at the cost of stopping performance
  14. Nov 7, 2012 at 7:52 AM
    TacoFMS
    Justin
    Louisa County, VA
    that is kind of what i assumed as well about the ceramic, so it looks like i will most likely go with the LTS, how have the life/wear of the pads been for ya?
  15. Nov 7, 2012 at 1:24 PM
    #35
    Nixinus
    Nixinus Well-Known Member
    Oregon
    2010 4x4
    What about factory TRD brakes? Anyone have any experience with these?
  16. Nov 11, 2012 at 8:24 PM
    #36
    12TRDTacoma
    Rob
    Concordia
    Boosted
    x2.. curious about those TRD pads as well as to why EBC yellows have not been mentioned. You figure kevlar brake pads would be the best route to go wouldn't they?
    I feel that the stock pads don't have a whole lot of bite when it comes to OH SHIT stopping situations.
  17. Nov 24, 2012 at 10:21 AM
    #37
    udy2554
    udy2554 NORTHERN RED-NECK
    Naples, NY
    '06 Tacoma TRD Sport
    Toytec ULK, Light Racing UCA's, OME Dakar rear leaves, ARB Bumper with XRC8 winch, Good Year Duratracs 285/70/17's on 17x9" Level 8 Strike 6's. Leer cap in the winter. Pioneer Double Din with BT, iPod, etc. Boston Acoustic components in all 4 doors with a Sony amp, powered 8" sub. Ultra gauge, Tom Tom...
    I just swapped in SP Performance slotted rotors and Hawk LTS'. I pull a camper and a landscape trailer, and was looking for a mild upgrade to stock.
    I went through Raceshopper.com.
    Talked with them before making my choice. Very reasonable prices and quick delivery!
  18. Nov 24, 2012 at 10:24 AM
    #38
    imsikotic
    imsikotic If u cant stand behind our troops. Stand in front
    Randy
    Temecula, Ca
    06 TRD Sport DesertRunner
    4" Camburg Race Spindles and Icon 2.5" ext travel Coilovers in the front for about 5"of lift and for the rear All-Pro 3" leaf pack and Fox 2.0 Resi's converted to piggyback and custom valved by DownSouth Motorsports. 17x9" KMC XD Addicts w/ 4.5 inch Backspacing and -12 Offset. Wrangler Duratracs 285/70/17. K&N CAI, Exhaust, Carriage Works Billet Grill, Custom Bed bar with ProComp fog lights,DirtKing Fabrication front bumper w/ 3 HID converted Hellas, Demello rear PreRunner bumper, Tinted windows, Full System w/ 2 10s, Garmin 265WT, ClearHLM. Theres more I just cant think of it right now.
  19. Nov 24, 2012 at 1:28 PM
    #39
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Says the man with an Old Man Emu suspension, Toytec AAL and LR UCAs :rolleyes:
    Aftermarket FTW. I got 70k miles on my stock brakes and then switched to Duralast. Lifetime warranty on pads, I'll never buy pads as long as I own the truck. :cool:
  20. Nov 24, 2012 at 8:53 PM
    #40
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    I'm swapping mine soon. I'm at 75K but I swapped pads at 50K and now my rotors are pretty much shot so replacing rotors, pads, and also going with SS lines. Probably do some blanks like Duralast, Hawk LTS pads, and the group buy SS lines.
